UART parser plugin
ilmz
UART parser plugin
#1 Post by ilmz » 09 Jan 2019, 11:33
Hello everyone, I study EasyESP, and read this forum a lot. I apologize for my bad english.
I need to take a data package on USART from an external microcircuit and parse it. When programming the ESP 8266 in Arduino IDE as a conventional microcontroller and succeeded in this matter.
My task is to parse the data in the EasyESP, and output several values.
Should I write my own plugin?
If so, can anyone show me examples of plugins with the parsing process?
Or can I use standard tools?
I want to talk a little about the protocol. 24 bytes are received. payload is from 3 to 20 bytes. 3 bytes for each value I need.
Configuration USART - 1 start bit, 1 stop bit, 8 data bits, parity bit - EVEN. Connection speed 4800
Domosapiens
Re: UART parser plugin
#2 Post by Domosapiens » 09 Jan 2019, 11:48
ilmz
#3 Post by ilmz » 12 Jan 2019, 07:41
Domosapiens wrote:
09 Jan 2019, 11:48
Not a direct help,but:
This could be worth reading:
https://github.com/letscontrolit/ESPEasy/issues/1588
Plugin template:
https://github.com/letscontrolit/ESPEas ... mplate.ino
Thank you. My task is done. _P077_CSE7766.ino file have parse algorithm with Serial settings.
Users browsing this forum: Bing [Bot] and 2 guests
