Page 1 of 2
Re: Wifi Candle - illuminate with ESPEasy (WS2812)
Posted: 31 Oct 2016, 14:25
by tozett
snow wrote:It's possible to use FastLED library instead of Adafruit_NeoPixel in your sketch?
FastLED supports basically all types of LED controllers, including NeoPixel ws28121B
hi dominik,
consider to use fastled lib (to play with?) as an alternative.
i found color-palettes very playful. you can change colors without chaning code for animation...
may have a look here and in the demo
https://github.com/FastLED/FastLED/wiki ... r-palettes
Posted: 01 Nov 2016, 18:52
by tozett
you got me starting again with espeasy and leds....
an actual finding, mabye of interest
+1
https://github.com/jasoncoon/esp8266-fastled-webserver
Posted: 23 Nov 2016, 09:25
by Mariete
Hello @moelski
Thank you very much for sharing your work.
I had it running in almost no time (5 minutes?) following your instructions.
Do you have plans to implement the Fire2012 algorithm? Or maybe some other person already did (being it integrated in Wifi Candle or just as a separate plugin)?
It would bee good to be able to adjust the strip's number of pixels.
I have plans to convert two old Ikea Kyoto lamps to WS2812 led strip and this effect is just what I need.
I already looked at the code but it's too complex for me to try to include the Fire2012.
Posted: 24 Nov 2016, 19:19
by moelski
Hi @all,
I had some busy days in the last weeks so I was not really able to follow all questions here ...
But it seems that there are some guys which have problems getting the candle up und running :o
So i think it would be the best to write a new tutorial with all steps explained in detail.
Hopefully my english skills will stand this adventure :D
@Mariete
Fire2012 algorithm
Will see ... Maybe in December. The main problem is that the Fire Simulation needs a lot more speed for running.
And the code is not so easy ... Maybe I give it a try ...
That would be a good extension ... But again ... I can do it in december. no time before ...
I can check that ....
Ok guys ... Let me write the tutorial ... And hopefully all problems are solved ... :ugeek:
Posted: 27 Nov 2016, 09:05
by r_255
Hi Moelski,
We all have our favorite animation, and mine is disco :D
Would it be a sugestion to implement artnet as protocol for the ws2812/neopix ?
https://github.com/rstephan/ArtnetWifi/ ... oPixel.ino
Artnet is a protocol that is like dmx and there is many free software out there that does Fire, animated gifs, videos, or any other led candy, music controlled or even ambilight.
http://www.solderlab.de/index.php/software/glediator
http://www.live-leds.de/
Yes, i did try to make a plugin myself based on martinus his neopixel plugin, but failed hard. Some how i do understand, and can identify the blocks of code in general. But changing the neopixel plugin to the artnet code is just to much for my head.
Posted: 30 Nov 2016, 18:31
by TMS
How do i controll this with Domoticz?
Posted: 22 Dec 2016, 16:19
by burton666
I am having some troubles getting this to work. The steps I have taken:
1: download ESP Easy 147 firmware.
2: Edit all files as the info says in the sketch
3: copy _P121_Candle.ino to ..\Source\ESPEasy -folder
3: Flash to ESP8266
4: use <IP>/upload the jscolor.min.js...
5: Neopixel is already installed if I understand correctly? In 147 there is already a folder called neopixel in libraries.
But I get no option to select candle/wifi candle under devices.
Posted: 29 Dec 2016, 06:05
by moelski
Hi burton666,
will check it today. I´m actually working on embedding the candle into my FHEM homeautomatisation system.
I will compile it with 147 and see if there are any problems left ...
Posted: 29 Dec 2016, 08:04
by moelski
Hi @all,
have done some work to enhance the documentation:
http://www.logview.info/Temp/CandleNotes.pdf
I will update the doc with information how to Setup FHEM and how to use MQTT.
Posted: 29 Dec 2016, 10:10
by Mariete
I implemented the Fire2012 algorithm and it's working now.
I don't like the effect very much at the moment. May be it has something to do with the color mapping, not sure.
Give me some time to see if I can fix the color mapping issue and clean the code and I'll upload it to the playground (or just live the code here if it doesn't deserves a plugin).
You can see the effect here: https://youtu.be/KVLsspIZyyk
Posted: 29 Dec 2016, 10:35
by moelski
Hi Mariete,
looks nice, but I think the main problem is that it´s a fire simulation.
And at y candle you don´t have this huge flame nor such sparkles flying around...
Did you include it into my code?
Posted: 29 Dec 2016, 10:40
by Mariete
moelski wrote:Hi Mariete,
I tried at first to include it into your code but I found it to be more difficult so I started from scratch (with the Martinu's WS2812 plugin).
If you want I can send you the code to include it into your code. I will be easy for you, I guess.
Posted: 29 Dec 2016, 10:49
by moelski
Ok you can send it to dominik AT logview DOT info.
I will have a look.
Posted: 29 Dec 2016, 11:01
by Mariete
moelski wrote:Ok you can send it to dominik AT logview DOT info.
I will have a look.
Sent!
I added (for a smother effect) a PLUGIN_SIXTY_PER_SECOND.
I sent to you also the latest ESPEasy.ino and __Plugin.ino I used to compile it, just in case I modified something more I don't remember.
Posted: 31 Dec 2016, 14:46
by burton666
I am going to try again with the candle, but before I start again was it possible to specify how many leds that are used ? or do I need a specific number of leds?
Posted: 07 Jan 2017, 10:25
by m.lamie
@Moelski, great project, i followed the setup notes and can report it is working as expected :D
Is there a way to have it included in Domoticz and control it like the MiLight?
Posted: 09 Jan 2017, 00:29
by paulymorph
I have followed the instructions very carefully and I am getting the following compile error. I've tried it on a PC and on Mac and on Arduino 1.6.5 (i believe) and now on 1.8. PLEASE HELP. I've been beating my head against the wall for 3 hours trying to get this to work.
D:\Users\ESPEasy_R120 wplugin\Source\ESPEasy\WebServer.ino: In function 'void WebServerInit()':
WebServer:19: error: 'handle_upload_post' was not declared in this scope
WebServer.on("/upload", HTTP_POST, handle_upload_post, handleFileUpload);
exit status 1
Posted: 10 Jan 2017, 03:29
by paulymorph
ok, so i found the other threads (here and here) on problems with compiling with SPIFFS set to true. Like others, by disabling SPIFFS I was able to compile and get it loaded and working on my esp8266 but I would like to solve the mystery of why it won't compile.
