Maybe someone has a good idea here ?
I want to install some LED Stripes that
- are controlled by a PIR
- fade up / down
- i could manually switch them on by a http command
- i could manually inhibit them to switch on
the PIR on / off should be directly in ESPEasy, not by a external server
I guess this could be done by one / some pretty long rules, anybody did this before ?
Please submit also parts of this routine, maybe i could puzzle them together myself
Dim up / down LED by a rule ?
Re: Dim up / down LED by a rule ?
I think thats you can do it, can you read this document before?
http://www.esp8266.nu/index.php/Tutorial_Rules
I saw the rules explanation, even have some ESP with rules running
But, is there a command to dim up / down ?
Or do i have to do it manually with a counter and a formula ?
commandArray = {}
-- Check for wifidimmer changed
DomDevice = 'wifidimmer'
for i, v in pairs(devicechanged) do
if (i == DomDevice) then
if (v == 'Off') then DomValue = 0
commandArray['OpenURL']='http://192.168.0.44/control?cmd=PWM,0,0,1024'
print("test")
DomValue = otherdevices_svalues[DomDevice]
CalcValue = DomValue*33
print(CalcValue)
url= 'http://192.168.0.44/control?cmd=PWM,0,' .. CalcValue ,'1024'
print (url);
--commandArray['SendNotification']="test"
commandArray['OpenURL']= url
end
end
end
Users browsing this forum: Bing [Bot] and 56 guests
