Now I haven't fully diagnosed this problem yet, but I have been having problems with sending data from a Wemos D1 mini to a local EMONcms server. The problem occurs on recent versions (ESP_Easy_mega_20201022_test_ESP8266_4M1M_VCC), but not older ones (ESP_Easy_mega-20191208_test_ESP8266_4M1M_VCC.bin).
(EMONcms controller does work)
Web Log Level: Debug Dev 9
92581964: SHT3x: Temperature: 22.11
92581964: SHT3x: Humidity: 58.32
92582171: HTTP : C007 Success! HTTP/1.1 200 OK^
92582685: WD : Uptime 1543 ConnectFailures 0 FreeMem 16312 WiFiStatus 3
92612685: WD : Uptime 1544 ConnectFailures 0 FreeMem 16296 WiFiStatus 3
(EMONcms controller does NOT work)
Web Log Level: Debug More
Check Reply: Check Acknowledgement
Log File
734594: SHT3x: Temperature: 21.84
734595: SHT3x: Humidity: 57.76
738453: WD : Uptime 12 ConnectFailures 0 FreeMem 20184 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
768453: WD : Uptime 13 ConnectFailures 0 FreeMem 20184 WiFiStatus WL_CONNECTED ESPeasy
In the ESP_Easy_mega_20201022_test_ESP8266_4M1M_VCC version log file there is never any mention of sending to EMONcms server or any failed acknowledgement.
Issues with EMONcms - recent builds only - logs not showing error
Re: Issues with EMONcms - recent builds only - logs not showing error
In "test" and "dev" builds, a lot of the debug level logs are excluded to make room to fit the binary on the flash.
Is it only the logs you're missing, or is it also a functional change?
I have exactly the same problem.
In recent build, also normal version, the data is not sent to the emoncms server. Rolling back to the ESP_Easy_mega_20200516_normal_ESP8266_4M1M version, everything resumes normal operation.
I don't know if this is the last working version.
There are no indications of errors in the log.
Ciao
Angelo
Ciao
Angelo
Is it related to this issue I fixed yesterday? https://github.com/letscontrolit/ESPEasy/issues/3377
If so, then I guess it is (very likely) also included in this test build I made for another PR:
https://www.dropbox.com/s/k9qndp6i7eoz2 ... 8.zip?dl=0
https://www.dropbox.com/s/ure33a179tg8b ... 8.zip?dl=0
Yes,
I've loaded the Release mega-20201125 and now everything work!
Thank you very much.
Ciao
Angelo
Ciao
Angelo
Thanks for getting back to report it is now working