Additionally and (for me), more important, is that I'm trying to figure out how control the color and brightness via MQTT commands but I can not figure out the right format to publish so that the device will respond. In the advanced menu (under Tools), you see that the subscribe template is /%sysname%/#. Someone mentioned that this format would work ("/<%sysname%>/cmd"), but i've not been able to get it to work. I've published numerous ways with no result.
/sysname/Brightness
/sysname/candle/Brightness
/sysname/cmd/Brightness
all with a value of between 1 and 255 but nothing is working. If anyone knows, can you please send exactly what you're using?
Posted: 10 Jan 2017, 18:40
by paulymorph
Another update on my progress. I've successfully complied and enabled SPIFFS by following Moelski's updated instructions here. The primary difference is that I had to use build 147 versus 120 but i'm fine with that.
Next, MQTT... I also compiled and loaded the MQTT Import plugin (and Extra Utilities) which appear to have successfully installed. Now, i'm trying to figure out how to publish (externally) to an MQTT topic such as /node2/candle/Brightness and have WiFi Candle brightness be adjusted accordingly without having to go through the UI of the ESP.
My goal is to create a Dashboard in Node-Red with buttons that will publish MQTT messages to the topics the ESP is subscribed to and to have the payload change the values on the Wifi Candle. I feel like i'm very close and am wondering if I need to use a combination of the MQTT_Import feature as well as a Rule on the device to change the value of the Candle Brightness based on the MQTT Import message. Here are some screen shots of what I have so far. You can see that on my MQTT Import item, It is reading the 'Brightness' value that I published out of MQTT Spy...
Screen Shot 2017-01-10 at 11.24.07 AM.png (127.08 KiB) Viewed 79813 times
Screen Shot 2017-01-10 at 11.21.03 AM.png (52.77 KiB) Viewed 79813 times
Screen Shot 2017-01-10 at 11.27.50 AM.png (82.06 KiB) Viewed 79813 times
Screen Shot 2017-01-10 at 11.19.33 AM.png (54.91 KiB) Viewed 79813 times
Posted: 10 Jan 2017, 20:03
by jjansen
I just saw some additional comments in the source code of the plugin about MQTT
Starting at line 454
Might be useful for you?
// Test
        // MQTT   : mosquitto_pub -d -t sensors/espeasy/ESP_Candle/cmd  -m "CANDLE_OFF"
        // HTTP   : http://192.168.30.183/tools?cmd=CANDLE%3A5%3AFF0000%3A200
        //          http://192.168.30.183/tools?cmd=CANDLE:4:FF0000:200
        // SERIAL : CANDLE:4:FF0000:200<CR><LF>
        // Commands
        // CANDLE:<FlameType>:<Color>:<Brightness>
        //    <FlameType>  : 1 Static Light, 2 Simple Candle, 3 Advanced Candle, 4 Police, 5 Blink, 6 Strobe, 7 Color Fader
        //    <Color>      : n.def.  Use the default color
        //                   RRGGBB  Use color in RRGGBB style (red, green blue) as HEX
        //    <Brightness> : 0-255
        // Samples:   CANDLE:2::100           Simple Candle with Default color and Brigthness at 100
        //            CANDLE:5:FF0000:200     Blink with RED Color and Brigthness at 200
        //            CANDLE:0::              Candle OFF
        //            CANDLE:1::255           Candle ON - White and full brigthness
Posted: 11 Jan 2017, 00:54
by paulymorph
Thank you very much jjansen. This is definitely progress. Already have a quick success using the HTTP method. Now i'll play with the MQTT examples to see if I can get the syntax right.
jjansen wrote:I just saw some additional comments in the source code of the plugin about MQTT
Posted: 11 Jan 2017, 08:02
by paulymorph
SUCCESS!!! I was able to get it all working except for one small thing. I created a Dashboard in Node-Red that can control all the attributes of the Wifi Candle all by sending formatted MQTT messages when I press the button on the dashboard after i have all the settings that I like.
The format for the MQTT message is the following
Topic:
/node2/candle/cmd Node2=device name, candle=The name i gave the Wifi Candle (called "Device" in ESP Easy), cmd= the operator that Moelski wrote into the code.
Message:
COLOR:2:8E3EFF:120 COLOR=static : 2 (Flame Type) : 8E3EFF (Hex color) : 120 (Brightness value 1-255)
The only thing i couldn't get to work is mode 7 (Color fader). It doesn't seem to work if I try that mode.
I'm glad to share the actual JSON of the flow if anyone is interested.
Screen Shot 2017-01-11 at 12.50.30 AM.png (79.06 KiB) Viewed 52297 times
Screen Shot 2017-01-11 at 12.57.01 AM.png (101.64 KiB) Viewed 52297 times
Posted: 11 Jan 2017, 08:32
by moelski
Great work Paul.
I think there is one command missing for using default colors or not.
But that is missing in the sources ... I have to add that in the next days.
Anyway ... Your solution looks great.
Personally I use FHEM and I will update my manual for FHEM usage, too.
Posted: 11 Jan 2017, 21:43
by paulymorph
Thanks moelski! I actually have a solution for the default colors... if I send the MQTT payload with nothing in the space for color, it reverts to the default color. Example "COLOR:2::100".
BTW! Do you have an idea why mode 7 doesn't appear to work? It works if I manually change it from the ESP EASY interface (I think). I know it was working on R120 at least.
Posted: 18 Jan 2017, 20:41
by nygma
On a different topic I was asking if a fade function can be made available for the PWM output. Can this candle logic be adapted output the values to 3 GPIOs using PWM instead of neopixel?
Posted: 23 Jan 2017, 13:58
by medline2c
Bonjour !
Félicitations pour ce beau projet... profil bas...
Je suis sur Jeedom avec plugIn EspEasy et je voulais savoir du coup, ayant lu plein de choses sur les ws8212 suite à cet article :
Les librairies ws8212 seraient peu compatibles avec les communications séries (I2C...) : qu'en est-il avec ce programme ? peut-on quand même piloter un afficher LED/OLED ou un lecteur RFID en I2C ou c'est mort...
Autre question : vous me confirmez bien qu'avec la première bibliothèque, je peux néanmoins piloter individuellement des néopixels mais du coup dans la limite de 12 maxi (limitation espeasy sur nombre de devices) ?...
Merci ... je suis ce post avec gourmandise !... bonne continuation !
Christophe
Google traduction :
Hello !
