Hi to all,
I've just tried updating some of my ESP8266-based nodes to V2.0.0-dev7 and discovered that the OpenHAB MQTT option is missing in the Controllers menu.
I've checked all the versions from V2.0.0-dev4 and they all seem to have OpenHAB missing.
Kind regards from David.
OpenHAB MQTT option missing
Forum rules
- dynamicdave
Re: OpenHAB MQTT option missing
openhab mqtt is only available if it is the first controller, when multiple controllers are available, like in the newest mega builds... so nothing is missing
- dynamicdave
Hi Krikk,
Thanks for your response - which explains why I couldn't "see" it.
Cheers from David.
Cheers from David.
- dynamicdave
Hi Krikk,
So this means my ESP8266 can only "talk" to ONE OpenHAB MQTT server?
Was there a reason to limit the number to one?
Thanks again for all your help.
Regards, David
Regards, David
currently yes i think, only one mqtt server, but this is because not everything has been adapted to the new mega feature with multiple controllers...
