i bought and received this package :
http://fr.aliexpress.com/item/Welcome-C ... Title=true
Seems to be Kerui brand inside.
Pairing the contact sensor to the siren works as sold.
Now, in Domoticz, i have 2 problems :
- the contact sensor is recognised with 4 different IDs : "Eurodomest" (most often), EV1527 (twice) and Chuango
- the siren doesn't work if i use the contact sensor as a switch in Domoticz to trigger it
Any idea how to solve this (the second problem is the most important) ?
Thank you.
Chinese Welcome Chime Alarm
Re: Chinese Welcome Chime Alarm
Yes, provide debug data for all buttons and I will make some modifications
Alright, in debug mode, i press all the button of the siren, entered the "Add detectors" and "Add remote controls" mode => nothing logged.
But it's a received so it's normal no ?
The contact sensor produces logs :
Each times it's open, it sends 2 times the command apparently. The siren catches the signal and rings.
No closing information (normal on cheap chinese sensors).
I copied and sent the command in the dedicated field but the siren didn't react.
Same ID each time in debug mode. But on Domoticz i can see different ID's sometimes (0008F4E0 "EV1527", 0000F4E0 "EV1527", 0070B1F1 "CHUANGO", 000F0B1F "Eurodomest").
Thank you.
20;23;DEBUG;Pulses=50;Pulses(uSec)=930,180,210,780,210,780,210,780,780,180,780,180,780,180,810,180,210,780,780,180,210,780,210,780,780,180,780,180,810,180,210,780,210,780,210,780,210,780,210,780,810,180,780,180,780,180,210,780,210,6990;
20;24;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;25;DEBUG;Pulses=36;Pulses(uSec)=360,180,210,780,780,180,210,780,210,780,780,180,780,180,780,180,210,780,210,780,210,780,210,780,210,780,780,180,780,180,780,180,210,780,210,6990;
20;26;DEBUG;Pulses=50;Pulses(uSec)=840,180,210,780,210,780,210,780,780,180,780,180,780,180,810,180,210,780,780,180,210,780,210,780,780,180,780,180,810,180,210,780,210,780,210,780,210,780,210,780,780,180,810,180,780,180,210,780,210,6990;
20;27;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;37;DEBUG;Pulses=50;Pulses(uSec)=900,180,210,780,210,780,210,780,780,180,780,180,780,180,810,180,210,780,780,180,210,780,210,780,780,180,780,180,810,180,210,780,210,780,210,780,210,780,210,780,810,180,780,180,780,180,210,780,210,6990;
20;38;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;39;DEBUG;Pulses=38;Pulses(uSec)=450,180,780,180,210,780,810,180,210,780,210,780,780,180,780,180,780,180,210,780,210,780,210,780,210,780,210,780,780,180,780,180,780,180,210,780,210,6990;
20;3A;DEBUG;Pulses=50;Pulses(uSec)=840,180,210,780,210,780,210,780,780,180,780,180,810,180,780,180,210,780,780,180,210,780,210,780,810,180,780,180,780,180,210,780,210,780,210,780,210,780,210,780,780,180,780,180,780,180,210,780,210,6990;
20;3B;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;55;DEBUG;Pulses=50;Pulses(uSec)=840,210,210,780,210,780,210,780,780,180,780,180,780,180,780,180,210,780,780,180,210,780,210,780,780,180,780,180,780,180,210,780,210,780,210,780,210,780,210,780,780,180,810,180,780,180,210,780,210,6990;
20;56;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;57;DEBUG;Pulses=33;Pulses(uSec)=870,150,240,780,210,780,810,180,810,180,810,60,330,780,210,780,210,780,210,780,210,780,810,180,810,180,810,180,210,720,240,1500,180;
20;58;DEBUG;Pulses=88;Pulses(uSec)=120,180,180,720,210,720,750,180,750,150,750,180,210,720,180,720,180,720,180,780,210,780,810,180,810,180,810,180,210,780,210,4560,840,900,390,420,870,390,870,180,210,780,210,780,210,780,810,180,810,180,810,180,810,180,210,780,810,180,210,780,210,780,810,180,810,180,810,180,210,780,210,780,210,780,210,780,210,780,780,180,780,180,780,180,210,780,210,6990;
20;59;DEBUG;Pulses=50;Pulses(uSec)=780,180,210,780,210,780,210,780,780,180,810,180,780,180,810,180,210,780,810,180,210,780,210,780,780,180,780,180,810,180,210,780,210,780,210,780,210,780,210,780,780,180,810,180,810,180,210,780,210,6990;
