I bought two LOLIN D1 mini pro and two Wemos D1 mini pro and flashed this four pieces with easy esp software.
But after reboot of the ESP6228 I don’t get ESP_Easy_0.
I disable my AVG anti virus and firewall, but no results.
After several attemps can’t flash on.
Not even by putting the GIO0 pin of the esp6288 on the ground.
Earlier it was not an problem, but after upgrade AVG several months ago I get this problem.
Who can help me? Possible send it too you for flashing.
Jack
Can't flash esp6288
Re: Can't flash esp6288
When upgrading an existing ESPEasy device with the similarly configured (4M1M) .bin file you are *not supposed* to get the AP, it will be re-using the previously stored WiFi credentials to connect to the network, and unless the router was restarted, should probably get the same IP address.
And on these 4M flash-memory devices, you can also replace the firmware using the Tools page button Update Firmware, browse to the .bin (or .bin.gz) file.
On personal title:
Some advice on AVG: Uninstall it and trash any media you have lying around, Windows Defender will provide similar protection, without bothering you with all kinds of useless popups and scare-tactics to woo you into buying more of their useless stuff.
On personal title:
I can't replace the firmware using the Tools page button Update Firmware because my router didn't found the esp6288.
If you open the Monitor button from the ESP Easy Flasher (I assume you have used that to flash it) so you can see if it does respond at all.
The problems with flashing are solved!
1. Disable AVG Internet Security.
2. Connect the GIO0 of the esp6288 too ground.
3. Connect the esp6288 too an USB port of the PC
4. Start Tasmotizer 1.2, select the right com port .
5. Select the right easy esp bin file.
6. Select "Erase before flashing"
7. Select Tamotize!
Jack
7. Select Tamotize!
Jack
