Addressable Temperature Sensors
Moderators: rtenklooster, BertB, Voyager, Stuntteam
prairietech
#1 Post by prairietech » 24 Mar 2020, 21:52
I have an application where RFLink might work. It involves using 6-8 temperature sensors in different close proximity locations.
Does anyone know of any off the shelf weatherproof temperature sensors that are addressable so their temperature data can be decoded on a individual sensor output?
This would be for use in the USA in case frequency coverage is an issue.
Re: Addressable Temperature Sensors
#2 Post by TD-er » 26 Mar 2020, 00:32
If it is in (relative) close proximity, why not use Dallas 1wire sensors?
prairietech
#3 Post by prairietech » 26 Mar 2020, 01:03
Running wire between the locations is not practical. In a couple locations, there is a driveway between sensor locations.
#4 Post by TD-er » 26 Mar 2020, 17:03
Should the sensor units be battery powered?
If not, then you can also have a look at ESPEasy and install several of them.
For battery powered ones I don't have a model to suggest.
prairietech
#5 Post by prairietech » 27 Mar 2020, 03:33
I'm a HUGE fan of esp easy!
But yes I was looking for something battery powered.
Also was looking for something with better range than wifi. I've used Wemos, esp8266 and sonoff devices with very very poor range.
#6 Post by TD-er » 27 Mar 2020, 19:55
Well I recently added support for LoRaWAN via the Microchip RN2483, so a range of several km is also an option and on location you could share the values via p2p protocol (one as AP, the others as wifi client)
Still not a battery-powered solution as WiFi + battery is not a good solution.
