Rflink 868 + Delta Dore X2D Tyxia 253 remote & Tyxia 4630 receivers
Post here about devices that are not yet or not fully supported
Antoine1
#1 Post by Antoine1 » 01 Apr 2018, 09:49
Hello to all,
I have recently bought and built an Rflink for 868mhz devices in order to use to control my home shutters.
My installation is actually manage via a remote Delta Dore Tyxia 253 and receivers Tyxia 4630 plugged at each shutters.
Depending on the website you are looking at the receiver is sometimes described as working on X2D protocol and sometimes on X3D protocol.
I am pretty sure that it is an X2D one as it is clearly written on the remote that the protocol is X2D and as the receivers are dated from 2011.
After assembly and soldering of the different part of the Rflink, everything seems to work properly as when I press on a button of the remote, the Rflink receives data properly but unfortunately, I do not manage to associate the receivers with the Rflink when trying to send a command.
Here is what I have when I press one time on the remote while it is in association mode + debug mode on Rflink Loader:
20;06;DEBUG;Pulses=511;Pulses(uSec)=2550,300,330,300,330,300,330,300,330,90,120,90,120,90,120,90,120,90,120,90,120,300,120,90,330,300,330,300,330,300,120,90,330,300,330,90,120,300,330,90,120,300,330,120,120,300,330,90,120,300,120,120,330,300,330,300,330,300,330,300,330,120,120,300,120,90,330,300,330,300,120,90,330,300,330,300,120,120,330,300,120,90,330,120,120,300,330,300,120,90,330,300,120,90,330,300,330,300,330,300,120,90,330,300,330,300,330,90,120,300,330,90,120,90,120,300,330,90,120,300,330,120,120,300,330,120,120,90,120,90,120,90,120,90,120,300,120,90,330,90,120,300,120,90,120,90,120,90,120,90,330,90,120,90,120,120,120,90,120,90,120,90,120,90,120,90,120,300,120,90,120,90,120,90,120,90,120,90,120,90,330,120,120,300,330,300,330,300,330,90,120,330,330,300,120,90,330,330,120,90,330,300,120,90,330,300,120,90,330,90,120,300,330,300,330,300,330,300,330,300,120,90,330,120,120,300,330,300,330,90,120,300,330,300,330,120,120,300,330,90,120,300,120,90,330,300,330,120,120,300,330,90,120,300,330,330,330,300,330,90,120,300,330,300,330,300,120,90,330,300,120,90,120,120,330,300,120,90,330,300,120,120,330,300,120,120,120,90,120,120,120,90,120,90,330,90,120,300,120,120,330,90,120,90,120,90,120,90,120,300,120,90,120,90,120,120,120,90,120,90,120,90,120,120,120,90,330,90,120,90,120,90,120,90,120,90,120,90,120,300,120,120,330,330,330,300,330,300,120,90,330,300,360,60,120,300,330,90,120,300,330,120,120,300,330,90,120,300,120,120,330,300,330,300,330,300,330,300,330,120,120,300,120,90,330,300,330,300,120,90,330,300,330,300,120,90,330,300,120,90,330,90,120,300,330,300,120,90,330,300,120,90,330,300,330,300,330,300,120,90,330,300,330,300,330,90,120,300,330,120,120,90,120,300,330,90,120,300,330,90,120,300,330,90,120,90,120,90,120,90,120,90,120,300,120,90,330,90,120,300,120,90,120,90,120,90,120,90,330,90,120,90,120,120,120,90,120,90,120,90,120,90,120,90,120,300,120,90,120,90,120,90,120,90,120,90,120,90,330,120,120,300,330,300,330,300,330,90,120,300,330;
20;07;X2DDEBUG;81485200859022812093fc7aff
20;08;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=2093;S=2281;BAT=OK;
20;09;DEBUG;Pulses=511;Pulses(uSec)=210,90,330,300,120,90,120,90,120,90,120,90,120,90,330,120,120,300,120,90,330,120,120,90,120,120,120,90,120,300,120,90,120,120,120,90,120,90,120,90,120,90,120,90,120,120,330,120,90,120,120,90,120,90,120,90,120,90,120,300,120,120,330,300,330,300,330,300,120,90,330,300,330,120,120,300,330,90,120,300,330,90,120,300,330,90,120,300,120,90,330,300,330,330,330,300,330,300,330,90,120,300,120,90,330,300,330,300,120,90,330,300,330,300,120,90,330,300,120,90,330,90,120,300,330,300,120,90,330,300,120,90,330,300,330,300,330,300,120,90,330,300,330,300,330,90,120,300,330,120,120,90,120,300,330,90,120,300,330,90,120,300,330,90,120,90,120,90,120,90,120,90,120,300,120,90,330,90,120,300,120,90,120,90,120,90,120,90,330,120,120,90,120,90,120,90,120,90,120,90,120,90,120,90,120,300,120,120,120,90,120,90,120,90,120,90,120,120,330,90,120,300,330,300,330,300,330,90,120,300,330,300,120,90,330,300,120,90,330,300,120,90,330,300,120,90,330,90,120,300,330,300,330,300,330,300,330,300,120,90,330,120,120,300,330,300,330,120,120,300,330,300,330,90,120,300,330,90,120,330,120,90,330,300,330,90,120,300,330,90,120,300,330,300,330,300,330,90,120,300,330,300,330,300,120,90,330,300,120,90,120,90,330,300,120,90,330,300,120,90,330,300,120,90,120,90,120,90,120,90,120,90,330,90,120,330,120,90,330,120,120,90,120,90,120,90,120,300,120,90,120,90,120,120,120,90,120,90,120,90,120,90,120,120,330,90,120,120,120,90,120,120,120,90,120,90,120,300,120,90,330,300,330,300,330,300,120,90,330,300,330,120,120,300,330,90,120,300,330,90,120,300,330,90,120,300,120,90,330,300,330,300,330,300,330,300,330,90,120,300,120,90,330,300,330,300,120,90,330,300,330,300,120,90,330,300,120,90,330,90,120,300,330,330,120,90,330,300,120,90,330,300,330,300,330,330,120,90,330,330,330,330,330,90,120,300,330,90,120,90,120,300,330,90,120,330,330,90,120,300,330,120,120,90,120,90,120,90,120,90,120,300,120,90,330,90,120,300,120,90,120,90,120,90,120,90,330,120,120,90,120;
