Problem to publish with mqtt
Masterg4941
#1 Post by Masterg4941 » 10 Mar 2019, 16:28
Hello everybody,
I have a 8266 mini with EASY ESP (mega-20190305) in use.
I also have a Raspberry Pi with IoBroker and mqtt/Sonoff adapters.
Now I want to integrate a PIR into the 8266 mini and recive the states on my IoBroker.
And here is my problem. I just can´t recive the GPIO state on the IoBoker and I don´t know why.
I also connected a DHT11 to the ESP and the mesurements are directly visible on the Iobroker. So why it doesnt work with the "switch"?
Can someone tell me what I am doing wrong?
Re: Problem to publish with mqtt
#2 Post by grovkillen » 10 Mar 2019, 18:43
Event commands should be placed last. Try move the event command after the publish command.
#3 Post by ThomasB » 10 Mar 2019, 20:21
FWIW, your rules duplicate each MQTT publish in the <if> statements. I mean, because the rules call the external Bewegun_on/Bewegun_off events there is no reason to duplicate the MQTT again with an identical local publish statement. I would have posted revised rules but your examples are graphic images and I recreating them is too much work for my lazy fingers. Hint: Always post code as text.
Debug Tip.
Do you see the publish event in the logs? I mean, do this:
1. Turn on weblog:
Tools->Advance->Web log Level: info
2. Watch the weblog as the Flur device is activated on and off:
Tool->Log
3. All the sent MQTT's will be reported in the log. They begin with:
ACT : Publish Bewegungsmelder_Flur/PIR/GPIO
Does the log report the publish events for the Flur when it is activated? If it does, then the MQTT payloads are being sent.
Masterg4941
#4 Post by Masterg4941 » 10 Mar 2019, 20:53
ok I reworked the rule to:
on PIR#State do
if [PIR#State]=1
Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
event, Bewegung_on
Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
event, Bewegung_off
On Bewegung_on do
GPIO 12,1
On Bewegung_off do
GPIO 12,0
And I can see the ACT into the Logfile. See below.
But I still can´t find the publish into the IoBroker.
16559738: DHT  : Humidity: 54.00
16559741: EVENT: Flur#Temperature=19.00
16559794: EVENT: Flur#Humidity=54.00
16559882: SW   : State 1.00
16559885: EVENT: PIR#State=1.00
16559931: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16559940: Command: publish
16559944: ACT  : event, Bewegung_on
16559951: Command: event
16559952: EVENT:  Bewegung_on
16560006: ACT  :
16560734: DHT  : No Reading
16560789: SW   : State 1.00
16560792: EVENT: PIR#State=1.00
16560869: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16560878: Command: publish
16560882: ACT  : event, Bewegung_on
16560889: Command: event
16560890: EVENT:  Bewegung_on
16560943: ACT  :
16561738: DHT  : Temperature: 19.00
16561738: DHT  : Humidity: 54.00
16561741: EVENT: Flur#Temperature=19.00
16561789: EVENT: Flur#Humidity=54.00
16561902: SW   : State 1.00
16561905: EVENT: PIR#State=1.00
16561951: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16561960: Command: publish
16561964: ACT  : event, Bewegung_on
16561971: Command: event
16561972: EVENT:  Bewegung_on
16562024: ACT  :
16562228: WD   : Uptime 276 ConnectFailures 0 FreeMem 16672 WiFiStatus 3
16562734: DHT  : No Reading
16562789: SW   : State 1.00
16562792: EVENT: PIR#State=1.00
16562835: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16562843: Command: publish
16562847: ACT  : event, Bewegung_on
16562855: Command: event
16562855: EVENT:  Bewegung_on
16562907: ACT  :
16563738: DHT  : Temperature: 19.00
16563738: DHT  : Humidity: 54.00
16563741: EVENT: Flur#Temperature=19.00
16563790: EVENT: Flur#Humidity=54.00
16563900: SW   : State 1.00
16563903: EVENT: PIR#State=1.00
16563947: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16563956: Command: publish
16563960: ACT  : event, Bewegung_on
16563967: Command: event
16563968: EVENT:  Bewegung_on
16564022: ACT  :
16564734: DHT  : No Reading
16564789: SW   : State 1.00
16564792: EVENT: PIR#State=1.00
16564837: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16564846: Command: publish
16564850: ACT  : event, Bewegung_on
16564857: Command: event
16564858: EVENT:  Bewegung_on
16564909: ACT  :
16565738: DHT  : Temperature: 19.00
16565738: DHT  : Humidity: 54.00
16565741: EVENT: Flur#Temperature=19.00
16565789: EVENT: Flur#Humidity=54.00
16565901: SW   : State 1.00
16565904: EVENT: PIR#State=1.00
16565949: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16565958: Command: publish
16565962: ACT  : event, Bewegung_on
16565969: Command: event
16565970: EVENT:  Bewegung_on
16566021: ACT  :
16566734: DHT  : No Reading
16566789: SW   : State 1.00
16566792: EVENT: PIR#State=1.00
16566835: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16566844: Command: publish
16566847: ACT  : event, Bewegung_on
16566856: Command: event
16566857: EVENT:  Bewegung_on
16566908: ACT  :
16567738: DHT  : Temperature: 19.00
16567738: DHT  : Humidity: 54.00
16567741: EVENT: Flur#Temperature=19.00
16567792: EVENT: Flur#Humidity=54.00
16567883: SW   : State 1.00
16567886: EVENT: PIR#State=1.00
16567956: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16567965: Command: publish
16567969: ACT  : event, Bewegung_on
16567977: Command: event
16567977: EVENT:  Bewegung_on
16568031: ACT  :
16568793: EVENT: PIR#State=1.00
16568838: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16568846: Command: publish
16568850: ACT  : event, Bewegung_on
16568858: Command: event
16568859: EVENT:  Bewegung_on
16568912: ACT  :
16569471: SW  : GPIO=12 State=0 Output value=0
16569475: EVENT: PIR#State=0.00
16569527: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16569536: Command: publish
16569540: ACT  : event, Bewegung_off
16569547: Command: event
16569548: EVENT:  Bewegung_off
16569634: ACT  :
16569738: DHT  : Temperature: 19.00
16569738: DHT  : Humidity: 54.00
16569742: EVENT: Flur#Temperature=19.00
16569796: EVENT: Flur#Humidity=54.00
16569890: SW   : State 0.00
16569893: EVENT: PIR#State=0.00
