Ventilation System and garage door.
I see my garage door that Have a Rolling code as a keeloq.
Would this Be possible to pair??
And a ithi daalderop / buva Stork ventilation System is that compatible?
Re: Ventilation System and garage door.
I think I have the same ventilator. Don't know what frequency it is working on, but the remote control is very good.
Keeloq is using encrypted data. Without knowing the key (eg hacking the key out of the remote) we can not add pairing / transmission support.
Right now only reception of Keeloq is supported so you can for example turn on the garage lights when the door is opened with the original remote.
I thin kthe Daalderop/buva is using 868 mhz?
No way to implement it due to missing hardware for testing.
I have a BFT remote, but it shows up as Keeloq when I press the button on the remote. As far as I can see, BFT is supported since v38 in RFLink. Is the protocol of BFT updated to another standard or can one use/buy different types of remote controls for BFT garage door opener?
If it is recognized as Keeloq then you can receive but not transmit.
what do i need to be able to transmit?
to include the management of encrypted keys in the firmware on arduino?
sniffing the communication between the remote control and the garage door does not seem to send encrypted information, so the problem is only in the association between rflink and the bft controller as if it were a remote control? or I need dedicated hardware?
Leonardo
Leonardo
You would need the decryption keys which you can not sniff from the signal. You could only get that by hacking the original hardware
thank's
ok i studied some of keeloq protocol
if i found the secret code to use, i will must insert in rflink code or can i use via serial console to pair my garage door with rflink ?
RFlink needs to be adapted for it.
Contact me via mail.
ok thanks
i'll stay in touch
Leo
i'll stay in touch
Leo
Also having the same thing with garage door.
If you succeed could you please post how did you extract the key and how to use it after.
No, i had no time because work and family
I’ll try next mounth
Users browsing this forum: Google [Bot] and 45 guests
