RFLink Livolo IDs and Unit Codes
I would like to manually add the Livolo switches to the Domoticz. After selecting the "Livolo" item from available devices list there are three parameters I need to set using trzy select lists - two parameters are related to "ID" and one to "Unit code". Is there any key how should I select values there?
Re: RFLink Livolo IDs and Unit Codes
What you are trying to do is not possible.
For RFlink there is no Livolo setting in Domoticz.
Read: http://www.rflink.nl/blog2/faq
and scroll to
Q: how to create devices in Domoticz without the original remote control?
and scroll to
I’ve already ready it. The Livolo model is not mentioned there (there are Impuls, Kaku, EMW203R), so is there any possibility to control Livolo them using such a codes?
The thing is that Some of the codes (randomly set on the basis of “ID’s” and “Unit codes” seems to be working - after the switch is added manually it’s triggering the Livolo switch correctly. But its a lottery...
Users browsing this forum: No registered users and 44 guests