16569945: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16569954: Command: publish
16569958: ACT  : event, Bewegung_off
16569966: Command: event
16569966: EVENT:  Bewegung_off
16570018: ACT  :
16570735: DHT  : No Reading
16570867: Command: event
16570868: EVENT:  Bewegung_off
16570919: ACT  :
16571738: DHT  : Temperature: 19.00
16571738: DHT  : Humidity: 54.00
16571741: EVENT: Flur#Temperature=19.00
16571792: EVENT: Flur#Humidity=54.00
16571882: SW   : State 0.00
16571885: EVENT: PIR#State=0.00
16571937: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16571945: Command: publish
16571949: ACT  : event, Bewegung_off
16571957: Command: event
16571958: EVENT:  Bewegung_off
16572045: ACT  :
16572736: DHT  : No Reading
16572789: SW   : State 0.00
16572792: EVENT: PIR#State=0.00
16572844: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16572853: Command: publish
16572860: ACT  : event, Bewegung_off
16572870: Command: event
16572871: EVENT:  Bewegung_off
16572951: ACT  :
16573940: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16573949: Command: publish
16573953: ACT  : event, Bewegung_off
16573960: Command: event
16573961: EVENT:  Bewegung_off
16574011: ACT  :
16574734: DHT  : No Reading
16574789: SW   : State 0.00
16574792: EVENT: PIR#State=0.00
16574845: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16574854: Command: publish
16574858: ACT  : event, Bewegung_off
16574865: Command: event
16574866: EVENT:  Bewegung_off
16574952: ACT  :
16575947: Command: publish
16575951: ACT  : event, Bewegung_off
16575959: Command: event
16575960: EVENT:  Bewegung_off
16576012: ACT  :
16576734: DHT  : No Reading
16576789: SW   : State 0.00
16576792: EVENT: PIR#State=0.00
16576842: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16576851: Command: publish
16576855: ACT  : event, Bewegung_off
16576862: Command: event
16576863: EVENT:  Bewegung_off
16576915: ACT  :
16577742: DHT  : Temperature: 19.00
16577742: DHT  : Humidity: 54.00
16577745: EVENT: Flur#Temperature=19.00
16577811: EVENT: Flur#Humidity=54.00
16577899: SW   : State 0.00
16577903: EVENT: PIR#State=0.00
16577957: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16577966: Command: publish
16577970: ACT  : event, Bewegung_off
16577980: Command: event
16577981: EVENT:  Bewegung_off
16578038: ACT  :
16578734: DHT  : No Reading
16578789: SW   : State 0.00
16578792: EVENT: PIR#State=0.00
16578843: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16578851: Command: publish
16578856: ACT  : event, Bewegung_off
16578863: Command: event
16578864: EVENT:  Bewegung_off
16578913: ACT  :
16579738: DHT  : Temperature: 19.00
16579738: DHT  : Humidity: 54.00
16579741: EVENT: Flur#Temperature=19.00
16579790: EVENT: Flur#Humidity=54.00
16579901: SW   : State 0.00
16579904: EVENT: PIR#State=0.00
16579956: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16579966: Command: publish
16579970: ACT  : event, Bewegung_off
16579978: Command: event
16579978: EVENT:  Bewegung_off
16580030: ACT  :
16580734: DHT  : No Reading
16580789: SW   : State 0.00
16580792: EVENT: PIR#State=0.00
16580842: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16580850: Command: publish
16580854: ACT  : event, Bewegung_off
16580862: Command: event
16580862: EVENT:  Bewegung_off
16580913: ACT  :
16581738: DHT  : Temperature: 19.00
16581738: DHT  : Humidity: 54.00
16581741: EVENT: Flur#Temperature=19.00
16581788: EVENT: Flur#Humidity=54.00
16581876: SW   : State 0.00
16581879: EVENT: PIR#State=0.00
16581960: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16581968: Command: publish
16581972: ACT  : event, Bewegung_off
16581979: Command: event
16581980: EVENT:  Bewegung_off
16582034: ACT  :
16582734: DHT  : No Reading
16582789: SW   : State 0.00
16582792: EVENT: PIR#State=0.00
16582842: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16582851: Command: publish
16582855: ACT  : event, Bewegung_off
16582862: Command: event
16582863: EVENT:  Bewegung_off
16582912: ACT  :
16583738: DHT  : Temperature: 19.00
16583738: DHT  : Humidity: 54.00
16583741: EVENT: Flur#Temperature=19.00
16583811: EVENT: Flur#Humidity=54.00
16583897: SW   : State 0.00
16583901: EVENT: PIR#State=0.00
16583954: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16583963: Command: publish
16583967: ACT  : event, Bewegung_off
16583975: Command: event
16583975: EVENT:  Bewegung_off
16584033: ACT  :
16584734: DHT  : No Reading
16584789: SW   : State 0.00
16584792: EVENT: PIR#State=0.00
16584843: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16584851: Command: publish
16584855: ACT  : event, Bewegung_off
16584862: Command: event
16584863: EVENT:  Bewegung_off
16584915: ACT  :
16585738: DHT  : Temperature: 19.00
16585738: DHT  : Humidity: 54.00
16585742: EVENT: Flur#Temperature=19.00
16585788: EVENT: Flur#Humidity=54.00
16585895: SW   : State 0.00
16585900: EVENT: PIR#State=0.00
16585952: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16585960: Command: publish
16585964: ACT  : event, Bewegung_off
16585972: Command: event
16585972: EVENT:  Bewegung_off
16586027: ACT  :
16586734: DHT  : No Reading
16586789: SW   : State 0.00
16586792: EVENT: PIR#State=0.00
16586844: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16586852: Command: publish
16586857: ACT  : event, Bewegung_off
16586864: Command: event
16586865: EVENT:  Bewegung_off
16586913: ACT  :
16587750: DHT  : Temperature: 19.00
16587750: DHT  : Humidity: 54.00
16587754: EVENT: Flur#Temperature=19.00
16587801: EVENT: Flur#Humidity=54.00
16587887: SW   : State 0.00
16587891: EVENT: PIR#State=0.00
16587971: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16587980: Command: publish
16587984: ACT  : event, Bewegung_off
16587992: Command: event
16587993: EVENT:  Bewegung_off
16588044: ACT  :
16588736: DHT  : No Reading
16588789: SW   : State 0.00
16588792: EVENT: PIR#State=0.00
16588842: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16588850: Command: publish
16588854: ACT  : event, Bewegung_off
16588861: Command: event
