Sonoff POW rule trigger for Current / Power
Posted: 23 Dec 2018, 01:06
by Sandominion
I try to use a Sonoff POW (R2 v1.0 with mega-20180826) for failure monitoring of a drainage pump. The pump is allways voltage supplied and switches itself on/off dependend on the water level. If the pump is working the Sonoff recognize the used current and even calculates the energy but I don't manage to use this for triggering a command like:
On Pumpe#Current>0 do ...
If I use an other device from my list everything works fine e.g.:
On Button#pressed>0 do ...
My settings for devices are:
Task: 1
Enabled: ✔
Device: Energy (AC) - CSE7766 [TESTING]
GPIO:
Values: Voltage: 239.15 Power: 36.90 Current: 0.16 Pulses: 12577.00
Task: 2
Enabled: ✔
Device: Switch input - Switch
GPIO: GPIO-0
Values: pressed: 1
Might this be somehow connected to the selected device type for current measurement 'Energy (AC) - CSE7766 [TESTING]'?
Any suggestions?
Re: Sonoff POW rule trigger for Current / Power
Posted: 23 Dec 2018, 08:33
by grovkillen
If you look in the log, what do you see?
Posted: 23 Dec 2018, 14:36
by Sandominion
grovkillen wrote:
23 Dec 2018, 08:33
Before I took the log I reduced the rule to focus on the problem:
rtttl,4:d=10,o=6,b=180:8c,8e,8g,c,e,g,8c,8e,8g //melody2buzzer
notify 2, Button_pressed_while_Power[Pumpe#Power] //Email ack
On Pumpe#Power>1 do
notify 2, Power_delta //Email ack
Logging: Info (2)
5259: EVENT: Pumpe#Voltage=236.77
5279: EVENT: Pumpe#Power=0.00
5293: EVENT: Pumpe#Current=0.00
5306: EVENT: Pumpe#Pulses=0.00
5334: SW : State 0.00
5336: EVENT: Button#pressed=0.00
5797: Current Time Zone: DST time start: 2019-03-31 02:00:00 offset: 120 minSTD time start: 2019-10-27 03:00:00 offset: 60 min
5798: EVENT: Time#Initialized
5815: EVENT: Clock#Time=Wed,23:35
17047: SW : Switch state 0 Output value 1
17049: EVENT: Button#pressed=1.00
17056: ACT : rtttl,4:d=10,o=6,b=180:8c,8e,8g,c,e,g,8c,8e,8g
18458: SW : rtttl,4:d=10,o=6,b=180:8c,8e,8g,c,e,g,8c,8e,8g
18495: ACT : notify 2, Button_pressed_while_Power0.00
The trigger for Button works well. There comes a melody from the Buzzer and an Email. After that I switched on the device to drain power without any trigger reaction. It seemed that the log was frozen. After refresh for the log I managed to catch another one (and pressed the Button again):
Logging: Info (2)
229537: ACT : notify 2, Button_pressed_while_Power36.36
229571: SW : Switch state 1 Output value 0
229573: EVENT: Button#pressed=0.00
229679: Command: notify
230748: Timeout while reading input data!
231748: Timeout while reading input data!
232748: Timeout while reading input data!
233898: EMAIL: Connection Closed Successfully
235912: EVENT: Clock#Time=Wed,23:39
242045: SW : Switch state 0 Output value 1
242048: EVENT: Button#pressed=1.00
242054: ACT : rtttl,4:d=10,o=6,b=180:8c,8e,8g,c,e,g,8c,8e,8g
243455: SW : rtttl,4:d=10,o=6,b=180:8c,8e,8g,c,e,g,8c,8e,8g
243491: ACT : notify 2, Button_pressed_while_Power36.32
243576: SW : Switch state 1 Output value 0
243578: EVENT: Button#pressed=0.00
243650: WD : Uptime 4 ConnectFailures 0 FreeMem 19384
243656: Command: notify
244725: Timeout while reading input data!
245725: Timeout while reading input data!
246725: Timeout while reading input data!
247875: EMAIL: Connection Closed Successfully
272296: WD : Uptime 5 ConnectFailures 0 FreeMem 19752
295914: EVENT: Clock#Time=Wed,23:40