Congratulations for this beautiful project ...
I am on Jeedom with plugIn EspEasy and I wanted to know of the coup, having read many things about the ws8212 following this article:
The libraries ws8212 would be poorly compatible with the serial communications (I2C ...): what is with this program? Can you still drive an LED / OLED display or an RFID reader in I2C or it isn't possible ...
Another question: you confirm to me that with the first library, I can nevertheless drive neopixels but within the limit of 12 maxi (limitation of espeasy on many devices)?
Thank you ... I am this post with gluttony! ... good continuation!
Christophe
Posted: 23 Jan 2017, 14:27
by Barb232
Hi Dominik,
can you send me a link from your manual?
i cant get it working the MQTT and the Candle (using MEGA EasyESP)
Posted: 23 Jan 2017, 19:07
by groovy
I built this candle and it works fine, thanks for sharing!
However, I want to use it with a PIR to enable/disable it when movement is detected.
The whole background and questions can be found on my original post, but maybe here is a better place to ask.
In summary, I want to switch the candle on, when movement is detected and switch it off after a period of time.
Any suggestions?
Posted: 24 Jan 2017, 00:26
by medline2c
Bonsoir !
Je suis en train de tester avec un NodeMCUV1.0.
Cela fonctionne à priori, sauf que lorsque le Node envoie une trame en HTTP à Jeedom, cela stoppe l'animation puis cela repart ensuite.. est-ce normal ? (communication série = interruption ?)
Ensuite, je ne parviens pas à trouver comment piloter via Jeedom la WifiCandle ?... Pouvez-vous m'indiquer la requête HTTP à exécuter ?..
Pour terminer, j'aimerais tester le pilotage d'un NeoPixel en HTTP, comment faire depuis Jeedom étant donné que l'on n'a pas l'option "Send data" quand on choisi ce type de device ?
Merci pour votre aide.
Christophe
Good evening!
I'm trying to test with a NodeMCUV1.0. It seem work good, except when the Node sends an HTTP frame to Jeedom : animation stop and then it starts again .. is this normal? (Serial communication = interruption?)
Then, I can not find how to drive via Jeedom the WifiCandle ... Can you tell me the HTTP request to run ? I've only "info" data send to jeedom but how do the same to the WifiCandle ? I don't understand...
Finally, I would like to test the control of only one NeoPixel with an HTTP command (with NeoPixel Basic installed), how to do withJeedom : I don't find the option "Send data" when choosing this type of device?
Thank you for your help.
Christophe
Posted: 25 Jan 2017, 18:08
by medline2c
Bonsoir,
Je me réponds partiellement à moi même (avis aux débutants tout petit niveau comme moi...) :
J'ai passé plusieurs heures à essayer de comprendre comme tout ça fonctionnait et j'ai réussi par Jeedom à commander la WifiCandle. Il suffit d'inclure dans le plugIn EspEasy la WifiCandle puis d'ajouter dans l'onglet COMMANDES, une commande d'action avec dans la zone "Task et variable" une ligne du style "CANDLE:2::100" pour activer le mode bougie simple avec une luminosité de 100... cela va faire apparaître des boutons pour changer le mode... je n'ai pas trouvé comment faire un curseur pour la couleur mais je cherche...
La question que je me pose toutefois est la suivante :
Etant donné qu'on ne peut gérer d'interruptions, on utilise la fonction millis() ... mais que ce passe-t-il au bout de plusieurs jours d'utilisation, quand la valeur de millis() va revenir à zéro... je n'ai rien vu qui prévoit le cas... :
Candle_Update = millis() + 150;
(~ligne 402)
J'ai raté quelque chose ?...
Christophe
Good evening,
I respond partially to myself (notice to beginners a little level like me ...):
I spent several hours trying to figure out how it all worked and I managed by Jeedom to order the WifiCandle. It is enough to include in the plugin EspEasy the WifiCandle then to add an action command in the "Task and variable" section of the "CANDLE: 2" :: 100 "to activate the simple candle mode with a brightness of 100 ... this will bring up buttons to change the mode ... I have not found how to make a slider for color but I'm looking for ...
The question I ask myself, however, is this:
Since we can not handle interrupts, we use the function millis () ... but it happens after several days d Use, when the value of millis () will return to zero ... I have not seen anything that provides the case ...:
 Candle_Update = millis () + 150;
(~ line 402)
Did I miss something ?...
Christophe
Posted: 31 Jan 2017, 08:09
by groovy
Is it possible to disable saving the settings to flash every time anything is changed?
I'm asking this, because my candle switches on and off many times, so I'm afraid killing the flash really soon.
Can I simply remove these two lines from the code at around line 530?
SaveTaskSettings(event->TaskIndex);
SaveSettings();
Does this have any other impact? Or should I only remove the second line and leave the first? I'm unsure, so can someone point me at the right direction?
Posted: 10 Apr 2017, 17:29
by marko67
Hello I need your help.
I am using R147 with the extension _p121 candle. A WS2812B strip with 30 neopixel. Is controlled by FHEM.
my question:
How can I control 1-10 led in red 11-20 led in blue and 21-30 led in white control. Is this only with _P122_NeoPixel.ino and if so how?
many thanks for your help
Marko
Posted: 13 Apr 2017, 13:12
by passie
Got the candle working via de esp web gui.
Which command's should be send in order to control the light via mqqt from ex pimatic or any other home automation software ?
I would like to control the led's with an if statement.
So for example:
If temp is > 20 celcius then make the leds red / flash.
-- passie
Posted: 25 Apr 2017, 23:44
by rolfz
Just realised that my question was answered on m Post #54.
Hi Paul, great work,
Would it be possible to post the node-red (JSON) code for your solution ? I did not yet get the details about how to setup the message COLOR:2:8E3EFF:120
//Rolf
Posted: 27 Apr 2017, 09:01
by passie
What is the complete mqtt message which has to be send in order to ex. change color ?
Currently i'm able to send mqtt pub to easpeasy like so:
mosquitto_pub -d -h 127.0.0.1 -t mosquitto_pub -h 127.0.0.1 -t /home/candle/Color/cmd -m 'FF0000'
mosquitto_pub -d -h 127.0.0.1 -t mosquitto_pub -h 127.0.0.1 -t /home/candle/Brightness/cmd -m '11'
mosquitto_pub -d -h 127.0.0.1 -t mosquitto_pub -h 127.0.0.1 -t /home/candle/Type/cmd -m '2'
This is working for individual mqtt messages.
