I have a single controller entered - MQTT and I am monitoring the domoticz/in topic. All values in the controller are default apart from IP of controller. Board is Wemos D1 mini.
Device interval is set to 0.
When it wakes from deep sleep I get 2 messages sent of the current device state(s).
Is there a way to reduce this to a single message on wake up?
G
Values are sent twice after deep sleep
Re: Values are sent twice after deep sleep
Can you give an example of the MQTT messages sent?
Also, what task/plugin is sending the values?
Here is an example output from node red with just ADC device enabled :
04/02/2021, 14:56:01node: 9a9d8fa6.08821
domoticz/in : msg.payload : Object
object
idx: 501
RSSI: 10
nvalue: 0
svalue: "4.78"
04/02/2021, 14:56:02node: 9a9d8fa6.08821
object
idx: 501
RSSI: 8
nvalue: 0
svalue: "4.78"
If I disable the ADC device, and add a switch in its place the result is the same - I get it twice.
04/02/2021, 15:05:58node: 9a9d8fa6.08821
object
idx: 500
RSSI: 10
command: "switchlight"
switchcmd: "Off"
object
idx: 500
RSSI: 8
switchcmd: "Off"
object
idx: 501
RSSI: 10
nvalue: 0
svalue: "4.78"
object
idx: 501
RSSI: 8
nvalue: 0
svalue: "4.78"
object
idx: 500
RSSI: 10
switchcmd: "Off"
object
idx: 500
RSSI: 8
switchcmd: "Off"
What version of ESPEasy are you using (name of the .bin file please)?
Sorry, Am using ESP_Easy_mega_20210114_normal_ESP8266_4M1M.bin
I have just tried removing domoticz/out from controller subscribe but leaving the controller publish value (domoticz/in) alone.
With this setup I get no messages at all being published to domoticz/in.
I have verified that 2 messages are sent using MQTT explorer.
I'm also getting the 2 messages from a cold boot.
Anything else I could try? An older version maybe?
I have just tested with ESP_Easy_v2.0.0-dev13_normal_ESP8266_4096.bin
I can confirm that this version only sends 1 message on the publish topic at restart.
However for some reason it sends two messages on the subscription topic. First is "Connection Lost" and then "connected"
If the default domoticz/out is used I get lots of errors in node red as I have lots of nodes listening on that topic and they expect a something json formatted.
Is there any way to stop it publishing on the subscribe domoticz/out topic?
Also rules work for me on this version - they don't on latest mega.
Maybe there is a mega version that solves all the above issues?
