No Milight Pairing option
Moderators: rtenklooster, BertB, Voyager, Stuntteam
korzeniewski36
#1 Post by korzeniewski36 » 08 Oct 2019, 15:04
Hello, I am a fresh gate user and I have a problem with pairing with milight and rflink, I do everything according to the instructions on the website http://www.rflink.nl/blog2/faq, but all the time I get the message that "problem while creating the sensor" led do not want to blink 3 times only the candle, the device is fut038, unfortunately I do not have a remote control. Do you have any ideas?
Stuntteam
Site Beheer
Re: No Milight Pairing option
#2 Post by Stuntteam » 08 Oct 2019, 23:26
Do the pairing within RFlink Loader!
Do NOT use the manual create rflink devices option.
That is only used to instruct the home automation software what your devices are.
There is no RF function linked to it at all.
korzeniewski36
#3 Post by korzeniewski36 » 09 Oct 2019, 15:27
Case solved, I gave a 20nF power capacitor and started right away. I made the pairing through Domoticz. Why not steam through Domoticz if it is so in the instructions? There is another problem with LED brightness when using plans in domoticz. The led colors change as set in the plan, but the brightness is set as after the last power off. It doesn't change at all, is there any advice?
