rflink not seeing La Crosse TX141TH-BV2
Post here about devices that are not yet or not fully supported
micsaund
#1 Post by micsaund » 12 Oct 2019, 23:01
I just got rflink running and have been playing around decoding which sensor is which around the house. In the process, I found that my La Crosse TX141TH-BV2 is not recognized.
It looks like the communication can be decoded (example https://github.com/merbanan/rtl_433/blo ... 41TH_Bv2.c )
Are there any plans to incorporate this sensor into rflink in the near future?
Mike
Stoomik
Re: rflink not seeing La Crosse TX141TH-BV2
#2 Post by Stoomik » 20 Mar 2020, 16:56
Hi !!
I got the same issue with this sensor.
I got a signal in the debug mode but can't connect it to domoticz. Here's the log from debug mode when I press the button to send the signal :
20;65;DEBUG;Pulses=344;Pulses(uSec)=120,210,240,210,240,240,30,450,270,210,30,480,30,450,30,450,60,450,90,480,30,480,60,450,270,210,60,480,270,210,270,240,240,210,270,240,270,210,30,480,240,210,60,480,60,480,90,450,30,480,270,240,270,240,60,480,60,450,60,480,60,450,270,240,30,480,270,210,60,480,270,270,270,240,270,300,690,810,660,840,660,840,660,900,60,450,30,480,270,240,270,240,240,210,60,480,270,240,60,450,60,480,60,480,60,450,60,480,60,450,60,450,270,240,30,450,240,210,270,240,270,240,270,240,240,210,30,480,270,240,60,450,60,480,60,450,90,450,270,240,240,240,60,450,60,480,30,450,60,450,270,210,60,480,240,240,30,480,270,210,270,240,240,270,660,840,660,840,660,840,660,870,60,480,60,420,270,240,270,240,270,240,60,480,270,240,30,480,60,450,60,480,90,450,60,480,60,450,60,480,240,210,60,480,270,240,270,240,240,240,270,240,270,210,60,480,240,240,30,480,60,450,60,480,60,450,270,240,240,240,30,450,60,480,60,450,60,450,240,210,60,480,240,240,60,480,270,240,270,240,240,300,660,840,660,840,660,840,660,870,30,450,60,480,270,240,240,240,270,240,60,450,270,240,60,450,60,480,30,480,60,420,60,480,90,480,90,450,270,240,60,510,270,240,270,240,270,240,270,240,240,210,60,480,270,240,30,450,60,480,60,450,60,480,240,210,240,210,60,480,60,450,60,450,60,480,270,210,60,480,240,240,60,450,270,240,270,240,240,300,660,810,660,6990;
2020-03-20 16:55:07.811 RFLink: 20;66;DEBUG;Pulses=272;Pulses(uSec)=1170,360,870,660,810,690,780,750,150,330,150,360,360,150,360,150,360,120,120,420,360,150,150,360,120,390,330,150,120,390,120,360,120,390,120,360,360,150,120,390,330,180,360,150,360,180,300,180,300,150,120,420,300,180,90,420,120,390,120,420,90,390,330,180,330,150,90,420,120,390,120,420,330,150,120,420,300,180,330,210,90,390,330,180,300,210,330,270,720,780,690,780,690,780,690,840,90,420,90,420,300,180,300,210,330,180,90,450,270,180,90,450,120,390,330,210,90,420,120,420,90,480,60,450,300,180,90,480,300,180,300,210,300,180,330,210,300,210,90,420,300,180,90,450,90,420,90,450,60,450,300,210,270,180,90,450,90,420,90,420,270,180,90,420,270,180,300,240,90,420,300,240,270,210,300,300,690,810,690,810,660,810,660,870,60,420,60,450,270,180,300,240,270,210,60,480,300,240,60,450,60,450,270,240,60,450,60,450,60,450,60,450,270,240,60,450,270,240,240,210,270,240,240,240,240,240,30,510,240,240,30,480,60,480,60,450,30,480,240,240,240,240,30,480,30,450,30,480,270,240,30,480,240,240,240,270,60,450,240,270,210,240,240,360,630,870,630,870,600,870,600,930;
2020-03-20 16:55:08.164 RFLink: 20;67;DEBUG;Pulses=330;Pulses(uSec)=330,240,30,450,30,420,30,450,60,450,270,240,60,480,270,210,270,240,240,210,270,270,270,210,30,480,240,210,60,480,60,450,30,480,60,480,270,240,240,210,60,450,60,480,60,450,270,240,60,450,270,240,240,240,60,450,270,210,270,240,240,300,660,840,660,840,660,840,660,870,60,450,30,450,270,210,270,270,270,240,60,480,270,240,30,450,60,480,270,210,60,480,60,450,30,510,60,450,270,210,60,480,270,240,270,240,240,240,270,270,270,210,60,510,270,240,60,450,60,480,60,480,90,450,270,240,240,240,60,450,60,480,60,450,270,240,30,420,270,240,270,240,60,480,270,240,270,240,270,330,690,840,660,810,660,840,660,870,60,450,60,480,270,210,270,240,270,240,60,480,270,240,30,450,60,450,270,210,30,480,60,450,60,510,60,480,270,210,60,480,270,210,270,240,240,210,270,270,270,210,60,480,240,210,60,480,90,450,60,450,60,480,270,210,240,210,30,480,60,480,60,450,270,240,60,450,270,240,270,240,60,480,270,240,270,210,270,330,690,840,660,810,660,840,660,870,90,450,60,480,240,210,270,240,270,210,60,450,240,210,30,480,60,450,270,240,30,480,30,450,60,450,60,480,270,210,60,510,240,240,270,240,270,240,270,240,240,210,60,480,270,240,30,450,60,450,90,450,60,450,270,240,240,240,60,480,60,450,90,450,270,240,30,480,270,240,270,240,60,450,270,240,240,240,270,300,660,840,660,6990;
2020-03-20 16:55:12.313 RFLink: 20;68;DEBUG;Pulses=272;Pulses(uSec)=6000,210,810,660,810,690,780,750,150,360,150,360,390,120,390,150,360,150,150,390,360,120,120,420,150,360,360,150,120,360,120,390,150,390,150,390,360,180,120,390,360,180,330,150,330,180,330,210,300,150,120,420,330,150,90,450,120,390,120,420,120,420,330,180,300,180,90,420,90,420,120,390,300,180,90,420,300,180,330,180,90,420,300,150,330,180,300,240,690,780,690,780,720,780,720,810,90,420,90,390,330,210,300,180,300,180,90,420,300,180,90,480,60,390,330,210,90,420,90,420,120,390,90,420,270,180,90,450,330,210,300,210,300,180,300,240,300,210,90,450,270,180,90,450,90,420,90,450,60,450,300,210,300,180,90,450,90,420,90,450,300,180,90,450,270,210,300,240,60,420,300,210,270,210,300,300,720,810,660,810,690,810,660,870,60,420,60,450,270,210,300,240,300,240,60,450,270,210,60,480,90,420,300,240,30,480,90,450,60,450,90,480,270,240,60,480,270,210,270,240,240,240,270,240,270,240,30,510,240,240,30,480,60,450,30,480,30,480,240,240,240,240,30,510,30,480,60,450,270,240,30,450,270,270,240,240,30,510,240,270,240,270,240,330,630,840,630,870,630,870,600,930;
Thank you for your answer !!
