No wifi AP with custom build
Posted: 26 Oct 2023, 09:32
I start from the beginning with platformio:
1st, I erase flash and I follow instructions in Custom-sample.h:
But I dont have AP wifi availabke once ESP8266 starts. Did I miss something ?
Serial monitoring:
- 1) rename this file to "Custom.h" (It is ignored by Git)
2) define your own settings below : only define some plugin (USES_P001) and controller (USES_C008)
3) define USE_CUSTOM_H as a build flags. ie : export PLATFORMIO_BUILD_FLAGS="'-DUSE_CUSTOM_H'" => In Windows environment : set PLATFORMIO_BUILD_FLAGS="'-DUSE_CUSTOM_H'"
Serial monitoring:
INIT : Booting version: ESP_Easy_mega_20231026_custom_ESP8266_4M1M, (Self built) My Build: Oct 26 2023 09:03:32 (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
599 : Info : INIT : Free RAM:29400
600 : Info : INIT : Manual Reboot #14 - Restart Reason: External System
601 : Info : FS : Mounting...
627 : Info : FS : �osing ESPEasySerial
653 : Info : ESPEasy console using ESPEasySerial
654 : Info : INIT : I2C
655 : Info : INIT : SPI not enabled
655 : Info : Set Network mode: WiFi
760 : Info : WIFI : Set WiFi to STA
928 : Info : Setup: Scan all channels
3115 : Info : ESPEasy ��3118 : Info : ESPEasy console using ESPEasySerial
3119 : Info : INFO : Plugins: 2 [No Debug Log] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
5309 : Info : Webserver: start
6654 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 23528 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
36648 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 23528 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
