The PMS x003 series are air quality sensors developed by Plantower (Chinese name 攀藤). The air pollution is an extremely serious problem in China.
So the first step I take is air quality monitoring. I make this plugin by hacking others. Here is the code:
This plugin reads the Air Quality value(μg/m3) from PMSX003 Sensor
DevicePin1 - is RX for ESP
DevicePin2 - is TX for ESP
#define PLUGIN_117
#define PLUGIN_ID_117 117
#define PLUGIN_NAME_117 "Air Quality Sensor PMSX003"
#define PLUGIN_VALUENAME1_117 "PM1.0"
#define PLUGIN_VALUENAME2_117 "PM2.5"
#define PLUGIN_VALUENAME3_117 "PM10"
boolean Plugin_117_init = false;
#include <SoftwareSerial.h>
SoftwareSerial *Plugin_117_PMSX003;
// 32-bytes CMD Air Quality read
byte pmsResp[32]; // 32 bytes bytes response
boolean Plugin_117(byte function, struct EventStruct *event, String& string)
boolean success = false;
switch (function)
case PLUGIN_DEVICE_ADD:
Device[++deviceCount].Number = PLUGIN_ID_117;
Device[deviceCount].Type = DEVICE_TYPE_DUAL;
Device[deviceCount].VType = SENSOR_TYPE_TRIPLE;
Device[deviceCount].FormulaOption = true;
Device[deviceCount].ValueCount = 3;
Device[deviceCount].GlobalSyncOption = true;
case PLUGIN_GET_DEVICENAME:
string = F(PLUGIN_NAME_117);
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_VALUENAME1_117));
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[1], PSTR(PLUGIN_VALUENAME2_117));
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[2], PSTR(PLUGIN_VALUENAME3_117));
case PLUGIN_INIT:
Plugin_117_init = true;
Plugin_117_PMSX003 = new SoftwareSerial(Settings.TaskDevicePin1[event->TaskIndex], Settings.TaskDevicePin2[event->TaskIndex]);
success = true;
case PLUGIN_READ:
if (Plugin_117_init)
Plugin_117_PMSX003->readBytes(pmsResp, 32);
int i;
unsigned int pm1_0 = 0;
unsigned int pm2_5 = 0;
unsigned int pm10 = 0;
unsigned int crccal = 0;
for (i = 0; i < 30; i++) crccal += pmsResp[i];
unsigned int crc = (pmsResp[30] << 8) + pmsResp[31];
if ( !(pmsResp[0] == 0x42 && pmsResp[1] == 0x4D && pmsResp[3] == 0x1C && crccal == crc ) ) {
// && crccal == crc
String log = F("PMSX003: CRC error: ");
log += String(crc); log += " / "; log += String(crccal);
addLog(LOG_LEVEL_ERROR, log);
success = false;
} else {
pm1_0 = ((pmsResp[4] << 8) + pmsResp[5]);
pm2_5 = ((pmsResp[6] << 8) + pmsResp[7]);
pm10 = ((pmsResp[8] << 8) + pmsResp[9]);
UserVar[event->BaseVarIndex] = (float)pm1_0;
UserVar[event->BaseVarIndex + 1] = (float)pm2_5;
UserVar[event->BaseVarIndex + 2] = (float)pm10;
String log = F("PMSX003: pm value: ");
log += pm1_0;
log += " / ";
log += pm2_5;
log += " / ";
log += pm10;
addLog(LOG_LEVEL_INFO, log);
success = true;
return success;
there're 2 problems:
1. As you can see,I never figure out how GitHub works. So is there anyone can do me a favor by pulling this code. Thanks a lot.
2. There's no device in domoticz can read 3 values with one task. So if you wanna make it work in domoticz, you should separate it into 3 plugins like I do now.
sorry for my bad English.