16588862: EVENT:  Bewegung_off
16588913: ACT  :
16589740: DHT  : Temperature: 19.00
16589740: DHT  : Humidity: 54.00
16589743: EVENT: Flur#Temperature=19.00
16589791: EVENT: Flur#Humidity=54.00
16589901: SW   : State 0.00
16589905: EVENT: PIR#State=0.00
16589956: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16589964: Command: publish
16589968: ACT  : event, Bewegung_off
16589975: Command: event
16589976: EVENT:  Bewegung_off
16590030: ACT  :
16590734: DHT  : No Reading
16590789: SW   : State 0.00
16590792: EVENT: PIR#State=0.00
16590843: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16590852: Command: publish
16590856: ACT  : event, Bewegung_off
16590863: Command: event
16590864: EVENT:  Bewegung_off
16590913: ACT  :
16591738: DHT  : Temperature: 19.00
16591738: DHT  : Humidity: 54.00
16591741: EVENT: Flur#Temperature=19.00
16591788: EVENT: Flur#Humidity=54.00
16591872: SW   : State 0.00
16591876: EVENT: PIR#State=0.00
16591955: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16591964: Command: publish
16591968: ACT  : event, Bewegung_off
16591975: Command: event
16591976: EVENT:  Bewegung_off
16592026: ACT  :
16592227: WD   : Uptime 277 ConnectFailures 0 FreeMem 16984 WiFiStatus 3
16592734: DHT  : No Reading
16592789: SW   : State 0.00
16592792: EVENT: PIR#State=0.00
16592842: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16592850: Command: publish
16592854: ACT  : event, Bewegung_off
16592861: Command: event
16592862: EVENT:  Bewegung_off
16592913: ACT  :
16593738: DHT  : Temperature: 19.00
16593738: DHT  : Humidity: 54.00
16593741: EVENT: Flur#Temperature=19.00
16593789: EVENT: Flur#Humidity=54.00
16593900: SW   : State 0.00
16593903: EVENT: PIR#State=0.00
16593955: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16593963: Command: publish
16593967: ACT  : event, Bewegung_off
16593975: Command: event
16593975: EVENT:  Bewegung_off
16594032: ACT  :
16594734: DHT  : No Reading
16594789: SW   : State 0.00
16594792: EVENT: PIR#State=0.00
16594843: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16594851: Command: publish
16594856: ACT  : event, Bewegung_off
16594863: Command: event
16594864: EVENT:  Bewegung_off
16594914: ACT  :
16595738: DHT  : Temperature: 19.00
16595738: DHT  : Humidity: 54.00
16595741: EVENT: Flur#Temperature=19.00
16595788: EVENT: Flur#Humidity=54.00
16595899: SW   : State 0.00
16595902: EVENT: PIR#State=0.00
16595955: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16595963: Command: publish
16595967: ACT  : event, Bewegung_off
16595974: Command: event
16595975: EVENT:  Bewegung_off
16596025: ACT  :
16596734: DHT  : No Reading
16596789: SW   : State 0.00
16596792: EVENT: PIR#State=0.00
16596842: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16596851: Command: publish
16596856: ACT  : event, Bewegung_off
16596864: Command: event
16596865: EVENT:  Bewegung_off
16596914: ACT  :
16597738: DHT  : Temperature: 19.00
16597738: DHT  : Humidity: 54.00
16597742: EVENT: Flur#Temperature=19.00
16597818: EVENT: Flur#Humidity=54.00
16597904: SW   : State 0.00
16597908: EVENT: PIR#State=0.00
16597958: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16597967: Command: publish
16597971: ACT  : event, Bewegung_off
16597981: Command: event
16597982: EVENT:  Bewegung_off
16598037: ACT  :
16598734: DHT  : No Reading
16598789: SW   : State 0.00
16598792: EVENT: PIR#State=0.00
16598844: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16598852: Command: publish
16598856: ACT  : event, Bewegung_off
16598864: Command: event
16598865: EVENT:  Bewegung_off
16598915: ACT  :
16599739: DHT  : Temperature: 19.00
16599740: DHT  : Humidity: 54.00
16599743: EVENT: Flur#Temperature=19.00
16599790: EVENT: Flur#Humidity=54.00
16599876: SW   : State 0.00
16599879: EVENT: PIR#State=0.00
16599931: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16599939: Command: publish
16599943: ACT  : event, Bewegung_off
16599950: Command: event
16599951: EVENT:  Bewegung_off
16600002: ACT  :
16600734: DHT  : No Reading
16600789: SW   : State 0.00
16600792: EVENT: PIR#State=0.00
16600842: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16600852: Command: publish
16600859: ACT  : event, Bewegung_off
16600868: Command: event
16600869: EVENT:  Bewegung_off
16600945: ACT  :
16601738: DHT  : Temperature: 19.00
16601738: DHT  : Humidity: 54.00
16601741: EVENT: Flur#Temperature=19.00
16601790: EVENT: Flur#Humidity=54.00
16601876: SW   : State 0.00
16601879: EVENT: PIR#State=0.00
16601930: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16601939: Command: publish
16601942: ACT  : event, Bewegung_off
16601950: Command: event
16601950: EVENT:  Bewegung_off
16602004: ACT  :
16602734: DHT  : No Reading
16602790: SW   : State 0.00
16602796: EVENT: PIR#State=0.00
16602865: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16602873: Command: publish
16602877: ACT  : event, Bewegung_off
16602885: Command: event
16602886: EVENT:  Bewegung_off
16602937: ACT  :
16603738: DHT  : Temperature: 19.00
16603738: DHT  : Humidity: 54.00
16603742: EVENT: Flur#Temperature=19.00
16603788: EVENT: Flur#Humidity=54.00
16603876: SW   : State 0.00
16603879: EVENT: PIR#State=0.00
16603931: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16603940: Command: publish
16603944: ACT  : event, Bewegung_off
16603951: Command: event
16603952: EVENT:  Bewegung_off
16604003: ACT  :
16604734: DHT  : No Reading
16604789: SW   : State 0.00
16604793: EVENT: PIR#State=0.00
16604845: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16604853: Command: publish
16604857: ACT  : event, Bewegung_off
16604864: Command: event
16604865: EVENT:  Bewegung_off
16604915: ACT  :
16605738: DHT  : Temperature: 19.00
16605738: DHT  : Humidity: 54.00
16605741: EVENT: Flur#Temperature=19.00
16605789: EVENT: Flur#Humidity=54.00
16605901: SW   : State 0.00
16605905: EVENT: PIR#State=0.00
16605956: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16605965: Command: publish
16605970: ACT  : event, Bewegung_off
