CAME TOP Garage door opener
kameo42
#1 Post by kameo42 » 07 Mar 2020, 21:11
I bought a house and the owner seemed to have been fascinated with the CAME remotes.
So far I see, these are supported devices in RFLINK. Supposedly, it would use M48 Top43 XEV protocol.
I got, with a 433 Mhz transciever, the following returns when pressing buttons:
20;14;DEBUG;Pulses=26;Pulses(uSec)=270,240,570,240,570,570,240,240,570,570,240,570,240,570,240,240,570,240,570,570,240,240,570,570,210,6990;
20;15;Aster;ID=0d18;SWITCH=02;CMD=ON;
So it seems to be Aster protocol right?
It seems to be a static code, but just sending back the same with:
10;Aster;ID=0d18;SWITCH=02;CMD=ON (it's a toggle)
didn't grant any result.
One more information, the remote back shows a TOP434NA model.
Any hints?
Also, if this is an insecure protocol, what do you usually replace those with? (that would be rolling code at minimum & compatible with RFlink obviously)