But how could i send the complete string to the espeasy so it changes color or do something else ?
Any help would be appreciated.
-- passie
Posted: 27 Apr 2017, 09:56
by Dylantje
Is this option available in the normal EspEasy flash?
Posted: 29 Apr 2017, 08:52
by passie
Dylantje wrote: 27 Apr 2017, 09:56 Is this option available in the normal EspEasy flash?
No it isn't.
Posted: 29 Apr 2017, 08:57
by passie
I'm trying different pub's but i'm unable to get it working via mqtt
mosquitto_pub -h 127.0.0.1 -t /home/candle/ -m "cmd=CANDLE:1:00FF00:100"
Via a curl I can control the neopixel.
set_candle_above: 'curl --data "cmd=CANDLE:3:FF0000:200" http://192.168.0.3/control'
Any clue points here ?
Posted: 30 Apr 2017, 09:35
by artic1980
You can check it through domoticz
Posted: 30 Apr 2017, 11:08
by passie
artic1980 wrote: 30 Apr 2017, 09:35 You can check it through domoticz
I'm trying to send the mqtt pub message not the integration with domoticz!?
Posted: 28 Jun 2017, 22:43
by helio58
paulymorph wrote: 11 Jan 2017, 08:02 SUCCESS!!! I was able to get it all working except for one small thing. I created a Dashboard in Node-Red that can control all the attributes of the Wifi Candle all by sending formatted MQTT messages when I press the button on the dashboard after i have all the settings that I like.
Topic:
Message:
Screen Shot 2017-01-11 at 12.50.30 AM.pngScreen Shot 2017-01-11 at 12.57.01 AM.png
Please could you share the Json of the flow?
Posted: 28 Sep 2017, 17:30
by papperone
I was giving some test to this plugin and I realize I can't get the "color picker" in any on the browser I checked (Chrome, FF, IE and Edge) as shown in the video on the first post.
As well the RGB selct arrows "up/down" are not shown in EDGE while they are in all other browser.
I understand is not a real ESPEasy bug but as far as I can see this plugin is uding java to create special devive page which is not wokring as it shoudl...
Can anyone test it as well? Or maybe better someone that is using this plugin has succeed to get the color picker enabled?
Posted: 23 Mar 2018, 19:49
by Speshal
jjansen wrote: 10 Jan 2017, 20:03 I just saw some additional comments in the source code of the plugin about MQTT
// Test
        // Commands
Thanks so much for this, it helped me immensely! :D
Posted: 31 Mar 2018, 01:08
by sjaak538
Is it possible to make
#define NUM_PIXEL 20 // Defines the amount of LED Pixel
#define NUM_PIXEL_ROW 5 // Defines the amount of LED Pixel per Row
editable in the webform ?
I have a led matrix 8x8 and no programming skills
Thanks in advance
Posted: 02 May 2018, 05:27
by jonathan-orsel
I made some updates on your plugin for my own usage :
> Led count and column count in plugin configuration (need a restart to apply)
> Some more effects ( find some inspiration at https://www.tweaking4all.com/hardware/a ... p-effects/ )
Feel free to take these changes.
works great with these LED strip https://www.aliexpress.com/item/1m-4m-5 ... autifyAB=0
#ifdef USES_P042
//######################################## Plugin 042: NeoPixel Candle ##################################
// PROJECT INFO
// Wifi Candle for ESPEasy by Dominik Schmidt (10.2016)
// INCLUDE jscolor (http://jscolor.com/)
//   * Download the lib from here: http://jscolor.com/release/latest.zip
//   * Extract jscolor.min.js
//   * Now open the Web UI of your ESPEasy with this URL:
//     http://<IP-ESPEasy>/upload
//   * Select Browse ... and choose the extracted jscolor.min.js File (ensure the ...min... version !!)
//   * Press Upload und you are done.
// Add the Adafruit Neopixel Library to your library path. You will find it here:
// https://github.com/adafruit/Adafruit_NeoPixel
// That´s all :-) Now ESPEasy has a new 25ms "Timer loop" and Neopixel Support.
// NOTES
// Please keep in mind that you can add tasks which produce a very large delay while reading the sensor.
// For example the DS18B20 is very slow in reading the values. This can slow down the simulation and you
// will notice that the candle did not run smooth. So keep an eye on your tasks and don't add to much other tasks.
// HARDWARE
// The Wifi Candle uses 20 WS2812 RGB pixels. They are all connected in one row.
// I build a wooden wick with 5 pixels on each side. (A picture is here : http://www.esp8266.nu/forum/viewtopic.php?f=2&t=2147)
// The pixels are connected to 5V and the data pin I use is GPIO13 (but you can choose another one).
// Please ensure that you use a strong power supply because the pixels consume a lot of power when they
// shine in white with high brightness!
// I also placed a 100µF capacitor at the end of the WS2812 chain on +5/GND just to ensure a good power stability.
// btw ... My Testboard was a NodeMCU V3.