16605978: Command: event
16605979: EVENT:  Bewegung_off
16606035: ACT  :
16606815: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16606824: Command: publish
16606828: ACT  : event, Bewegung_on
16606835: Command: event
16606836: EVENT:  Bewegung_on
16606885: ACT  :
16606960: SW   : State 1.00
16606963: EVENT: PIR#State=1.00
16607006: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16607014: Command: publish
16607018: ACT  : event, Bewegung_on
16607026: Command: event
16607026: EVENT:  Bewegung_on
16607078: ACT  :
16607738: DHT  : Temperature: 19.00
16607738: DHT  : Humidity: 54.00
16607742: EVENT: Flur#Temperature=19.00
16607788: EVENT: Flur#Humidity=54.00
16607877: SW   : State 1.00
16607880: EVENT: PIR#State=1.00
16607931: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16607939: Command: publish
16607943: ACT  : event, Bewegung_on
16607951: Command: event
16607951: EVENT:  Bewegung_on
16608003: ACT  :
16608857: EVENT:  Bewegung_on
16608906: ACT  :
16609738: DHT  : Temperature: 19.00
16609738: DHT  : Humidity: 54.00
16609741: EVENT: Flur#Temperature=19.00
16609790: EVENT: Flur#Humidity=54.00
16609876: SW   : State 1.00
16609880: EVENT: PIR#State=1.00
16609922: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16609931: Command: publish
16609935: ACT  : event, Bewegung_on
16609942: Command: event
16609943: EVENT:  Bewegung_on
16609995: ACT  :
16610734: DHT  : No Reading
16610789: SW   : State 1.00
16610792: EVENT: PIR#State=1.00
16610838: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16610846: Command: publish
16610850: ACT  : event, Bewegung_on
16610857: Command: event
16610858: EVENT:  Bewegung_on
16610910: ACT  :
16611738: DHT  : Temperature: 19.00
16611738: DHT  : Humidity: 54.00
16611741: EVENT: Flur#Temperature=19.00
16611788: EVENT: Flur#Humidity=54.00
16611876: SW   : State 1.00
16611879: EVENT: PIR#State=1.00
16611923: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16611931: Command: publish
16611935: ACT  : event, Bewegung_on
16611942: Command: event
16611943: EVENT:  Bewegung_on
16611994: ACT  :
16612734: DHT  : No Reading
16612857: EVENT:  Bewegung_on
16612907: ACT  :
16613738: DHT  : Temperature: 19.00
16613738: DHT  : Humidity: 54.00
16613741: EVENT: Flur#Temperature=19.00
16613789: EVENT: Flur#Humidity=54.00
16613876: SW   : State 1.00
16613879: EVENT: PIR#State=1.00
16613923: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16613931: Command: publish
16613935: ACT  : event, Bewegung_on
16613942: Command: event
16613943: EVENT:  Bewegung_on
16613996: ACT  :
16614734: DHT  : No Reading
16614789: SW   : State 1.00
16614792: EVENT: PIR#State=1.00
16614835: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16614843: Command: publish
16614847: ACT  : event, Bewegung_on
16614854: Command: event
16614855: EVENT:  Bewegung_on
16614906: ACT  :
16615738: DHT  : Temperature: 19.00
16615738: DHT  : Humidity: 54.00
16615741: EVENT: Flur#Temperature=19.00
16615788: EVENT: Flur#Humidity=54.00
16615876: SW   : State 1.00
16615879: EVENT: PIR#State=1.00
16615924: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16615932: Command: publish
16615936: ACT  : event, Bewegung_on
16615943: Command: event
16615944: EVENT:  Bewegung_on
16615995: ACT  :
16616734: DHT  : No Reading
16616789: SW   : State 1.00
16616792: EVENT: PIR#State=1.00
16616858: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16616866: Command: publish
16616870: ACT  : event, Bewegung_on
16616877: Command: event
16616878: EVENT:  Bewegung_on
16616931: ACT  :
16617738: DHT  : Temperature: 19.00
16617739: DHT  : Humidity: 54.00
16617742: EVENT: Flur#Temperature=19.00
16617790: EVENT: Flur#Humidity=54.00
16617877: SW   : State 1.00
16617881: EVENT: PIR#State=1.00
16617923: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16617931: Command: publish
16617935: ACT  : event, Bewegung_on
16617943: Command: event
16617944: EVENT:  Bewegung_on
16617996: ACT  :
16618734: DHT  : No Reading
16618855: EVENT:  Bewegung_on
16618904: ACT  :
16619738: DHT  : Temperature: 19.00
16619738: DHT  : Humidity: 54.00
16619741: EVENT: Flur#Temperature=19.00
16619788: EVENT: Flur#Humidity=54.00
16619876: SW   : State 1.00
16619879: EVENT: PIR#State=1.00
16619923: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16619932: Command: publish
16619936: ACT  : event, Bewegung_on
16619943: Command: event
16619944: EVENT:  Bewegung_on
16619995: ACT  :
16620734: DHT  : No Reading
16620789: SW   : State 1.00
16620792: EVENT: PIR#State=1.00
16620836: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16620844: Command: publish
16620848: ACT  : event, Bewegung_on
16620855: Command: event
16620856: EVENT:  Bewegung_on
16620905: ACT  :
16621738: DHT  : Temperature: 19.00
16621738: DHT  : Humidity: 54.00
16621742: EVENT: Flur#Temperature=19.00
16621789: EVENT: Flur#Humidity=54.00
16621876: SW   : State 1.00
16621879: EVENT: PIR#State=1.00
16621922: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16621931: Command: publish
16621935: ACT  : event, Bewegung_on
16621942: Command: event
16621943: EVENT:  Bewegung_on
16621995: ACT  :
16622228: WD   : Uptime 277 ConnectFailures 0 FreeMem 16984 WiFiStatus 3
16622734: DHT  : No Reading
16622790: SW   : State 1.00
16622793: EVENT: PIR#State=1.00
16622835: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16622844: Command: publish
16622847: ACT  : event, Bewegung_on
16622855: Command: event
16622855: EVENT:  Bewegung_on
16622906: ACT  :
16623738: DHT  : Temperature: 19.00
16623738: DHT  : Humidity: 54.00
16623741: EVENT: Flur#Temperature=19.00
16623789: EVENT: Flur#Humidity=54.00
16623964: Command: publish
16623968: ACT  : event, Bewegung_on
16623975: Command: event
16623976: EVENT:  Bewegung_on
16624030: ACT  :
16624734: DHT  : No Reading
16624789: SW   : State 1.00
16624792: EVENT: PIR#State=1.00
16624836: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16624845: Command: publish
16624849: ACT  : event, Bewegung_on
16624856: Command: event
