Slightly confused about plugin development
janjoh
#1 Post by janjoh » 17 Oct 2018, 22:03
Sooo, I decided that I need a plugin for AC measurement with ACS712.
So i followed the guides at https://www.letscontrolit.com/wiki/inde ... Platformio, https://www.letscontrolit.com/wiki/inde ... ith_github, https://www.letscontrolit.com/wiki/inde ... platformio I am running on Windows 10 Professional.
That gave me an environment that does a full PIO Build in about 15 minutes, and a normal_ESP8266_4096 (Which i gather would be the proper one for Wemos D1 Mini Pro, right?) in about 15 seconds.
I see a few warnings, about unused/redeclared variables, and I assume those are normal.
Then i copied _Pxxx_PluginTemplate.ino to _P217_ACS712AC.ino (I saw on the playground that I should use unique values between 100-199, but i also saw "used the next available one", which appears to be 217.
Peeking in _P002_ADC.ino i set out to modify my file to do nothing but initialize
//#include section
//include libraries here. For example:
//#include <LiquidCrystal_I2C.h>
//uncomment one of the following as needed
//#ifdef PLUGIN_BUILD_DEVELOPMENT
//#ifdef PLUGIN_BUILD_TESTING
#define PLUGIN_217
#define PLUGIN_ID_217     217               //plugin id
#define PLUGIN_NAME_217   "Energy Meter ACS712 AC"     //"Plugin Name" is what will be dislpayed in the selection list
#define PLUGIN_VALUENAME1_217 "Ampere (RMS)"     //variable output of the plugin. The label is in quotation marks
//#define PLUGIN_VALUENAME2_xxx "output2"     //multiple outputs are supported
//#define PLUGIN_xxx_DEBUG  false             //set to true for extra log info in the debug
PIN/port configuration is stored in the following:
Settings.TaskDevicePin1[event->TaskIndex] - The first GPIO pin selected within the task
Settings.TaskDevicePin2[event->TaskIndex] - The second GPIO pin selected within the task
Settings.TaskDevicePin3[event->TaskIndex] - The third GPIO pin selected within the task
Settings.TaskDevicePort[event->TaskIndex] - The port in case the device has multiple in/out pins
Custom configuration is stored in the following:
Settings.TaskDevicePluginConfig[event->TaskIndex][x]
x can be between 1 - 8 and can store values between -32767 - 32768 (16 bit)
//A plugin has to implement the following function
boolean Plugin_217(byte function, struct EventStruct *event, String& string)
  //function: reason the plugin was called
  //event: ??add description here??
  // string: ??add description here??
  boolean success = false;
  switch (function)
    case PLUGIN_DEVICE_ADD:
        //This case defines the device characteristics, edit appropriately
        Device[++deviceCount].Number = PLUGIN_ID_217;
        Device[deviceCount].Type = DEVICE_TYPE_ANALOG;  //how the device is connected
        Device[deviceCount].VType = SENSOR_TYPE_SINGLE; //type of value the plugin will return, used only for Domoticz
        Device[deviceCount].FormulaOption = true;
        Device[deviceCount].ValueCount = 1;             //number of output variables. The value should match the number of keys PLUGIN_VALUENAME1_xxx
        Device[deviceCount].TimerOptional = true;
        Device[deviceCount].DecimalsOnly = true;
    case PLUGIN_GET_DEVICENAME:
      //return the device name
      string = F(PLUGIN_NAME_217);
      //called when the user opens the module configuration page
      //it allows to add a new row for each output variable of the plugin
      strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_VALUENAME1_217));
    case PLUGIN_WEBFORM_LOAD:
      //this case defines what should be displayed on the web form, when this plugin is selected
      //The user's selection will be stored in
      //Settings.TaskDevicePluginConfig[event->TaskIndex][x] (custom configuration)
      // Make sure not to append data to the string variable in this PLUGIN_WEBFORM_LOAD call.
      // This has changed, so now use the appropriate functions to write directly to the Streaming
      // WebServer. This takes much less memory and is faster.
      // There will be an error in the web interface if something is added to the "string" variable.
      //Use any of the following (defined at WebServer.ino):
      //addFormNote(F("not editable text added here"));
      To add some html, which cannot be done in the existing functions, add it in the following way:
      addHtml(F("<TR><TD>Analog Pin:<TD>"));
      For strings, always use the F() macro, which stores the string in flash, not in memory.
