and moovo use the same code transmission) but Domiticz and RFlink will autodetect the push on the original remote. But it doesn't work when I use the switch button on Domoticz.
They work on the 433,92MHz band
Look below there is a dump for 2 attemps because it's a rolling code.
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R45;
10;version;
20;01;VER=1.1;REV=45;BUILD=09;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
10;rfdebug=on;
20;03;RFDEBUG=ON;
20;04;DEBUG;Pulses=156;Pulses(uSec)=0,690,270,330,300,330,300,330,270,330,270,330,270,330,300,330,300,330,270,330,270,330,300,3900,690,330,270,720,300,720,690,330,300,720,720,330,270,720,720,330,720,330,300,720,690,330,720,330,720,330,300,720,690,330,690,330,270,720,720,330,690,330,300,720,270,750,690,330,300,720,690,330,690,330,720,330,270,720,720,330,690,330,690,330,690,330,720,330,720,330,690,330,300,750,270,750,690,330,720,330,300,720,690,330,270,750,690,330,300,720,720,330,300,720,690,330,690,330,270,720,300,720,300,720,690,330,270,750,690,330,690,330,690,330,690,330,690,330,690,330,720,330,690,330,690,330,270,750,690,330,690,330,300,720,300,6990;
20;05;DEBUG;Pulses=154;Pulses(uSec)=360,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,270,330,300,330,270,3900,690,330,270,720,270,750,690,330,270,720,690,330,270,720,690,330,690,330,270,720,690,330,690,330,690,330,270,720,690,330,690,330,270,720,690,330,690,330,270,720,270,720,690,330,270,720,690,330,690,330,690,330,270,720,690,330,690,330,690,330,690,330,690,330,690,330,690,330,300,720,270,750,690,330,690,330,300,720,690,330,270,750,690,330,270,720,690,330,270,720,690,330,690,330,270,720,300,720,270,720,690,330,270,750,690,330,690,330,690,330,690,330,690,330,690,330,690,330,690,330,690,330,270,750,690,330,690,330,690,330,270,6990;
20;06;Keeloq;ID=32a9;SWITCH=04;CMD=ON;BAT=OK;
10;rfdebug=off;
20;07;RFDEBUG=OFF;
10;rfdebug=on;
20;08;RFDEBUG=ON;
20;09;DEBUG;Pulses=156;Pulses(uSec)=390,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,3900,720,330,300,720,720,330,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,720,330,690,330,720,330,300,720,720,330,300,720,300,720,720,330,300,720,300,720,720,330,300,720,720,330,720,330,720,330,300,720,300,720,300,720,720,330,300,720,720,330,720,330,300,720,300,720,690,330,690,330,300,720,720,330,300,720,720,330,300,720,720,330,300,720,720,330,720,330,300,720,300,720,300,720,690,330,300,720,690,330,720,330,690,330,690,330,720,330,690,330,720,330,690,330,690,330,300,720,720,330,720,330,300,720,300,6990;
20;0A;Keeloq;ID=32a9;SWITCH=04;CMD=ON;BAT=LOW;
20;0B;DEBUG;Pulses=156;Pulses(uSec)=360,330,300,330,300,330,270,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,3870,690,330,300,720,690,330,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,300,720,690,330,690,330,690,330,300,720,690,330,300,720,300,720,690,330,300,720,300,720,690,330,300,720,690,330,690,330,720,330,300,720,300,720,300,720,690,330,300,720,690,330,720,330,300,720,300,720,720,330,690,330,300,720,690,330,300,720,720,330,300,720,690,330,300,720,690,330,720,330,300,720,300,720,300,720,720,330,300,720,720,330,720,330,690,330,690,330,720,330,690,330,720,330,690,330,690,330,300,720,690,330,720,330,300,720,300,6990;
20;0C;DEBUG;Pulses=66;Pulses(uSec)=360,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,330,300,3900,690,300,300,720,690,330,300,720,300,720,270,720,300,720,300,720,300,720,300,720,300,720,300,720,720,330,690,330,720,330,300,720,720,330,300,720,300,720,690,330,300,720;
10;rfdebug=off;
20;0D;RFDEBUG=OFF;
20;0E;Keeloq;ID=32a9;SWITCH=0b;CMD=ON;BAT=LOW;