16624857: EVENT:  Bewegung_on
16624905: ACT  :
16625738: DHT  : Temperature: 19.00
16625738: DHT  : Humidity: 54.00
16625741: EVENT: Flur#Temperature=19.00
16625788: EVENT: Flur#Humidity=54.00
16625876: SW   : State 1.00
16625879: EVENT: PIR#State=1.00
16625922: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16625931: Command: publish
16625935: ACT  : event, Bewegung_on
16625943: Command: event
16625944: EVENT:  Bewegung_on
16625995: ACT  :
16626734: DHT  : No Reading
16626789: SW   : State 1.00
16626792: EVENT: PIR#State=1.00
16626834: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16626843: Command: publish
16626847: ACT  : event, Bewegung_on
16626854: Command: event
16626855: EVENT:  Bewegung_on
16626906: ACT  :
16627738: DHT  : Temperature: 19.00
16627738: DHT  : Humidity: 54.00
16627741: EVENT: Flur#Temperature=19.00
16627789: EVENT: Flur#Humidity=54.00
16627875: SW   : State 1.00
16627879: EVENT: PIR#State=1.00
16627923: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16627931: Command: publish
16627935: ACT  : event, Bewegung_on
16627943: Command: event
16627943: EVENT:  Bewegung_on
16627994: ACT  :
16628734: DHT  : No Reading
16628791: SW   : State 1.00
16628794: EVENT: PIR#State=1.00
16628838: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16628846: Command: publish
16628850: ACT  : event, Bewegung_on
16628857: Command: event
16628858: EVENT:  Bewegung_on
16628909: ACT  :
16629738: DHT  : Temperature: 19.00
16629738: DHT  : Humidity: 54.00
16629741: EVENT: Flur#Temperature=19.00
16629964: Command: publish
16629969: ACT  : event, Bewegung_on
16629976: Command: event
16629977: EVENT:  Bewegung_on
16630035: ACT  :
16630734: DHT  : No Reading
16630789: SW   : State 1.00
16630792: EVENT: PIR#State=1.00
16630834: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16630843: Command: publish
16630846: ACT  : event, Bewegung_on
16630856: Command: event
16630857: EVENT:  Bewegung_on
16630906: ACT  :
16631738: DHT  : Temperature: 19.00
16631738: DHT  : Humidity: 54.00
16631741: EVENT: Flur#Temperature=19.00
16631790: EVENT: Flur#Humidity=54.00
16631877: SW   : State 1.00
16631880: EVENT: PIR#State=1.00
16631923: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16631931: Command: publish
16631935: ACT  : event, Bewegung_on
16631942: Command: event
16631943: EVENT:  Bewegung_on
16631994: ACT  :
16632836: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16632845: Command: publish
16632848: ACT  : event, Bewegung_on
16632856: Command: event
16632857: EVENT:  Bewegung_on
16632908: ACT  :
16633250: SW  : GPIO=12 State=0 Output value=0
16633253: EVENT: PIR#State=0.00
16633303: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16633313: Command: publish
16633317: ACT  : event, Bewegung_off
16633324: Command: event
16633325: EVENT:  Bewegung_off
16633374: ACT  :
16633738: DHT  : Humidity: 54.00
16633741: EVENT: Flur#Temperature=19.00
16633789: EVENT: Flur#Humidity=54.00
16633882: SW   : State 0.00
16633886: EVENT: PIR#State=0.00
16633938: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16633947: Command: publish
16633951: ACT  : event, Bewegung_off
16633958: Command: event
16633959: EVENT:  Bewegung_off
16634010: ACT  :
16634734: DHT  : No Reading
16634789: SW   : State 0.00
16634792: EVENT: PIR#State=0.00
16634896: EVENT:  Bewegung_off
16634946: ACT  :
16635738: DHT  : Temperature: 19.00
16635739: DHT  : Humidity: 54.00
16635742: EVENT: Flur#Temperature=19.00
16635790: EVENT: Flur#Humidity=54.00
16635878: SW   : State 0.00
16635881: EVENT: PIR#State=0.00
16635932: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16635941: Command: publish
16635944: ACT  : event, Bewegung_off
16635952: Command: event
16635952: EVENT:  Bewegung_off
16636005: ACT  :
16636734: DHT  : No Reading
16636789: SW   : State 0.00
16636792: EVENT: PIR#State=0.00
16636842: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16636851: Command: publish
16636854: ACT  : event, Bewegung_off
16636862: Command: event
16636862: EVENT:  Bewegung_off
16636914: ACT  :
16637738: DHT  : Temperature: 19.00
16637738: DHT  : Humidity: 54.00
16637742: EVENT: Flur#Temperature=19.00
16637788: EVENT: Flur#Humidity=54.00
16637876: SW   : State 0.00
16637879: EVENT: PIR#State=0.00
16637931: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16637940: Command: publish
16637944: ACT  : event, Bewegung_off
16637951: Command: event
16637952: EVENT:  Bewegung_off
16638002: ACT  :
16638734: DHT  : No Reading
16638789: SW   : State 0.00
16638792: EVENT: PIR#State=0.00
16638842: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16638852: Command: publish
16638856: ACT  : event, Bewegung_off
16638863: Command: event
16638864: EVENT:  Bewegung_off
16638913: ACT  :
16639746: DHT  : Temperature: 19.00
16639746: DHT  : Humidity: 54.00
16639749: EVENT: Flur#Temperature=19.00
16639798: EVENT: Flur#Humidity=54.00
16639885: SW   : State 0.00
16639888: EVENT: PIR#State=0.00
16639939: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16639948: Command: publish
16639952: ACT  : event, Bewegung_off
16639959: Command: event
16639960: EVENT:  Bewegung_off
16640013: ACT  :
16640734: DHT  : No Reading
16640791: SW   : State 0.00
16640794: EVENT: PIR#State=0.00
16640844: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16640852: Command: publish
16640856: ACT  : event, Bewegung_off
16640863: Command: event
16640864: EVENT:  Bewegung_off
16640915: ACT  :
16641738: DHT  : Temperature: 19.00
16641738: DHT  : Humidity: 54.00
16641741: EVENT: Flur#Temperature=19.00
16641788: EVENT: Flur#Humidity=54.00
16641876: SW   : State 0.00
16641879: EVENT: PIR#State=0.00
16641930: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16641938: Command: publish
16641942: ACT  : event, Bewegung_off
16641949: Command: event
16641950: EVENT:  Bewegung_off
16642001: ACT  :
16642734: DHT  : No Reading
16642789: SW   : State 0.00
16642792: EVENT: PIR#State=0.00
16642843: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16642852: Command: publish
