[Solved] Calculating Temperature Difference
costo
#1 Post by costo » 07 Feb 2019, 02:55
I am using ESPEasy 1.48 with MQTT protocol.
I have two DS18b20 sensors , one connected to the cold and the other to the warmwater pipe of my central heating.
Both values are received by domoticz. Now I also want to display the temperature_difference into domoticz.
I could easy do this in domoticz with a script but I thought it must be easy for EASPEasy to do this for me.
Sending the temperature with Publish domoticz/in works but the value is displayed as a string.
this is my Rules:
On System#Boot do
  timerSet,1,30
On Rules#Timer=1 do
 Diff = Warm#Temperature-Cold#Temperature
 Publish domoticz/in,{"idx":775,"nvalue":0,"svalue":Diff}
 timerSet,1,30
The log looks like this:
2089230 : DS : Temperature: 40.75 (28-d4-41-45-92-e-2-44)
2089231 : EVENT: Cold#Temperature=40.75
2089301 : DS : Temperature: 45.44 (28-9-4a-45-92-e-2-ba)
2089303 : EVENT: Warm#Temperature=45.44
2089378 : MQTT : Connected to broker
2089381 : Subscribed to: domoticz/out
2095542 : EVENT: Rules#Timer=1
2095546 : ACT : Diff = Warm#Temperature-Cold#Temperature
2095550 : ACT :
2095554 : ACT : Publish domoticz/in,{"idx":775,"nvalue":0,"svalue":Diff}
2095563 : ACT : timerSet,1,30
I tried it in several ways but I cannot make it work so that the Diff string is replaced by the calculated difference of warm & cold.
Is this possible to do in ESPEasy 1.48 ?
How can it be done ?
Or do I need to go to ther mega version ?
Re: Calculating Temperature Difference
#2 Post by grovkillen » 07 Feb 2019, 05:37
Create a dummy device and do this:
On System#Boot do
  timerSet,1,30
On Rules#Timer=1 do
 TaskValueSet,12,1,[Warm#Temperature]-[Cold#Temperature]
 Publish domoticz/in,{"idx":775,"nvalue":0,"svalue":[Diff#Temp]}
 timerSet,1,30
In this example the dummy is named Diff#Temp and is stored on task number 12.
costo
#3 Post by costo » 07 Feb 2019, 14:37
Thank you grovkillen for this excellent solution.
After posting the question here I kept experimenting with the example in the wiki and found a working solution with a dummy.
 on Warm#Temperature do
  TaskValueSet,4,1,[Warm#Temperature]-[Cold#Temperature]
   Publish domoticz/in,{"idx":775,"nvalue":0,"svalue":"[Diff#C1]"}
But I find your solution with timerSet more elegant so I will use that.
