RFLink consistently changes ID of switch after an hour or so
Mike99
#1 Post by Mike99 » 08 Oct 2020, 17:37
I’m using RFLink with homeasssisant.
On my Sonoff multiremote (https://www.itead.cc/sonoff-rm433-remot ... -base.html) the ID’s change from Eurodomest -xxxx to EV1527 -xxxx consistently after an hour after restart on some of the Sonoff remote switches.
It always changes to the same EV1527 alternative ID’s so I’ve taken account of this by adding both IDs in the automation script on Home Assistant and adding both as switches.
Although this resolves the issue for me (hopefully permanently)I imagine others will struggle with this when new to RFLink for a while as I did - I thought it was hardware or soldering issues.
I assume this is some kind of bug in the RFlInk firmware and hopefully this information can help fix that bug.
Mirror of the Sonoff remote site in case it becomes inaccessible: https://archive.is/IQR8t
