3 way switch from banggood - 433 IC unknown
Posted: 22 May 2019, 13:32
Hi everyone,
Recently I bought a super cheap 3 way switch from banggood. It does transmit, RFLINK sees the code, but it is unsupported. I opened the device but the 433mhz IC is unknown.
I hope it can be supported in RFLink, since the switch is overall really great.
This is the device: https://www.banggood.com/86-Type-123-Wa ... 34774.html
Here is the debug log, both in jpg format and txt format. I hope it can be added to rflink!
Edit: I forgot to mention that this 3 way switch only sents an "On" command (i.e., each individual switch only has one button. Not 2 (On & Off). So one device has in total 3 RF codes, 3x ON).
10;rfdebug=on;
20;02;RFDEBUG=ON;
<!-- schakelaar 1 --!>
2019-05-10 13:13:26 - 20;03;DEBUG;Pulses=48;Pulses(uSec)=330,900,240,870,240,870,240,870,240,870,870,240,240,900,900,240,240,870,870,240,870,240,870,240,870,240,870,240,870,240,870,240,870,240,240,870,870,240,240,870,240,870,240,870,870,240,240,6990;
20;04;DEBUG;Pulses=50;Pulses(uSec)=300,900,240,870,240,870,240,870,240,870,240,870,870,240,240,900,870,240,240,870,870,2402019-05-10 13:13:27 - ,870,240,870,240,900,240,870,240,870,240,870,240,870,240,240,870,870,240,240,870,240,870,240,870,870,210,240,6990;
20;05;DEBUG;Pulses=50;Pulses(uSec)=300,900,240,870,240,870,240,870,240,870,240,870,870,240,240,900,870,240,240,870,870,240,870,240,870,240,870,240,870,240,870,240,870,240,870,240,240,870,870,240,240,870,240,870,240,870,870,240,240,6990;
<!-- schakelaar 2 --!>
2019-05-10 13:14:30 - 20;06;DEBUG;Pulses=48;Pulses(uSec)=270,900,240,900,240,870,240,870,240,870,870,240,240,900,870,240,240,900,870,240,870,240,870,240,870,240,870,240,870,240,870,240,870,240,240,870,870,240,240,870,900,240,240,870,240,870,240,6990;
20;07;DEBUG;Pulses=50;Pulses(uSec)=300,900,240,870,240,870,240,900,240,870,240,870,870,240,240,900,870,240,240,870,870,240,870,240,870,240,870,240,870,240,870,240,870,240,870,240,240,870,870,240,240,870,870,240,240,870,240,870,240,6990;
20;08;DEBUG;Pulses=50;Pulses(uSec)=270,900,240,870,240,870,240,870,240,870,240,870,870,240,240,900,870,240,240,870,870,240,870,240,870,240,870,240,870,240,870,240,900,240,870,240,240,870,870,240,240,870,870,240,240,900,240,870,240,6990;
<!-- schakelaar 3 --!>
2019-05-10 13:15:28 - 20;09;DEBUG;Pulses=48;Pulses(uSec)=330,900,240,870,240,870,240,870,240,870,870,240,240,900,870,240,240,870,900,240,870,240,870,240,870,240,870,240,870,240,870,240,870,240,240,870,870,240,240,870,240,870,870,240,240,870,240,6990;
20;0A;DEBUG;Pulses=50;Pulses(uSec)=300,900,240,900,240,870,240,870,240,870,240,870,870,240,240,900,870,240,240,870,870,240,900,240,870,240,870,240,870,240,870,240,870,240,870,240,240,870,870,240,240,870,240,870,870,240,240,870,240,6990;
20;0B;DEBUG;Pulses=50;Pulses(uSec)=300,900,240,870,240,870,240,870,240,870,240,870,870,240,240,900,870,240,240,870,870,240,870,240,870,240,870,240,870,240,870,240,870,240,870,240,240,870,900,240,240,870,240,870,870,240,240,870,240,6990;