20;0A;DEBUG;Pulses=50;Pulses(uSec)=270,330,90,630,150,270,180,750,300,450,150,510,270,570,270,450,150,750,60,270,120,930,270,1470,90,150,210,1110,120,660,120,660,180,480,90,780,240,780,30,210,180,1020,270,720,150,660,60,840,60,6990;
And here is what I have when I press several times the "up" button when the remote is in association mode with debug mode disabled:
20;0C;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=1e2b;S=2281;BAT=OK;
20;0D;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=c62a;S=2281;BAT=OK;
20;0E;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=69b0;S=2281;BAT=OK;
20;0F;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=f12b;S=2281;BAT=OK;
20;10;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=1a2b;S=2281;BAT=OK;
20;11;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=08b0;S=2281;BAT=OK;
20;12;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=b692;S=2281;BAT=OK;
20;13;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=c12a;S=2281;BAT=OK;
20;14;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=d092;S=2281;BAT=OK;
20;15;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=3692;S=2281;BAT=OK;
20;16;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=c52a;S=2281;BAT=OK;
20;17;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=e92a;S=2281;BAT=OK;
20;18;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=09b0;S=2281;BAT=OK;
20;19;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=b392;S=2281;BAT=OK;
20;1A;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=1c92;S=2281;BAT=OK;
20;1B;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=1c2b;S=2281;BAT=OK;
20;1C;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=ce2b;S=2281;BAT=OK;
20;1D;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=d692;S=2281;BAT=OK;
20;1E;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=0393;S=2281;BAT=OK;
20;1F;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=3893;S=2281;BAT=OK;
20;20;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=1493;S=2281;BAT=OK;
20;21;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=46b0;S=2281;BAT=OK;
20;22;X2D;ID=0014881;SWITCH=12;CMD=ON;EXT=TYXIA;RC=8892;S=2281;BAT=OK;
Do you think there is a chance to get it working or not?
In case you need additional logs tell me!
Many thanks in advance for your potential help (or not), I know X2D is tricky and that due to rolling code it might not be possible to make it working but I still have a little hope...
molki
Re: Rflink 868 + Delta Dore X2D Tyxia 253 remote & Tyxia 4630 receivers
#2 Post by molki » 09 Apr 2018, 17:36
I'm also interested in this, but don't have the 868 hardware yet. What 868 module did you use ?
For the protocol, are you sure this is the good way to go ?
For my shutters, when I want to associate a new remote, I have to use the old remote to set the shutter receiver to "associating mode", and then I have to press 2 buttons on the new remote for the receiver to accept and register it. (special command sent by the remote)
I think this is what we must decode before decoding how actions work. (decoding how the pairing with receivers work)
Antoine1
#3 Post by Antoine1 » 10 Apr 2018, 22:46
In order to put the receivers in association mode, it is necessary to press a button at the back of the receiver.
In order to put the remote in learning mode I have to hold on the button in the middle of the remote for few secondes, then I have to select the area I want to associate this receiver with and finally press up or down button.
The logs I have posted are captures of the signal received by the RFlink when press up or down when both receiver and remote are in association.
What looks strange for me is that the signal received seems to be exactly the same than the one the remote is sending when it is not in association mode.
I could post more logs and do more tests if it can help.
Regarding the hardware, I bought it on Nodo shop, in a complete package.
Stuntteam
Site Beheer
#4 Post by Stuntteam » 10 Apr 2018, 23:54
Association (Pairing) mode is already supported for some X2D models.. We are working on others.
SuperCed
#5 Post by SuperCed » 31 May 2019, 14:24
I try to command a Driver 220 CPL with a Tydom 520 inside.
The manufacturer told me that I need a Tydom 310 or 315 to control it, but I don't have that.
So I think I cannot sniff packets...
I am trying with a rflink 868.
How can I find the right command to pair my rflink with the Driver 200 and how can I find command in order to change in moon or sun etc ?
Thanks a lot!
