CC2500 - or equivalent for Ansluta?
mkotek
#1 Post by mkotek » 01 Nov 2016, 22:04
I have seen, there is now a requirement for CC2500 to be used for connectivity to Ansluta devices.
Does it mean, I can use Ansluta and Milight connection at the same time (pins seem to be overlaping - any way to move them?)?
Also, I can see, on Aliexpress, they offer MD7105-SY (or A7105) claiming to be better than CC2500. Can I use this one instead of CC2500 or this one (or one of the 2 other menitoned on wiring page) is required? MD7105-SY seems to be more easily available and cheaper.
Michal 'Kotek', greetings from Poland. Zapraszam na mój blog o automatyce domowej po polsku: http://www.ukotka.com.
Stuntteam
Site Beheer
Re: CC2500 - or equivalent for Ansluta?
#2 Post by Stuntteam » 01 Nov 2016, 23:24
mkotek wrote:I have seen, there is now a requirement for CC2500 to be used for connectivity to Ansluta devices.
Yes, you can use Ansluta and Milight at the same time.
The pin overlap is not a mistake but a feature.
As for the module, you need a real CC2500. Not one of the many fakes or mostly incompatibles.
A search for the real CC2500 on aliexpress shows one for 2.37 and one for 1.93 euros. Hardly expensive...
mkotek
#3 Post by mkotek » 04 Nov 2016, 08:18
Stuntteam wrote: As for the module, you need a real CC2500. Not one of the many fakes or mostly incompatibles.
I have just asked for the benefit of us all, as the blog shows 2 other components I presume compatible with CC2500.
And on the price - of course they ar enot expensive, but as with a lot of Aliexpress listings, if something is cheaper, does not mean it is worse than more expensive items. Hence my observationabout other modules being cheaper.
Again, nothing against utilizing CC2500 itself. And thank you for the response.
ayasystems
#4 Post by ayasystems » 25 Jan 2017, 10:41
Which is the best option to do a level shifter?
I'm ussing a txb0108-bi-directional-level-shifter but seems not works .....
Regards!
ayasystems
#5 Post by ayasystems » 25 Jan 2017, 11:43
I build another cc2500 with txb0108 level shifter and works fine whit this code -> https://github.com/Zohan/ArduinoCC2500Demo
But is not working with rf link....
When I try to activate Ansluta Rflink not work anymore until the eeprom is erased.
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R45;
10;version;
20;01;VER=1.1;REV=45;BUILD=09;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
10;rfdebug=on;
20;03;RFDEBUG=ON;
10;rfdebug=off;
20;04;RFDEBUG=OFF;
10;rfudebug=on;
20;05;RFUDEBUG=ON;
10;rfdebug=on;
20;06;RFDEBUG=ON;
10;setAnsluta=on;
10;rfdebug=off;
10;rfdebug=on;
10;rfdebug=off;
10;rfudebug=off;
10;rfdebug=on;
10;rfdebug=off;
10;rfudebug=on;
Stuntteam
Site Beheer
#6 Post by Stuntteam » 25 Jan 2017, 15:14
This means one of the following things:
- CC2500 module is not wired correctly (check pinout, make sure level shifters are used correctly)
- CC2500 module does not receive enough power (make sure the level shifters are working correctly and are shifting fast enough)
- CC2500 module is dead (did you connect it to 5 volt, it does not like that)
Dr_Genestealer
#7 Post by Dr_Genestealer » 27 Jan 2017, 22:39
Strangely I'm experiencing the same issue: viewtopic.php?f=11&t=2586&p=12773&hilit ... %3B#p12773
techsoz
#8 Post by techsoz » 12 Jun 2017, 21:00
ok, now i wired it. directly following: https://github.com/Genestealer/Home-Ass ... ay-ESP8266
but it doesnt seem to work
when I click on Ansluta mode on, it says
20;03;setAnsluta=OFF;NO CC2500;
20;04;setGPIO=ON;
20;00;Internal Pullup on RF-in disabled
Users browsing this forum: No registered users and 38 guests
