HAGER FLASH THERMOSTAT problem
French support forum, post can be done in French, answers will either be in French or in English.
Moderators: rtenklooster, BertB, Voyager, Stuntteam, Deennoo
pouilld
#1 Post by pouilld » 30 May 2018, 11:22
RFLINK V48 documentation indicates this device as supported.
Domoticz release don't support it (invalid device type) it but beta does.
Device is automatically discovered when using a remote and a switch type ON/OFF created in Domoticz.
Problem is that commands ON or OFF sent later with Domoticz are accepted by RFLINK but without any action on the device.
See attached log (RFLINK V48 and latest Domoticz beta version).
Please help,
Thanks in advance,
D. Pouilloux
LOG Domoticz.zip
(1.04 KiB) Downloaded 67 times
Errance
Re: HAGER FLASH THERMOSTAT problem
#2 Post by Errance » 05 Nov 2019, 20:10
I'm aslo trying to use an Hager Thermoflash and it's not working.
Does someone made it work ?
[2019-11-05 20:05:11][INFO] : 11;10;Hager;10c70002;20;ON
[2019-11-05 20:05:11][DEBUG] : Trame non utilisable 0710c700022008
[2019-11-05 20:05:11][DEBUG] : Trame non utilisable 20;8B;OK
Errance
#3 Post by Errance » 09 Nov 2019, 19:25
I have tried with the Rflink loader.
I can see the Hager Thermoflash sending signal, but when I try to do the same, It say ok but nothing happen.
I have done it closely to the heater
Is this a bug with the Rflink ? It's really strange.
20;41;Hager;ID=12ff0002;SWITCH=20;CMD=ON;D=08;
20;42;Hager;ID=12ff0002;SWITCH=20;CMD=OFF;D=0C;
10;Hager;12ff0002;20;ON;
07000000002008
20;0A;OK;
Errance
#4 Post by Errance » 13 Nov 2019, 15:57
Nobody is using Hager protocol ? :-(
Errance
#5 Post by Errance » 20 Nov 2019, 14:21
I have made another try but no more success, the Rflink can listen the signal but when I send it, nothing :-/