      //String dropdown[5] = { F("option1"), F("option2"), F("option3"), F("option4")};
      //addFormSelector(string, F("drop-down menu"), F("plugin_xxx_displtype"), 4, dropdown, NULL, Settings.TaskDevicePluginConfig[event->TaskIndex][0]);
      //number selection (min-value - max-value)
      addFormNumericBox(string, F("description"), F("plugin_xxx_description"), Settings.TaskDevicePluginConfig[event->TaskIndex][1], min-value, max-value);
      //after the form has been loaded, set success and break
      success = true;
    case PLUGIN_WEBFORM_SAVE:
      //this case defines the code to be executed when the form is submitted
      //the plugin settings should be saved to Settings.TaskDevicePluginConfig[event->TaskIndex][x]
      //ping configuration should be read from Settings.TaskDevicePin1[event->TaskIndex] and stored
      //after the form has been saved successfuly, set success and break
      success = true;
    case PLUGIN_INIT:
      //this case defines code to be executed when the plugin is initialised
      //after the plugin has been initialised successfuly, set success and break
      success = true;
    case PLUGIN_READ:
      //code to be executed to read data
      //It is executed according to the delay configured on the device configuration page, only once
      //after the plugin has read data successfuly, set success and break
      success = true;
    case PLUGIN_WRITE:
      //this case defines code to be executed when the plugin executes an action (command).
      //Commands can be accessed via rules or via http.
      //As an example, http://192.168.1.12//control?cmd=dothis
      //implies that there exists the comamnd "dothis"
      if (plugin_not_initialised)
      //parse string to extract the command
      String tmpString  = string;
      if (argIndex)
        tmpString = tmpString.substring(0, argIndex);
      String tmpStr = string;
      int comma1 = tmpStr.indexOf(',');
      if (tmpString.equalsIgnoreCase(F("dothis"))) {
        //do something
        success = true;     //set to true only if plugin has executed a command successfully
	case PLUGIN_EXIT:
	  //perform cleanup tasks here. For example, free memory
    case PLUGIN_ONCE_A_SECOND:
      //code to be executed once a second. Tasks which do not require fast response can be added here
      success = true;
    case PLUGIN_TEN_PER_SECOND:
      //code to be executed 10 times per second. Tasks which require fast response can be added here
      //be careful on what is added here. Heavy processing will result in slowing the module down!
      success = true;
  }   // switch
  return success;
}     //function
//implement plugin specific procedures and functions here
void p217_do_sth_useful()
  //code
That, however, fails quite miserably. So, I take it I am missing something quite fundamental.. but what?
C:/Users/j2/Documents/GitHub/ESPEasy/src/_P217_ACS712AC.ino:197:51: note: in expansion of macro 'F'
C:/Users/j2/Documents/GitHub/ESPEasy/src/_P217_ACS712AC.ino:289:11: error: 'plugin_not_initialised' was not declared in this scope
C:/Users/j2/Documents/GitHub/ESPEasy/src/_P217_ACS712AC.ino:309:11: warning: unused variable 'comma1' [-Wunused-variable]
*** [.pioenvs\normal_ESP8266_4096\src\ESPEasy.ino.cpp.o] Error 1
 [ERROR] Took 7.91 seconds
Environment normal_ESP8266_4096                 [ERROR]
 [ERROR] Took 7.92 seconds
 [SUMMARY]
Environment esp-wrover-kit_test_1M8_partition   [SKIP]
Environment esp32dev                            [SKIP]
Environment esp32test_1M8_partition             [SKIP]
Environment normal_ESP8266_1024                 [SKIP]
Environment normal_ESP8285_1024                 [SKIP]
Environment normal_WROOM02_2048                 [SKIP]
Environment normal_IR_ESP8266_4096              [SKIP]
Environment test_ESP8266_1024                   [SKIP]
Environment test_ESP8285_1024                   [SKIP]
Environment test_WROOM02_2048                   [SKIP]
Environment test_ESP8266_4096                   [SKIP]
Environment test_ESP8266_4096_VCC               [SKIP]
Environment dev_ESP8266_1024                    [SKIP]
Environment dev_ESP8285_1024                    [SKIP]
Environment dev_WROOM02_2048                    [SKIP]
Environment dev_ESP8266_4096                    [SKIP]
Environment dev_ESP8266PUYA_1024                [SKIP]
Environment dev_ESP8266PUYA_1024_VCC            [SKIP]
Environment hard_SONOFF_POW                     [SKIP]
Environment hard_SONOFF_POW_R2                  [SKIP]
Environment hard_Shelly_1                       [SKIP]
Environment hard_Ventus_W266                    [SKIP]
janjoh
Re: Slightly confused about plugin development
#2 Post by janjoh » 20 Oct 2018, 23:54
Okay.. I think i now have a skeleton that at least appears to build. But, I am still not really understanding userVars i guess...
