RFLINK V48 documentation indicates this device as supported.
Domoticz release don't support it (invalid device type) it but beta does.
Device is automatically discovered when using a remote and a switch type ON/OFF created in Domoticz.
Problem is that commands ON or OFF sent later with Domoticz are accepted by RFLINK but without any action on the device.
See attached log (RFLINK V48 and latest Domoticz beta version).
Please help,
Thanks in advance,
D. Pouilloux
HAGER FLASH THERMOSTAT problem
- LOG Domoticz.zip
- (1.04 KiB) Downloaded 569 times
Re: HAGER FLASH THERMOSTAT problem
I'm aslo trying to use an Hager Thermoflash and it's not working.
Does someone made it work ?
[2019-11-05 20:05:11][INFO] : 11;10;Hager;10c70002;20;ON
[2019-11-05 20:05:11][DEBUG] : Trame non utilisable 0710c700022008
[2019-11-05 20:05:11][DEBUG] : Trame non utilisable 20;8B;OK
I have tried with the Rflink loader.
I can see the Hager Thermoflash sending signal, but when I try to do the same, It say ok but nothing happen.
I have done it closely to the heater
Is this a bug with the Rflink ? It's really strange.
20;41;Hager;ID=12ff0002;SWITCH=20;CMD=ON;D=08;
20;42;Hager;ID=12ff0002;SWITCH=20;CMD=OFF;D=0C;
10;Hager;12ff0002;20;ON;
07000000002008
20;0A;OK;
Nobody is using Hager protocol ?
I have made another try but no more success, the Rflink can listen the signal but when I send it, nothing :-/
I have made some further tests in 2018 using several beta version of V48 in coordination with a RFLINK programmer and we have progressed in determining in RFLINK the coding of the various orders sent by the thermostat.
Unfortunately (lack of ressources, complexity?) the firmware has not be upgraded to allow correct receiving and sending of various thermostat orders by Domoticz, so I give up and tried to replace actual devices with SONOFF R2 dual, modified, smart switch with EASPEASY MEGA 2.
Hi guys,
I also have an Hager Thermoflash thermostat with a 433MHz Rflink in R48. I am observing the same bad behavior in home assistant (I can see a switch corresponding to the state of the heating system which correctly evolve, ON when heating, OFF when not, but when I am interacting with this switch manually in Home Assistant nothing happen on the heater). It seems Read Only information.
I saw in the RFLink v1.1 R50 work-in-progress that Additional Hager support will be added.
If you need testers I can maybe help but I don't know where to find rflink beta release.
KR,
KR,
Users browsing this forum: No registered users and 27 guests