20;5A;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;7D;DEBUG;Pulses=50;Pulses(uSec)=840,210,210,780,210,780,210,780,780,180,780,180,780,180,780,180,210,780,810,180,210,780,210,780,780,180,780,180,780,180,210,780,210,780,210,780,210,780,210,780,780,180,780,180,780,180,210,780,210,6990;
20;7E;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;7F;DEBUG;Pulses=38;Pulses(uSec)=600,180,780,180,210,780,780,180,210,780,210,780,780,180,780,180,780,180,210,780,210,780,210,780,210,780,210,780,780,180,810,180,780,180,210,780,210,6990;
20;80;DEBUG;Pulses=50;Pulses(uSec)=810,180,210,780,210,780,210,780,810,180,780,180,780,180,810,180,210,780,780,180,210,780,210,780,780,180,810,180,780,180,210,780,210,780,210,780,210,780,210,780,780,180,780,180,780,180,210,780,210,6990;
20;81;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;A2;DEBUG;Pulses=50;Pulses(uSec)=840,210,210,780,210,780,210,780,780,180,780,180,780,180,780,180,210,780,780,180,210,780,210,780,780,180,780,180,780,180,210,780,210,780,210,780,210,780,210,780,780,180,810,180,780,180,210,780,210,6990;
20;A3;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;A4;DEBUG;Pulses=50;Pulses(uSec)=810,180,210,780,210,780,210,780,780,180,810,180,780,180,810,180,210,780,780,180,210,780,210,780,780,180,810,180,780,180,210,780,210,780,210,780,210,780,210,780,810,180,780,180,810,180,210,780,210,6990;
20;A5;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;A6;DEBUG;Pulses=38;Pulses(uSec)=810,180,810,180,210,780,810,180,210,780,210,780,810,180,810,180,810,180,210,780,210,780,210,780,210,780,210,780,810,180,780,180,810,180,210,780,210,6990;
20;A7;DEBUG;Pulses=50;Pulses(uSec)=810,210,210,780,210,780,210,780,810,180,810,180,810,180,780,180,210,780,810,180,210,780,210,780,810,180,810,180,810,180,210,780,210,780,210,780,210,780,210,780,780,180,780,180,810,180,210,780,210,6990;
20;A8;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;DC;DEBUG;Pulses=50;Pulses(uSec)=870,180,210,780,210,780,210,780,780,180,780,180,810,180,810,180,210,780,810,180,210,780,210,780,780,180,780,180,810,180,210,780,210,780,210,780,210,780,210,780,780,180,810,180,810,180,210,780,210,6990;
20;DD;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;DE;DEBUG;Pulses=38;Pulses(uSec)=540,180,780,180,210,780,780,180,210,780,210,780,810,180,810,180,810,180,210,780,210,780,210,780,210,780,210,780,780,180,810,180,810,180,210,780,210,6990;
20;DF;DEBUG;Pulses=50;Pulses(uSec)=900,210,210,780,210,780,210,780,810,180,810,180,780,180,810,180,210,780,810,180,210,780,210,780,780,180,810,180,810,180,210,780,210,780,210,780,210,780,210,780,780,180,810,180,810,180,210,780,210,6990;
20;E0;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;E1;DEBUG;Pulses=226;Pulses
20;FF;DEBUG;Pulses=50;Pulses(uSec)=840,210,210,780,210,780,210,780,780,180,780,180,780,180,780,180,210,780,810,180,210,780,210,780,780,180,780,180,780,180,210,780,210,780,210,780,210,780,210,780,780,180,780,180,780,180,210,780,210,6990;
20;00;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;01;DEBUG;Pulses=38;Pulses(uSec)=210,180,780,180,210,780,810,180,210,780,210,780,780,180,810,180,810,180,210,780,210,780,210,780,210,780,210,780,810,180,780,180,780,180,210,780,210,6990;
20;02;DEBUG;Pulses=50;Pulses(uSec)=810,180,210,780,210,780,210,780,780,180,780,180,810,180,810,180,210,780,780,180,210,780,210,780,780,180,810,180,810,180,210,780,210,780,210,780,210,780,210,780,780,180,810,180,810,180,210,780,210,6990;
20;03;Eurodomest;ID=070b1f;SWITCH=00;CMD=OFF;
20;04;DEBUG;Pulses=132;Pulses
Thank you.
I put the siren in learning mode and tried different types of manual switches = not working
hi
have you been able to get this chime to work reliably in RFlink ?
unfortunately no
But i didn't insist a lot waiting for a solution from stuntteam