In PLUGIN_READ.. Lets say that i want the device to report my "AmpsRMS"... what is my next step so to say?
  #define PLUGIN_217
  #define PLUGIN_NAME_217   "Energy (AC) - ACS712"     //"Plugin Name" is what will be dislpayed in the selection list
  #define PLUGIN_VALUENAME1_217 "Amperes (RMS)"     //variable output of the plugin. The label is in quotation marks
  #define PLUGIN_217_DEBUG  true             //set to true for extra log info in the debug
    switch (function)
        success = true;
        success = true;
      case PLUGIN_INIT:
        success = true;
      case PLUGIN_READ:
        int mVperAmp = 66; // use 100 for 20A Module and 66 for 30A Module
        double Voltage = 0;
        double VRMS = 0;
        double AmpsRMS = 0;
       Voltage = p217_get_VPP();
        VRMS = (Voltage/2.0) *0.707;
        AmpsRMS = (VRMS * 1000)/mVperAmp;
        success = true;
      case PLUGIN_EXIT:
        success = true;
float p217_get_VPP()
    const int sensorIn = A0;
    float result;
    int readValue;             //value read from the sensor
    int maxValue = 0;          // store max value here
    int minValue = 1024;          // store min value here
    uint32_t start_time = millis();
   while((millis()-start_time) < 1000) //sample for 1 Sec
       readValue = analogRead(sensorIn);
       // see if you have a new maxValue
       if (readValue > maxValue)
           /*record the maximum sensor value*/
           maxValue = readValue;
       if (readValue < minValue)
           minValue = readValue;
   // Subtract min from max
   result = ((maxValue - minValue) * 5.0)/1024.0;
   return result;
#3 Post by ThomasB » 26 Oct 2018, 16:47
You would assign PLUGIN_READ's AmpsRMS to the UserVar like this:
UserVar[event->BaseVarIndex] = (float)AmpsRMS;
janjoh
#4 Post by janjoh » 26 Oct 2018, 22:16
ThomasB wrote: 26 Oct 2018, 16:47 You would assign PLUGIN_READ's AmpsRMS to the UserVar like this:
Ok. That was, eh, to simple in theory :)
But I still do not get any values in the web UI. I added som logging, and i see the "expected" values there, but i am still missing something... Annoying.
  #define PLUGIN_217
    switch (function)
        success = true;
        success = true;
      case PLUGIN_INIT:
        success = true;
      case PLUGIN_READ:
        addLog(LOG_LEVEL_INFO,"P217PluginRead");
        double Voltage = 0;
        double VRMS = 0;
        double AmpsRMS = 0;
        addLog(LOG_LEVEL_INFO,String(Voltage));
        addLog(LOG_LEVEL_INFO,String(AmpsRMS));
        success = true;
      case PLUGIN_EXIT:
        success = true;
    float result;
   return result;
#5 Post by ThomasB » 27 Oct 2018, 00:40
Then continue to check for mistakes in your code. You can review the other plugins to see working examples.
Unfortunately I don't have time to do a thorough review. But I see a significant error. Your Plugin_075() function is missing the closing return success; that tells the calling function to update the user vars.
janjoh
#6 Post by janjoh » 27 Oct 2018, 08:56
ThomasB wrote: 27 Oct 2018, 00:40 Then continue to check for mistakes in your code. You can review the other plugins to see working examples.
That it all it was. Sigh...
I am so very grateful for your help. Truly. Thank you.
Now to re-do it. Clean it up and make it better :)
#7 Post by ThomasB » 27 Oct 2018, 18:42
Glad to hear you got it working.
janjoh
#8 Post by janjoh » 27 Oct 2018, 21:19
ThomasB wrote: 27 Oct 2018, 18:42 Glad to hear you got it working.
I think i must have accidentally deleted that during all my "incremental approximation" :D
stefannetzer
#9 Post by stefannetzer » 12 Jul 2019, 00:02
Hi janjoh
I like your Plugin. After some work with the module I did some reasearch to stabilize the Measurements and to shorten the measurement cycle. Before adding anything to GitHub, I would like to get in touch with you first.
Best Regards
Stefan
alexthesmeus
#10 Post by alexthesmeus » 12 Nov 2019, 13:31
I Stefan,
Can you share your version of the plugin? I'd like to use it.
Alex
Users browsing this forum: Bing [Bot] and 15 guests