// QUESTIONS
// Send me an email at dominik@logview.info
// or place a comment in the Forum:
// http://www.esp8266.nu/forum/viewtopic.php?f=2&t=2147
// Candle Infos
// http://www.howtodotip.com/how+to+do+arduino+candle++3
// https://codebender.cc/sketch:129316#Neopixel%20Candle.ino
// http://www.instructables.com/id/Garden-Arduino-Lights/?ALLSTEPS                    Garten Beleuchtung
// http://www.instructables.com/id/Arduino-Controlled-Electric-Candle/?ALLSTEPS       InstaMorph Kerze
// https://github.com/danesparza/Halloweenfire/blob/master/halloweenfire.ino          Halloweenfire
// RGB / HSV Converter
// https://github.com/ratkins/RGBConverter          Lib
// https://www.ruinelli.ch/rgb-to-hsv               Code
// http://stackoverflow.com/questions/3018313/algorithm-to-convert-rgb-to-hsv-and-hsv-to-rgb-in-range-0-255-for-both    Code Sammlung
#include <Adafruit_NeoPixel.h>
//#define NUM_PIXEL       150         // Defines the amount of LED Pixel
//#define NUM_PIXEL_ROW    1         // Defines the amount of LED Pixel per Row
int NUM_PIXEL =      150 ;        // Defines the amount of LED Pixel
int NUM_PIXEL_ROW =   1   ;      // Defines the amount of LED Pixel per Row
#define RANDOM_PIXEL    70         // Defines the Flicker Level for Simple Candle
#define BRIGHT_START   128         // Defines the Start Brightness
#define BASE_TEMP       21         // Defines the Base Temp for TempRange Transformation
enum SimType {
  TypeOff,
  TypeSimpleCandle,
  TypeAdvancedCandle,
  TypeStaticLight,
  TypePolice,
  TypeBlink,
  TypeStrobe,
  TypeColorFader,
  TypeCylon,
  TypeSparkle,
  TypeRainbow,
  SIMTYPE_LEN
enum ColorType {
  ColorDefault,
  ColorSelected
byte Candle_red = 0;
byte Candle_green = 0;
byte Candle_blue = 0;
byte Candle_bright = 128;
SimType Candle_type = TypeSimpleCandle;
ColorType Candle_color = ColorDefault;
// global variables
unsigned long Candle_Update = 0;
word Candle_Temp[4] = { 0, 0, 0 };     // Temp variables
int Candle_Temp4 = 0;
boolean GPIO_Set = false;
Adafruit_NeoPixel *Candle_pixels;
#define PLUGIN_042
#define PLUGIN_ID_042         42
#define PLUGIN_NAME_042       "Output - NeoPixel (Candle)"
#define PLUGIN_VALUENAME1_042 "Color"
#define PLUGIN_VALUENAME2_042 "Brightness"
#define PLUGIN_VALUENAME3_042 "Type"
boolean Plugin_042(byte function, struct EventStruct *event, String& string)
  boolean success = false;
  switch (function)
    case PLUGIN_DEVICE_ADD:
        Device[++deviceCount].Number = PLUGIN_ID_042;
        Device[deviceCount].Type = DEVICE_TYPE_SINGLE;
        Device[deviceCount].VType = SENSOR_TYPE_TRIPLE;
        Device[deviceCount].ValueCount = 3;
        Device[deviceCount].GlobalSyncOption = false;
    case PLUGIN_GET_DEVICENAME:
        string = F(PLUGIN_NAME_042);
        strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_VALUENAME1_042));
        strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[1], PSTR(PLUGIN_VALUENAME2_042));
        strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[2], PSTR(PLUGIN_VALUENAME3_042));
    case PLUGIN_WEBFORM_LOAD:
        string += F("<script src=\"jscolor.min.js\"></script>\n");
        char tmpString[128];
        String options[SIMTYPE_LEN];
        // int optionValues[8];
        options[0] = F("Off");
        options[1] = F("Static Light");
        options[2] = F("Simple Candle");
        options[3] = F("Advanced Candle");
        options[4] = F("Police");
        options[5] = F("Blink");
        options[6] = F("Strobe");
        options[7] = F("Color Fader");
        options[8] = F("Cylon");
        options[9] = F("Sparkle");
        options[10] = F("Rainbow");
        byte choice = Settings.TaskDevicePluginConfig[event->TaskIndex][4];
        if (choice > sizeof(options) - 1)
          choice = 2;
        // strip properties selection
        addFormNumericBox(string,F("Led Count"), F("web_Leds"), Settings.TaskDevicePluginConfig[event->TaskIndex][6],1,999);
        addFormNumericBox(string,F("Led per columns"), F("web_Columns"), Settings.TaskDevicePluginConfig[event->TaskIndex][7],1,999);
        // Candle Type Selection
        addFormSelector(string, F("Flame Type"), F("web_Candle_Type"), SIMTYPE_LEN, options, NULL, choice);
        // Advanced Color options
        Candle_color = (ColorType)Settings.TaskDevicePluginConfig[event->TaskIndex][5];
        string += F("<TR><TD>Color Handling:<TD>"); // checked
        string += F("<input type='radio' id='web_Color_Default' name='web_Color_Type' value='0'");
        if (Candle_color == ColorDefault) {
          string += F(" checked>");
        } else {
          string += F(">");
        string += F("<label for='web_Color_Default'> Use default color</label><br>");
        string += F("<input type='radio' id='web_Color_Selected' name='web_Color_Type' value='1'");
        if (Candle_color == ColorSelected) {
        } else {
          string += F(">");
        string += F("<label for='web_Color_Selected'> Use selected color</label><br>");
        // Color Selection
        char hexvalue[7] = {0};
        sprintf(hexvalue, "%02X%02X%02X",     // Create Hex value for color
                Settings.TaskDevicePluginConfig[event->TaskIndex][0],
                Settings.TaskDevicePluginConfig[event->TaskIndex][1],
                Settings.TaskDevicePluginConfig[event->TaskIndex][2]);
        // http://jscolor.com/examples/
        string += F("<TR><TD>Color:<TD><input class=\"jscolor {onFineChange:'update(this)'}\" value='");
        string += hexvalue;
        string += F("'>");
        addFormNumericBox(string, F("RGB Color"), F("web_RGB_Red"), Settings.TaskDevicePluginConfig[event->TaskIndex][0], 0, 255);
        addNumericBox(string, F("web_RGB_Green"), Settings.TaskDevicePluginConfig[event->TaskIndex][1], 0, 255);
        addNumericBox(string, F("web_RGB_Blue"), Settings.TaskDevicePluginConfig[event->TaskIndex][2], 0, 255);
