Goeden middag,
Ik ben nieuw in deze wereld en probeer daarom nog met goedkope spullen dingen uit.
Nu heb ik een deur contact binnen gekregen maar die zie ik niet in Domoticz (of ik doe iets fout). Want ik weet ook niet precies hoe ik hem aan moet maken.
Nu las ik op het forum ook iemand die 2x de informatie ontving van de melder (was een ander type).
Ik heb nu hetzelfde probleem is daarom misschien dat hij het bij mij ook niet werkt.
Ik voeg hierbij de debug file die ik van de melder ontvang.
20;28;DEBUG;Pulses=50;Pulses(uSec)=210,870,90,870,90,870,660,300,90,870,690,270,90,870,90,870,90,900,660,300,90,900,60,870,690,300,90,870,690,300,660,300,90,870,90,870,690,300,90,870,690,300,690,300,660,300,90,870,90,6990;
20;29;DEBUG;Pulses=50;Pulses(uSec)=210,870,90,870,90,870,660,300,90,870,660,300,90,870,90,870,90,870,660,300,90,870,90,870,660,300,90,870,690,300,690,300,90,870,90,870,660,300,90,870,660,300,660,300,690,300,90,870,90,6990;
20;2A;DEBUG;Pulses=50;Pulses(uSec)=180,900,90,870,90,870,660,300,90,900,660,300,90,870,90,900,90,870,660,300,90,870,90,900,660,300,90,900,660,300,660,300,90,870,90,900,660,300,90,900,660,300,660,300,660,300,90,900,60,6990;
20;2B;DEBUG;Pulses=50;Pulses(uSec)=180,900,90,900,90,900,660,300,60,900,660,300,90,900,60,900,60,900,660,300,60,900,60,900,660,330,60,900,660,330,660,330,60,900,60,900,660,330,60,900,660,330,630,330,630,330,60,900,60,6990;
20;2C;DEBUG;Pulses=26;Pulses(uSec)=720,360,30,960,600,360,630,330,60,930,30,930,600,330,60,930,630,330,630,330,630,330,60,930,60,6990;
20;2D;DEBUG;Pulses=32;Pulses(uSec)=270,300,60,870,30,870,600,300,60,870,600,330,600,330,30,870,60,870,630,330,60,930,630,330,630,330,630,330,60,930,60,6990;
20;2E;DEBUG;Pulses=26;Pulses(uSec)=60,300,60,870,600,300,600,300,60,840,60,840,600,300,60,870,600,300,630,300,660,300,90,900,60,6990;
20;2F;Mertik;ID=65;SWITCH=01;CMD=GODOWN;
20;30;DEBUG;Pulses=50;Pulses(uSec)=180,900,60,900,90,900,660,300,90,870,660,300,90,870,90,870,90,870,660,300,90,870,90,870,660,300,90,870,660,300,690,300,90,870,90,870,660,300,90,870,660,300,690,300,690,300,90,870,90,6990;
20;31;Eurodomest;ID=0ebb4d;SWITCH=00;CMD=OFF;
20;32;DEBUG;Pulses=50;Pulses(uSec)=180,870,120,870,90,870,690,240,150,870,690,240,150,870,120,870,120,870,690,210,150,870,120,870,690,240,150,870,690,240,750,240,150,870,120,840,690,240,150,870,690,240,750,240,750,240,150,840,120,6990;
20;33;DEBUG;Pulses=50;Pulses(uSec)=180,840,120,840,120,840,690,240,150,840,690,240,150,810,150,870,120,870,690,240,150,810,150,840,690,240,150,810,750,240,720,240,150,810,150,810,750,240,150,810,750,240,720,240,750,270,150,810,150,6990;
20;34;DEBUG;Pulses=50;Pulses(uSec)=210,780,150,810,150,810,750,240,150,840,720,240,150,840,150,810,150,840,720,240,150,840,150,840,720,240,150,840,720,270,780,270,180,870,150,840,750,240,150,840,750,270,810,300,870,300,210,900,150,6990;
20;35;DEBUG;Pulses=50;Pulses(uSec)=240,840,150,840,150,840,750,270,180,930,900,330,240,1080,210,990,180,960,900,330,270,1140,210,1050,1020,390,300,1260,1200,450,1530,570,480,1620,360,1380,1350,510,450,1650,1560,600,1980,720,2430,870,810,2610,630,6990;
Info van het deurcontact zonder de Debug aan.
20;57;Eurodomest;ID=0ebb4d;SWITCH=00;CMD=OFF;
20;58;EV1527;ID=0144b2;SWITCH=0e;CMD=ON;
20;59;Eurodomest;ID=0ebb4d;SWITCH=00;CMD=OFF;
20;5A;EV1527;ID=0144b2;SWITCH=0e;CMD=ON;
20;5B;Eurodomest;ID=0ebb4d;SWITCH=00;CMD=OFF;
20;5C;EV1527;ID=0144b2;SWITCH=0e;CMD=ON;
20;5D;Eurodomest;ID=0ebb4d;SWITCH=00;CMD=OFF;
20;5E;EV1527;ID=0144b2;SWITCH=0e;CMD=ON;
Het is hier off topic maar kan iemand mij ook een hint geven/of waar ik het kan vinden hoe ik deze switch in domoticz instel.
Vriendelijk Groeten Ton Rijnaard
Deur contact uit china Eurodomest
Re: Deur contact uit china Eurodomest
De eurodomest en de EV1527 codes zijn hetzelfde maar de ene is geinverteerd t.o.v. de andere.
Eurodomest;ID=0ebb4d , EV1527;ID=0144b2
de 2 ID's hexadecimaal opgeteld geven 0fffff daarom zijn ze elkaars complement.
Die eenvoudige deursensors geven alleen een signaal op het moment dat de magneet weggehaald wordt en niet als de magneet teruggeplaatst wordt. De lengte van de burst is ongeveer 1 seconde. Daarom wordt de code een keer of 10 herkend maar zowel eurodomest als EV1527 gebruiken hetzelfde soort codering (geinverteerd) maar met een verschillende lengte (timing) van een hoog+laag.
Het beste kun je in domoticz deze sensor als EV1527 aanmaken en als type een "Push On Button" je moet dan nog een delay invullen, de tijd in seconde's dat de schakelaar vanzelf weer uit gaat.
Users browsing this forum: No registered users and 45 guests