16642858: ACT  : event, Bewegung_off
16642867: Command: event
16642868: EVENT:  Bewegung_off
16642947: ACT  :
16643738: DHT  : Temperature: 19.00
16643738: DHT  : Humidity: 54.00
16643741: EVENT: Flur#Temperature=19.00
16643790: EVENT: Flur#Humidity=54.00
16643878: SW   : State 0.00
16643881: EVENT: PIR#State=0.00
16643932: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16643940: Command: publish
16643944: ACT  : event, Bewegung_off
16643951: Command: event
16643952: EVENT:  Bewegung_off
16644005: ACT  :
16644735: DHT  : No Reading
16644863: Command: event
16644864: EVENT:  Bewegung_off
16644916: ACT  :
16645738: DHT  : Temperature: 20.00
16645738: DHT  : Humidity: 54.00
16645741: EVENT: Flur#Temperature=20.00
16645788: EVENT: Flur#Humidity=54.00
16645877: SW   : State 0.00
16645880: EVENT: PIR#State=0.00
16645932: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16645941: Command: publish
16645945: ACT  : event, Bewegung_off
16645952: Command: event
16645953: EVENT:  Bewegung_off
16646038: ACT  :
16646734: DHT  : No Reading
16646789: SW   : State 0.00
16646792: EVENT: PIR#State=0.00
16647076: EVENT:  Bewegung_on
16647129: ACT  :
16647738: DHT  : Temperature: 19.00
16647738: DHT  : Humidity: 54.00
16647741: EVENT: Flur#Temperature=19.00
16647789: EVENT: Flur#Humidity=54.00
16647877: SW   : State 1.00
16647880: EVENT: PIR#State=1.00
16647923: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16647932: Command: publish
16647936: ACT  : event, Bewegung_on
16647943: Command: event
16647944: EVENT:  Bewegung_on
16647996: ACT  :
16648734: DHT  : No Reading
16648789: SW   : State 1.00
16648792: EVENT: PIR#State=1.00
16648835: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16648843: Command: publish
16648847: ACT  : event, Bewegung_on
16648854: Command: event
16648855: EVENT:  Bewegung_on
16648907: ACT  :
16649738: DHT  : Temperature: 19.00
16649738: DHT  : Humidity: 54.00
16649741: EVENT: Flur#Temperature=19.00
16649787: EVENT: Flur#Humidity=54.00
16649876: SW   : State 1.00
16649879: EVENT: PIR#State=1.00
16649924: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16649933: Command: publish
16649937: ACT  : event, Bewegung_on
16649944: Command: event
16649945: EVENT:  Bewegung_on
16649995: ACT  :
16650734: DHT  : No Reading
16650789: SW   : State 1.00
16650792: EVENT: PIR#State=1.00
16650834: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16650843: Command: publish
16650847: ACT  : event, Bewegung_on
16650854: Command: event
16650855: EVENT:  Bewegung_on
16650936: ACT  :
16651738: DHT  : Temperature: 20.00
16651738: DHT  : Humidity: 54.00
16651741: EVENT: Flur#Temperature=20.00
16651789: EVENT: Flur#Humidity=54.00
16651876: SW   : State 1.00
16651879: EVENT: PIR#State=1.00
16651922: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16651931: Command: publish
16651935: ACT  : event, Bewegung_on
16651942: Command: event
16651943: EVENT:  Bewegung_on
16651996: ACT  :
16652229: WD   : Uptime 278 ConnectFailures 0 FreeMem 16984 WiFiStatus 3
16652734: DHT  : No Reading
16652789: SW   : State 1.00
16652792: EVENT: PIR#State=1.00
16652834: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16652842: Command: publish
16652846: ACT  : event, Bewegung_on
16652854: Command: event
16652854: EVENT:  Bewegung_on
16652905: ACT  :
16653738: DHT  : Temperature: 19.00
16653738: DHT  : Humidity: 54.00
16653741: EVENT: Flur#Temperature=19.00
16653788: EVENT: Flur#Humidity=54.00
16653876: SW   : State 1.00
16653879: EVENT: PIR#State=1.00
16653923: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16653932: Command: publish
16653936: ACT  : event, Bewegung_on
16653943: Command: event
16653944: EVENT:  Bewegung_on
16653994: ACT  :
16654735: DHT  : No Reading
16654789: SW   : State 1.00
16654792: EVENT: PIR#State=1.00
16654836: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16654844: Command: publish
16654848: ACT  : event, Bewegung_on
16654855: Command: event
16654856: EVENT:  Bewegung_on
16654905: ACT  :
16655738: DHT  : Temperature: 19.00
16655738: DHT  : Humidity: 54.00
16655741: EVENT: Flur#Temperature=19.00
16655788: EVENT: Flur#Humidity=54.00
16655875: SW   : State 1.00
16655878: EVENT: PIR#State=1.00
16655921: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16655930: Command: publish
16655934: ACT  : event, Bewegung_on
16655941: Command: event
16655942: EVENT:  Bewegung_on
16655995: ACT  :
16656734: DHT  : No Reading
16656789: SW   : State 1.00
16656792: EVENT: PIR#State=1.00
16656835: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16656843: Command: publish
16656847: ACT  : event, Bewegung_on
16656854: Command: event
16656855: EVENT:  Bewegung_on
16656906: ACT  :
16657738: DHT  : Temperature: 19.00
16657738: DHT  : Humidity: 54.00
16657741: EVENT: Flur#Temperature=19.00
16657789: EVENT: Flur#Humidity=54.00
16657876: SW   : State 1.00
16657880: EVENT: PIR#State=1.00
16657924: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16657933: Command: publish
16657937: ACT  : event, Bewegung_on
16657944: Command: event
16657945: EVENT:  Bewegung_on
16657997: ACT  :
16658734: DHT  : No Reading
16658789: SW   : State 1.00
16658792: EVENT: PIR#State=1.00
16658836: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16658845: Command: publish
16658848: ACT  : event, Bewegung_on
16658856: Command: event
16658857: EVENT:  Bewegung_on
16658906: ACT  :
16659738: DHT  : Humidity: 54.00
16659741: EVENT: Flur#Temperature=19.00
16659788: EVENT: Flur#Humidity=54.00
16659876: SW   : State 1.00
16659879: EVENT: PIR#State=1.00
16659921: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16659930: Command: publish
16659936: ACT  : event, Bewegung_on
16659943: Command: event
16659944: EVENT:  Bewegung_on
16659994: ACT  :
16660734: DHT  : No Reading
16660791: SW   : State 1.00
16660795: EVENT: PIR#State=1.00
16660887: EVENT:  Bewegung_on
16660938: ACT  :
16661738: DHT  : Temperature: 20.00
16661739: DHT  : Humidity: 54.00
16661742: EVENT: Flur#Temperature=20.00