        // Brightness Selection
        string += F("<TR><TD>Brightness:<TD>min<input type='range' id='web_Bright_Slide' min='0' max='255' value='");
        string += Settings.TaskDevicePluginConfig[event->TaskIndex][3];
        string += F("'> max");
        sprintf_P(tmpString, PSTR("<TR><TD>Brightness Value:<TD><input type='text' name='web_Bright_Text' id='web_Bright_Text' size='3' value='%u'>"), Settings.TaskDevicePluginConfig[event->TaskIndex][3]);
        string += tmpString;
        // Some Javascript we need to update the items
        string += F("<script script type='text/javascript'>");
        string += F("function update(picker) {");
        string += F("    document.getElementById('web_RGB_Red').value = Math.round(picker.rgb[0]);");
        string += F("    document.getElementById('web_RGB_Green').value = Math.round(picker.rgb[1]);");
        string += F("    document.getElementById('web_RGB_Blue').value = Math.round(picker.rgb[2]);");
        string += F("}");
        string += F("</script>");
        string += F("<script type='text/javascript'>window.addEventListener('load', function(){");
        string += F("var slider = document.getElementById('web_Bright_Slide');");
        string += F("slider.addEventListener('change', function(){");
        string += F("document.getElementById('web_Bright_Text').value = this.value;");
        string += F("});");
        string += F("});</script>");
        success = true;
    case PLUGIN_WEBFORM_SAVE:
        Settings.TaskDevicePluginConfig[event->TaskIndex][6] = getFormItemInt(F("web_Leds"));
        Settings.TaskDevicePluginConfig[event->TaskIndex][7] = getFormItemInt(F("web_Columns"));
        NUM_PIXEL = Settings.TaskDevicePluginConfig[event->TaskIndex][6] ;         // Defines the amount of LED Pixel
        NUM_PIXEL_ROW = Settings.TaskDevicePluginConfig[event->TaskIndex][7];       // Defines the amount of LED Pixel per Row
        Settings.TaskDevicePluginConfig[event->TaskIndex][0] = getFormItemInt(F("web_RGB_Red"));
        Settings.TaskDevicePluginConfig[event->TaskIndex][1] = getFormItemInt(F("web_RGB_Green"));
        Settings.TaskDevicePluginConfig[event->TaskIndex][2] = getFormItemInt(F("web_RGB_Blue"));
        Settings.TaskDevicePluginConfig[event->TaskIndex][3] = getFormItemInt(F("web_Bright_Text"));
        Settings.TaskDevicePluginConfig[event->TaskIndex][4] = getFormItemInt(F("web_Candle_Type"));
        Settings.TaskDevicePluginConfig[event->TaskIndex][5] = getFormItemInt(F("web_Color_Type"));
        Candle_red = Settings.TaskDevicePluginConfig[event->TaskIndex][0];
        Candle_green = Settings.TaskDevicePluginConfig[event->TaskIndex][1];
        Candle_blue = Settings.TaskDevicePluginConfig[event->TaskIndex][2];
        if (Candle_bright > 255) {
          Candle_bright = 255;
        Candle_bright = Settings.TaskDevicePluginConfig[event->TaskIndex][3];
        Candle_type = (SimType)Settings.TaskDevicePluginConfig[event->TaskIndex][4];
        success = true;
    case PLUGIN_INIT:
        NUM_PIXEL_ROW = Settings.TaskDevicePluginConfig[event->TaskIndex][7] ;     // Defines the amount of LED Pixel per Row
        if (Candle_red == 0 && Candle_green == 0 && Candle_blue == 0) {
          Candle_bright = BRIGHT_START;
        if (!Candle_pixels || GPIO_Set == false)
          GPIO_Set = Settings.TaskDevicePin1[event->TaskIndex] > -1;
          if (Candle_pixels) {
            delete Candle_pixels;
          Candle_pixels = new Adafruit_NeoPixel(NUM_PIXEL, Settings.TaskDevicePin1[event->TaskIndex], NEO_GRB + NEO_KHZ800);
          SetPixelsBlack();
          Candle_pixels->setBrightness(Candle_bright);
          Candle_pixels->begin();
          String log = F("CAND : Init WS2812 Pin : ");
          log += Settings.TaskDevicePin1[event->TaskIndex];
          addLog(LOG_LEVEL_DEBUG, log);
        success = true;
    case PLUGIN_ONCE_A_SECOND:
        Candle_pixels->show(); // This sends the updated pixel color to the hardware.
        success = true;
    case PLUGIN_FIFTY_PER_SECOND:
        switch (Candle_type)
          case 0:   // "Update" for OFF
              type_Off();
          case 1:   // Update for LIGHT
              type_Static_Light();
          case 2: // Random Updates for Simple Candle, Advanced Candle, Fire Simulation
          case 3:
              if (timeOutReached(Candle_Update)) {
                if (Candle_type == 2) {
                  type_Simple_Candle();
                if (Candle_type == 3) {
                  type_Advanced_Candle();
                Candle_Update = millis() + random(25, 150);
          case 4:   // Update for Police
                type_Police();
          case 5:   // Update for Blink
                type_BlinkStrobe();
                Candle_Update = millis() + 100;
          case 6:   // Update for Strobe
              type_BlinkStrobe();
          case 7:   // Update for ColorFader
                type_ColorFader();
                Candle_Update = millis() + 2000;
            //effects addition
          case 8:   // Update for Cylon
                type_Cylon(5);
                Candle_Update = millis() + NUM_PIXEL/20;
            case 9:   // Update for type_Sparkle
              type_Sparkle();
            case 10:   // Update for type_rainbow
                type_Rainbow();
                Candle_Update = millis() + 20;
        success = true;
    case PLUGIN_READ:
        UserVar[event->BaseVarIndex] = Candle_red * 65536 + Candle_green * 256 + Candle_blue;
        UserVar[event->BaseVarIndex + 1] = Candle_bright;
        UserVar[event->BaseVarIndex + 2] = Candle_type;
        success = true;
    case PLUGIN_WRITE:
        String tmpString  = string;
        // Test
        // Commands
        //    <FlameType>  : 1 Static Light, 2 Simple Candle, 3 Advanced Candle, 4 Police, 5 Blink, 6 Strobe, 7 Color Fader , ...
