ESPEasy Web flasher
Posted: 25 Jun 2023, 18:02
by RayPath
I used from time to time web flasher which url address is on
https://github.com/letscontrolit/ESPEasy
but when I try today:
https://td-er.nl/ESPEasy/
see on screen:
You don't have permission to access this resource.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
Re: ESPEasy Web flasher
Posted: 25 Jun 2023, 22:34
Can you send me your IP-address via a direct message?
I have disabled a few IP-ranges (quite a few) due to massive hack attempts.
Just to give some indication, I get about 3.3 TByte a month in incommig traffic which is blocked by these filters (so no outgoing traffic) for hack-attempts.
So at some point I may have added blocks of IP-addresses which may be a bit too course and I'm happy to remove yours from that block.
Posted: 06 Aug 2023, 13:53
by pich70
Hi!
I have the same as the guy above. Can I ask you for help?
Posted: 06 Aug 2023, 14:44
Can you try again?
Posted: 19 Jan 2024, 21:57
by ZokiPoki
I have the same problem when trying to access
I am getting:
Forbidden
Cannot send you a DM because i do not have rights.
My IP is dynamic but it should be in range of 77.28.0.0/16
Posted: 19 Jan 2024, 22:25
Can you retry?
Posted: 20 Jan 2024, 00:29
by ZokiPoki
TD-er wrote: ↑19 Jan 2024, 22:25Can you retry?
Working now.
Tnx
