LED (4x20) Unable to Define & Save Device Lines 1-4
Posted: 18 Nov 2018, 23:03
Having some strange problems with setting up an LED device which I've done many times before. Sure I've had this problem before but can't locate any related threads.
When I add some commands to any of the LED device lines 1-4, such as "%sysweekday_s% %systm_hm% %sysday%-%sysmonth%-%sysyear%", I select submit but the line doesn't appear to be saved.
I've tried different EDP8266s, different 4x20 LEDs and older builds (such as ESP_Easy_mega-20181107_normal_core_241_ESP8266_4096) - currently using ESP_Easy_mega-20181117_normal_ESP8266_4096.
I've attached the zipped config file with all setup details.
Any help appreciated. Thanks.