        if (tmpString.startsWith("CANDLE:")){
          int idx1 = tmpString.indexOf(':');
          int idx2 = tmpString.indexOf(':', idx1+1);
          int idx3 = tmpString.indexOf(':', idx2+1);
          int idx4 = tmpString.indexOf(':', idx3+1);
          String val_Type = tmpString.substring(idx1+1, idx2);
          String val_Color = tmpString.substring(idx2+1, idx3);
          String val_Bright = tmpString.substring(idx3+1, idx4);
          if (val_Type != "") {
             if (val_Type.toInt() > -1 && val_Type.toInt() < SIMTYPE_LEN) {
                Settings.TaskDevicePluginConfig[event->TaskIndex][4] = val_Type.toInt();     // Type
                String log = F("CAND : CMD - Type : ");
                log += val_Type;
          if (val_Bright != "") {
             if (val_Bright.toInt() > -1 && val_Bright.toInt() < 256) {
                Settings.TaskDevicePluginConfig[event->TaskIndex][3] = val_Bright.toInt();     // Brightness
                String log = F("CAND : CMD - Bright : ");
                log += val_Bright;
          if (val_Color != "") {
            long number = strtol( &val_Color[0], NULL, 16);
            // Split RGB to r, g, b values
            byte r = number >> 16;
            byte g = number >> 8 & 0xFF;
            byte b = number & 0xFF;
            Settings.TaskDevicePluginConfig[event->TaskIndex][0] = r;   // R
            Settings.TaskDevicePluginConfig[event->TaskIndex][1] = g;   // G
            Settings.TaskDevicePluginConfig[event->TaskIndex][2] = b;   // B
            Settings.TaskDevicePluginConfig[event->TaskIndex][5] = 1;
            Candle_color = (ColorType)Settings.TaskDevicePluginConfig[event->TaskIndex][5];   // ColorType (ColorSelected)
            String log = F("CAND : CMD - R ");
            log += r;
            log += F(" G ");
            log += g;
            log += F(" B ");
            log += b;
          } else {
            Settings.TaskDevicePluginConfig[event->TaskIndex][5] = 0;
            Candle_color = (ColorType)Settings.TaskDevicePluginConfig[event->TaskIndex][5];   // ColorType (ColorDefault)
            addLog(LOG_LEVEL_DEBUG, F("CAND : CMD - Color : DEFAULT"));
          //SaveTaskSettings(event->TaskIndex);
          //SaveSettings();
          success = true;
  return success;
void SetPixelsBlack() {
  for (int i = 0; i < NUM_PIXEL; i++) {
    Candle_pixels->setPixelColor(i, Candle_pixels->Color(0, 0, 0));
void SetPixelToColor(int PixelIdx) {
  Candle_pixels->setPixelColor(PixelIdx, Candle_pixels->Color(Candle_red, Candle_green, Candle_blue));
void type_Off() {
  SetPixelsBlack();
void type_Static_Light() {
      Candle_pixels->setPixelColor(i, 255, 255, 255);     // Default is white
    } else {
      Candle_pixels->setPixelColor(i, Candle_red, Candle_green, Candle_blue);
void type_Simple_Candle() {
  int r, g, b;
    r = 226, g = 042, b =  35;   // Regular (orange) flame
    //r = 158, g =   8, b = 148;   // Purple flame
    //r =  74, g = 150, b =  12;   // Green flame
  } else {
    r = Candle_red, g = Candle_green, b = Candle_blue;
  //  Flicker, based on our initial RGB values
    int flicker = random(0, RANDOM_PIXEL);
    int r1 = r - flicker;
    int g1 = g - flicker;
    int b1 = b - flicker;
    if (g1 < 0) g1 = 0;
    if (r1 < 0) r1 = 0;
    if (b1 < 0) b1 = 0;
    Candle_pixels->setPixelColor(i, r1, g1, b1);
void type_Advanced_Candle() {
  Candle_Temp[0] = random(1, 4); // 1..4  LEDs in RED
  Candle_Temp[1] = random(1, 4) + Candle_Temp[0]; // 1..3  LEDs in Yellow / Orange
  Candle_Temp[2] = random(0, 2); // 0..1  Choose Yellow = 0 / Orange = 1
  int colorbase[3];
  int color1[3];
  int color2[3];
  int color3[3];
    colorbase[0] = 255; colorbase[1] = 120; colorbase[2] = 0;   // Light Orange #FF7800
    color1[0] = 115; color1[1] = 50; color1[2] = 0;             // Brown      #733200
    color2[0] = 180; color2[1] = 80; color2[2] = 0;             // Orange     #B45000
    color3[0] =  70; color3[1] = 30; color3[2] = 0;              // Dark brown #4A2000
  } else {
    colorbase[0] = Candle_red; colorbase[1] = Candle_green; colorbase[2] = Candle_blue;
    double hsv[3];
    // Calc HSV
    RGBtoHSV(Candle_red, Candle_green, Candle_blue, hsv);
    double newH = hsv[0] - 5;
    if (newH < 0) { newH += 359; }
    double newV = hsv[2] / 2;
    double newV2 = hsv[2] / 4;
    // Calc new RGBs
    HSVtoRGB(newH, hsv[1], hsv[2], color1);
    HSVtoRGB(hsv[0], hsv[1], newV, color2);
    HSVtoRGB(newH, hsv[1], newV2, color3);
  for (int j = 0; j < NUM_PIXEL/5; j++) {
    for (unsigned int i = 1; i < 6; i++){
      if (i <= Candle_Temp[0]) {
        Candle_pixels->setPixelColor(j * 5 + i - 1, colorbase[0], colorbase[1], colorbase[2]);
      if (i > Candle_Temp[0] && i <= Candle_Temp[1]) {
        if (Candle_Temp[2] == 0){
          Candle_pixels->setPixelColor(j * 5 + i - 1, color1[0], color1[1], color1[2]);
        } else {
          Candle_pixels->setPixelColor(j * 5 + i - 1, color2[0], color2[1], color2[2]);
      if (i > Candle_Temp[1]) {
        Candle_pixels->setPixelColor(j * 5 + i - 1, color3[0], color3[1], color3[2]);
void type_Police() {
  Candle_Temp[0]++;
  if (Candle_Temp[0] > NUM_PIXEL / 5) {
    Candle_Temp[0] = 0;
  for (unsigned int i = 0; i < NUM_PIXEL / 5; i++) {
    if (i == Candle_Temp[0])
      for (int j = 0; j < 5; j++) {
          Candle_pixels->setPixelColor(i * 5 + j, 0, 0, 255);
        } else {
          Candle_pixels->setPixelColor(i * 5 + j, Candle_red, Candle_green, Candle_blue);
    } else {
        Candle_pixels->setPixelColor(i * 5 + j, 0, 0, 0);
void type_BlinkStrobe() {
  Candle_Temp[0]++;
  if (Candle_Temp[0] > 1) {
    Candle_Temp[0] = 0;
    if (Candle_Temp[0] == 0) {
      Candle_pixels->setPixelColor(i, 0, 0, 0);
    } else {