16661790: EVENT: Flur#Humidity=54.00
16661876: SW   : State 1.00
16661879: EVENT: PIR#State=1.00
16661924: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16661932: Command: publish
16661936: ACT  : event, Bewegung_on
16661943: Command: event
16661944: EVENT:  Bewegung_on
16661997: ACT  :
16662734: DHT  : No Reading
16662789: SW   : State 1.00
16662792: EVENT: PIR#State=1.00
16662836: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16662844: Command: publish
16662848: ACT  : event, Bewegung_on
16662855: Command: event
16662856: EVENT:  Bewegung_on
16662907: ACT  :
16663738: DHT  : Temperature: 19.00
16663738: DHT  : Humidity: 54.00
16663741: EVENT: Flur#Temperature=19.00
16663788: EVENT: Flur#Humidity=54.00
16663874: SW   : State 1.00
16663877: EVENT: PIR#State=1.00
16663919: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16663928: Command: publish
16663932: ACT  : event, Bewegung_on
16663939: Command: event
16663940: EVENT:  Bewegung_on
16663991: ACT  :
16664734: DHT  : No Reading
16664789: SW   : State 1.00
16664792: EVENT: PIR#State=1.00
16664834: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16664843: Command: publish
16664846: ACT  : event, Bewegung_on
16664855: Command: event
16664856: EVENT:  Bewegung_on
16664905: ACT  :
16665738: DHT  : Temperature: 20.00
16665738: DHT  : Humidity: 54.00
16665741: EVENT: Flur#Temperature=20.00
16665789: EVENT: Flur#Humidity=54.00
16665876: SW   : State 1.00
16665880: EVENT: PIR#State=1.00
16665923: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16665931: Command: publish
16665935: ACT  : event, Bewegung_on
16665942: Command: event
16665943: EVENT:  Bewegung_on
16665996: ACT  :
16666734: DHT  : No Reading
16666791: SW   : State 1.00
16666796: EVENT: PIR#State=1.00
16666839: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16666847: Command: publish
16666851: ACT  : event, Bewegung_on
16666858: Command: event
16666859: EVENT:  Bewegung_on
16666910: ACT  :
16667738: DHT  : Temperature: 19.00
16667738: DHT  : Humidity: 54.00
16667741: EVENT: Flur#Temperature=19.00
16667788: EVENT: Flur#Humidity=54.00
16667967: Command: publish
16667971: ACT  : event, Bewegung_on
16667978: Command: event
16667979: EVENT:  Bewegung_on
16668037: ACT  :
16668736: DHT  : No Reading
16668789: SW   : State 1.00
16668792: EVENT: PIR#State=1.00
16668834: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16668843: Command: publish
16668848: ACT  : event, Bewegung_on
16668856: Command: event
16668856: EVENT:  Bewegung_on
16668905: ACT  :
16669738: DHT  : Temperature: 19.00
16669738: DHT  : Humidity: 54.00
16669741: EVENT: Flur#Temperature=19.00
16669790: EVENT: Flur#Humidity=54.00
16669877: SW   : State 1.00
16669880: EVENT: PIR#State=1.00
16669923: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16669932: Command: publish
16669936: ACT  : event, Bewegung_on
16669943: Command: event
16669944: EVENT:  Bewegung_on
16669996: ACT  :
16670734: DHT  : No Reading
16670790: SW   : State 1.00
16670793: EVENT: PIR#State=1.00
16670835: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16670844: Command: publish
16670848: ACT  : event, Bewegung_on
16670855: Command: event
16670856: EVENT:  Bewegung_on
16670907: ACT  :
16671738: DHT  : Temperature: 19.00
16671738: DHT  : Humidity: 54.00
16671741: EVENT: Flur#Temperature=19.00
16671788: EVENT: Flur#Humidity=54.00
16671876: SW   : State 1.00
16671879: EVENT: PIR#State=1.00
16671923: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16671932: Command: publish
16671936: ACT  : event, Bewegung_on
16671943: Command: event
16671944: EVENT:  Bewegung_on
16671995: ACT  :
16673524: Command: event
16673525: EVENT:  Bewegung_off
16673576: ACT  :
16673738: DHT  : Temperature: 20.00
16673738: DHT  : Humidity: 54.00
16673741: EVENT: Flur#Temperature=20.00
16673791: EVENT: Flur#Humidity=54.00
16673879: SW   : State 0.00
16673882: EVENT: PIR#State=0.00
16673933: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16673942: Command: publish
16673946: ACT  : event, Bewegung_off
16673956: Command: event
16673957: EVENT:  Bewegung_off
16674042: ACT  :
16674734: DHT  : No Reading
16674789: SW   : State 0.00
16674793: EVENT: PIR#State=0.00
16674842: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16674851: Command: publish
16674855: ACT  : event, Bewegung_off
16674862: Command: event
16674863: EVENT:  Bewegung_off
16674914: ACT  :
16675738: DHT  : Temperature: 19.00
16675738: DHT  : Humidity: 54.00
16675741: EVENT: Flur#Temperature=19.00
16675787: EVENT: Flur#Humidity=54.00
16675875: SW   : State 0.00
16675879: EVENT: PIR#State=0.00
16675930: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16675938: Command: publish
16675942: ACT  : event, Bewegung_off
16675950: Command: event
16675950: EVENT:  Bewegung_off
16676001: ACT  :
16676734: DHT  : No Reading
16676791: SW   : State 0.00
16676794: EVENT: PIR#State=0.00
16676844: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16676853: Command: publish
16676857: ACT  : event, Bewegung_off
16676864: Command: event
16676865: EVENT:  Bewegung_off
16676914: ACT  :
16677738: DHT  : Temperature: 19.00
16677738: DHT  : Humidity: 54.00
16677741: EVENT: Flur#Temperature=19.00
16677789: EVENT: Flur#Humidity=54.00
16677876: SW   : State 0.00
16677879: EVENT: PIR#State=0.00
16677930: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16677938: Command: publish
16677942: ACT  : event, Bewegung_off
16677949: Command: event
16677950: EVENT:  Bewegung_off
16678003: ACT  :
16678734: DHT  : No Reading
16678789: SW   : State 0.00
16678792: EVENT: PIR#State=0.00
16678846: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,0
16678855: Command: publish
16678859: ACT  : event, Bewegung_off
16678866: Command: event
16678867: EVENT:  Bewegung_off
16678916: ACT  :
16679738: DHT  : Temperature: 19.00
16679738: DHT  : Humidity: 54.00
16679741: EVENT: Flur#Temperature=19.00
16679787: EVENT: Flur#Humidity=54.00
16680306: Command: publish
16680310: ACT  : event, Bewegung_on
