Hello.
Following my issues with the tilt motor I decided to get the other curtains working until this gets sorted.
For some reason - one of my blinds is reversed, up is down and down is up, the other ones (one of them is the same model) are fine.
Is there a way to inverse it a specific device? is that a pairinig issue and trying again should solve it?
Somfy RTS inverted control
Re: Somfy RTS inverted control
You need to follow the manual from somfy for this.
With a somfy remote you can change the direction of the motor. That up will be the same direction as your other blinds
I have 2 blinds and 2 curtains.
Had the same problem, with the remote i changed the direction.
The somfy control was fine, the problem was with RFlink.
I ended up solving it by upgrading home assistant and adding "inverted" to the configuration of the blind.
