Using curl/http to read a value of a ds18b20
hvdwolf
#1 Post by hvdwolf » 20 Jan 2020, 16:16
I have a ds18b20 on my Nodemcu on GPIO pin 2 to read the temperature and a relais on pin 15 to switch the heating on/off. The Esp Easy "website" simply shows me the right temperature.
I want to read/set the values from my linux server as well.
For reading the status of the on/off GPIO pin 2, I simply use something like:
curl --silent --data 'cmd=status,gpio,15' http://192.168.178.241/control | grep state | awk {'print $2'}
for setting to On/high I use:
curl --silent --data 'cmd=gpio,15,1' http://192.168.178.241/control
and for setting it to Off/Low I use:
curl --silent --data 'cmd=gpio,15,0' http://192.168.178.241/control
But how do I read the value of the temperature of my ds18b20?
If I use the same command
curl --silent --data 'cmd=status,gpio,2' http://192.168.178.241/control
on the GPIO pin 2 where my ds18b20 is connected I get something like:
"log": "",
"plugin": 1,
"pin": 2,
"mode": "output",
"state": 0
I can't find it in the cmd (command reference) wiki page.
Re: Using curl/http to read a value of a ds18b20
#2 Post by grovkillen » 20 Jan 2020, 16:24
Use the json endpoint?
hvdwolf
#3 Post by hvdwolf » 20 Jan 2020, 19:58
grovkillen wrote: 20 Jan 2020, 16:24 Use the json endpoint?
Thanks for pointing me to the json endpoint. I searched in the forum and found references to javascript code, but I can't completely reproduce it for curl/script use.
Using curl I do
curl --silent  http://192.168.178.246/json
{"System":{
"Build": 147,
"Unit": 0,
"Uptime": 29005,
"Free RAM": 26472
"Sensors":[
"TaskName": "woonkamertemperatuur",
"woonkamertemperatuur": 20.37
"TaskName": "Uptime",
"woonkamer-uptime": 29005.00
This gives me the complete json array back which I can parse using search and substring functions.
But is there a way to immediately access the temperature (in this case 20.37).
Like said: Trying options like the javascript examples doesn't give me the value.
#4 Post by grovkillen » 20 Jan 2020, 21:35
http://192.168.178.246/json?tasknr=1
Will filter the json.
See more URL filters here: https://github.com/letscontrolit/ESPEas ... ON.ino#L12
PS. By the looks of your json string it seems to me you're running an old version?
hvdwolf
#5 Post by hvdwolf » 20 Jan 2020, 22:49
Thanks a lot.
Yes, I'm still running the r147 version with a minor patch of my own.
Those nodemcus with this version are so extremely stable that I never upgraded. I have 3 of them which keep on running without issues.
But I will now take a look at the new versions as I now wanted to change some things in my config.
#6 Post by grovkillen » 20 Jan 2020, 22:58
The latest are really stable but be aware the that the config isn't compatible with the R147 version so make sure you take the settings some other way (screenshots or notes).