      } else {
void type_ColorFader() {
  int colors[3];
  double hsv[3];
  if (Candle_color != ColorDefault) {
    if (Candle_Temp[0] > 254 && Candle_Temp[1] == 1) {
      Candle_Temp[1] = 0;
    if (Candle_Temp[0] < 55 && Candle_Temp[1] == 0) {
      Candle_Temp[1] = 1;
    if (Candle_Temp[1] > 0) {
      Candle_Temp[0]++;
    } else {
      Candle_Temp[0]--;
    // Calc HSV
    // void RGBtoHSV(byte r, byte g, byte b, double hsv[3])
    // Calc RGB with new V
    // HSVtoRGB(int hue, int sat, int val, int colors[3])
    // hue: 0-359, sat: 0-255, val (lightness): 0-255
    HSVtoRGB(hsv[0], hsv[1], Candle_Temp[0], colors);
      Candle_pixels->setPixelColor(i, colors[0], colors[1], colors[2]);
  } else {
    Candle_Temp[0]++;
    if (Candle_Temp[0] > 359) {
      Candle_Temp[0] = 0;
    HSVtoRGB(Candle_Temp[0], 255, 255, colors);
// Effects additions
void type_Cylon(int EyeSize){
  byte red = 255; byte green = 255 ; byte blue = 255 ; // Default is white
    red = Candle_red; green = Candle_green ; blue = Candle_blue ;
  if (Candle_Temp[0] >= NUM_PIXEL-EyeSize-1 ) { //max value
    Candle_Temp[1] = 0; //decrease
  } else if (Candle_Temp[0] <=0 ) { //min value
    Candle_Temp[1] = 1; //increase
    if ( Candle_Temp[1] == 0 ) { // decrease
    Candle_Temp[1] = 0;
    Candle_Temp[0]--;
  } else { //increase
    Candle_Temp[1] = 1;
    Candle_Temp[0]++;
  for(int i = 0; i < NUM_PIXEL-EyeSize-1; i++) {
    if (Candle_Temp[0]==i) {
      Candle_pixels->setPixelColor(i-1, 0, 0, 0);
      Candle_pixels->setPixelColor(i, red/10, green/10, blue/10);
      for(int j = 1; j <= EyeSize; j++) {
        Candle_pixels->setPixelColor(i+j, red, green, blue);
      Candle_pixels->setPixelColor(i+EyeSize+1, red/10, green/10, blue/10);
      Candle_pixels->setPixelColor(i+EyeSize+2, 0, 0, 0);
void type_Sparkle() {
  int Pixel ;
  for (int i=0 ; i<10; i++)
    Pixel = random(NUM_PIXEL);
    Candle_pixels->setPixelColor(Pixel,red,green,blue);
    Candle_pixels->setPixelColor(Pixel,0,0,0);
void type_Rainbow() {
  byte *c;
  uint16_t i;
  //for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
  Candle_Temp[0]++ ;
  if (Candle_Temp[0] > 256*5 ) Candle_Temp[0] = 0;
  for(i=0; i< NUM_PIXEL; i++) {
    c=Wheel(((i * 256 / NUM_PIXEL) + Candle_Temp[0]) & 255);
    Candle_pixels->setPixelColor(i, *c, *(c+1), *(c+2));
byte * Wheel(byte WheelPos) {
  static byte c[3];
  if(WheelPos < 85) {
   c[0]=WheelPos * 3;
   c[1]=255 - WheelPos * 3;
   c[2]=0;
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   c[0]=255 - WheelPos * 3;
   c[1]=0;
   c[2]=WheelPos * 3;
  } else {
   WheelPos -= 170;
   c[0]=0;
   c[1]=WheelPos * 3;
   c[2]=255 - WheelPos * 3;
  return c;
// Convert HSC Color to RGB Color
void HSVtoRGB(int hue, int sat, int val, int colors[3]) {
  int r=0, g=0, b=0, base=0;
  if (sat == 0) { // Achromatic color (gray).
    colors[0]=val;
    colors[1]=val;
    colors[2]=val;
  else  {
    base = ((255 - sat) * val)>>8;
    switch(hue/60) {
    case 0:
      r = val;
      g = (((val-base)*hue)/60)+base;
      b = base;
    case 1:
      r = (((val-base)*(60-(hue%60)))/60)+base;
      g = val;
      b = base;
    case 2:
      r = base;
      g = val;
      b = (((val-base)*(hue%60))/60)+base;
    case 3:
      r = base;
      g = (((val-base)*(60-(hue%60)))/60)+base;
      b = val;
    case 4:
      r = (((val-base)*(hue%60))/60)+base;
      g = base;
      b = val;
    case 5:
      r = val;
      g = base;
      b = (((val-base)*(60-(hue%60)))/60)+base;
    colors[0]=r;
    colors[1]=g;
    colors[2]=b;
// Convert RGB Color to HSV Color
void RGBtoHSV(byte r, byte g, byte b, double hsv[3]) {
    double rd = (double) r/255;
    double gd = (double) g/255;
    double bd = (double) b/255;
    double maxval = rd;
    if (gd > maxval) { maxval = gd; }
    if (bd > maxval) { maxval = bd; }
    double minval = rd;
    if (gd < minval) { minval = gd; }
    if (bd < minval) { minval = bd; }
    double h = 0, s, v = maxval;
    double d = maxval - minval;
    s = maxval == 0 ? 0 : d / maxval;
    if (maxval == minval) {
        h = 0; // achromatic
    } else {
        if (maxval == rd) {
            h = (gd - bd) / d + (gd < bd ? 6 : 0);
        } else if (maxval == gd) {
            h = (bd - rd) / d + 2;
        } else if (maxval == bd) {
            h = (rd - gd) / d + 4;
        h /= 6;
    hsv[0] = h * 360;
    hsv[1] = s * 255;
    hsv[2] = v * 255;
#endif // USES_P042
Posted: 24 May 2018, 09:51
by riker1
jonathan-orsel wrote: 02 May 2018, 05:27 Hello,
is this integrated in a special firmware?
Thanks T
Posted: 24 May 2018, 14:02
by papperone
why you don't submit those changes in the GitHub repository? I think it is a very good improvement for this plugin which is part of the 2.0 release...
Posted: 14 Jun 2018, 02:56
by kiwijunglist
Can someone tell me how to issue mqtt commands to espeasy using openhab protocol.
Device name = esp01
Subscribe template = /%sysname%/
Task -> Device: switch
Task -> Device name: led
Task -> Device GPIO: 14
Task -> Device optional name: switch
http://192.168.178.100/control?cmd=GPIO,14,0 and http://192.168.178.100/control?cmd=GPIO,14,1 are working for turning the LED light on and off
MQTT subscription works fine, but MQTT publish commands to control the esp chip doesn't work!
What would the mqtt topic and command for controlling this LED? I spent 2 hours trying different combinations.
PLEASE SOMEONE HELP ME !!!! :( :( :(
Posted: 27 Jul 2018, 19:14
by teqilla
Meybe someone give me a code for Home Assistant to control wifi candle thru mqtt.
Thanx in advance.
Posted: 03 Oct 2018, 20:25
by Reefie
Hi Paul
I realise it has been quite some time since you posted this, I was wondering if you still had the flow and if so, would you mind sharing :P