16680320: Command: event
16680321: EVENT:  Bewegung_on
16680372: ACT  :
16680734: DHT  : No Reading
16680789: SW   : State 1.00
16680793: EVENT: PIR#State=1.00
16680835: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16680844: Command: publish
16680848: ACT  : event, Bewegung_on
16680855: Command: event
16680856: EVENT:  Bewegung_on
16680905: ACT  :
16681738: DHT  : Temperature: 19.00
16681738: DHT  : Humidity: 54.00
16681741: EVENT: Flur#Temperature=19.00
16681789: EVENT: Flur#Humidity=54.00
16681877: SW   : State 1.00
16681880: EVENT: PIR#State=1.00
16681923: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16681931: Command: publish
16681935: ACT  : event, Bewegung_on
16681942: Command: event
16681943: EVENT:  Bewegung_on
16681996: ACT  :
16682228: WD   : Uptime 278 ConnectFailures 0 FreeMem 15416 WiFiStatus 3
16682859: Command: event
16682860: EVENT:  Bewegung_on
16682912: ACT  :
16683738: DHT  : Temperature: 19.00
16683738: DHT  : Humidity: 54.00
16683741: EVENT: Flur#Temperature=19.00
16683788: EVENT: Flur#Humidity=54.00
16683877: SW   : State 1.00
16683880: EVENT: PIR#State=1.00
16683925: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16683933: Command: publish
16683937: ACT  : event, Bewegung_on
16683944: Command: event
16683945: EVENT:  Bewegung_on
16684032: ACT  :
16684734: DHT  : No Reading
16684789: SW   : State 1.00
16684792: EVENT: PIR#State=1.00
16684836: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16684844: Command: publish
16684848: ACT  : event, Bewegung_on
16684855: Command: event
16684856: EVENT:  Bewegung_on
16684938: ACT  :
16685939: Command: publish
16685943: ACT  : event, Bewegung_on
16685952: Command: event
16685952: EVENT:  Bewegung_on
16686004: ACT  :
16686734: DHT  : No Reading
16686789: SW   : State 1.00
16686792: EVENT: PIR#State=1.00
16686834: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16686843: Command: publish
16686847: ACT  : event, Bewegung_on
16686854: Command: event
16686855: EVENT:  Bewegung_on
16686906: ACT  :
16687738: DHT  : Temperature: 19.00
16687738: DHT  : Humidity: 54.00
16687741: EVENT: Flur#Temperature=19.00
16687810: EVENT: Flur#Humidity=54.00
16687898: SW   : State 1.00
16687902: EVENT: PIR#State=1.00
16687946: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16687954: Command: publish
16687958: ACT  : event, Bewegung_on
16687965: Command: event
16687966: EVENT:  Bewegung_on
16688025: ACT  :
16688734: DHT  : No Reading
16688789: SW   : State 1.00
16688792: EVENT: PIR#State=1.00
16688836: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16688844: Command: publish
16688848: ACT  : event, Bewegung_on
16688856: Command: event
16688856: EVENT:  Bewegung_on
16688905: ACT  :
16689738: DHT  : Temperature: 19.00
16689738: DHT  : Humidity: 54.00
16689742: EVENT: Flur#Temperature=19.00
16689788: EVENT: Flur#Humidity=54.00
16689877: SW   : State 1.00
16689880: EVENT: PIR#State=1.00
16689955: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16689963: Command: publish
16689967: ACT  : event, Bewegung_on
16689974: Command: event
16689975: EVENT:  Bewegung_on
16690026: ACT  :
16690734: DHT  : No Reading
16690789: SW   : State 1.00
16690792: EVENT: PIR#State=1.00
16690834: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16690843: Command: publish
16690846: ACT  : event, Bewegung_on
16690854: Command: event
16690855: EVENT:  Bewegung_on
16690906: ACT  :
16691738: DHT  : Temperature: 19.00
16691738: DHT  : Humidity: 54.00
16691741: EVENT: Flur#Temperature=19.00
16691789: EVENT: Flur#Humidity=54.00
16691900: SW   : State 1.00
16691903: EVENT: PIR#State=1.00
16691947: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16691955: Command: publish
16691959: ACT  : event, Bewegung_on
16691966: Command: event
16691967: EVENT:  Bewegung_on
16692021: ACT  :
16692734: DHT  : No Reading
16692789: SW   : State 1.00
16692792: EVENT: PIR#State=1.00
16692836: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16692844: Command: publish
16692848: ACT  : event, Bewegung_on
16692855: Command: event
16692856: EVENT:  Bewegung_on
16692905: ACT  :
16693741: DHT  : Temperature: 20.00
16693741: DHT  : Humidity: 54.00
16693744: EVENT: Flur#Temperature=20.00
16693792: EVENT: Flur#Humidity=54.00
16693880: SW   : State 1.00
16693884: EVENT: PIR#State=1.00
16693958: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16693967: Command: publish
16693971: ACT  : event, Bewegung_on
16693978: Command: event
16693979: EVENT:  Bewegung_on
16694030: ACT  :
16694734: DHT  : No Reading
16694789: SW   : State 1.00
16694792: EVENT: PIR#State=1.00
16694835: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16694843: Command: publish
16694847: ACT  : event, Bewegung_on
16694856: Command: event
16694857: EVENT:  Bewegung_on
16694906: ACT  :
16695738: DHT  : Temperature: 19.00
16695738: DHT  : Humidity: 54.00
16695741: EVENT: Flur#Temperature=19.00
16695789: EVENT: Flur#Humidity=54.00
16697932: Command: publish
16697936: ACT  : event, Bewegung_on
16697943: Command: event
16697944: EVENT:  Bewegung_on
16697994: ACT  :
16698734: DHT  : No Reading
16698789: SW   : State 1.00
16698792: EVENT: PIR#State=1.00
16698834: ACT  : Publish Bewegungsmelder_Flur/PIR/GPIO 12,1
16698843: Command: publish
16698848: ACT  : event, Bewegung_on
16698856: Command: event
16698856: EVENT:  Bewegung_on
16698906: ACT  :
Any ideas?
#5 Post by ThomasB » 10 Mar 2019, 21:08
Good, ESPEasy is working.
I don't have any experience with your MQTT broker. However, I see something unusual in your broker's screenshot. The PIR/GPIO topic is missing. It needs to be defined for the broker to receive it.
Masterg4941
#6 Post by Masterg4941 » 11 Mar 2019, 20:47
OK there were some troubles with the mqtt servers.
I had the Sonoff mqtt server and the MQTT Server installed... both on the same port.
Now the MQTT is running on port 1886 and everthing is allright. The published elements are visible now :)
Thanks for the help!
#7 Post by ThomasB » 11 Mar 2019, 21:29
Glad to hear you solved it.
