command line input for serialsend to rflink
Posted: 18 Oct 2023, 22:18
Hello folkes,
I'm mutch further than the last time, but not there yet
It's fun to mess about with the tools, but I'm running to a problem with Esp Easy.
setup:
RFLINK 433.92 (v1.1.4f)
ARDUINO Mega software RFlink firmware version 1.48 on ard
ANTENNE
rflink Wifi bridge v.0.9.2
NodeMCU software Build: ESP_Easy_mega_20230822_normal_ESP8266_4M1M Aug 22 2023
It is now possible for me to read the 433mhz messages and send them to MQTT. Now the receiving part
I cannot send messages via the command line to serial. I think it's via serialsend, but the below options didn't work. Then, when I've got it working, I want to send the info from Home assistant -> MQTT -> Esp Easy -> RFlink -> 433 mhz
Can you maybe help me? It must be something stupid, but I couldn't find the answer on the forum nor wiki.
Reseived parameter via MQTT Explorer
The options that I've tried out:
and various above
Serial.println 20;TriState;0a828a;2;OFF;
and Serial.print 20;TriState;0a828a;2;OFF;
gives an error
Command unknown: Serial.println 20;TriState;0a828a;2;OFF;
Command unknown: Serial.print 20;TriState;0a828a;2;OFF;
I've got espRFLinkMQTT working alright, and I could execute messages from MQTT Explorer. Kudos for seb821. The software is still going strong! And was easy to install But I want to install also some other sensors on the Nodemcu instead of installing another one...
Might you know which ports are not in use please let me know (and make my live easier), than I dont need to figure that out
tnx for answering and kudos for the developers who made and maintaining this project!!!
greetings Alex
setup:
ANTENNE
domotica_veranda_2/switch = !Serial#20;01;TriState;ID=0a828a;SWITCH=0;CMD=ON;
domotica_veranda_2/switch = !Serial#20;02;AB400D;ID=59;SWITCH=3;CMD=OFF;
10;TriState;0a828a;2;OFF;
10;TriState;0a828a;0;ON;
serialsend 10;TriState;0a828a;2;OFF;
serialsend [10;TriState;0a828a;2;OFF;]
serialsend (10;TriState;0a828a;2;OFF;)
serialsend (10;TriState;0a828a;2;OFF;);
serialsend "10;TriState;0a828a;2;OFF;"
serialsend '10;TriState;0a828a;2;OFF;
gives an error
greetings Alex
