long push, short push detection with a button (connected on gpio)
Hi ESPEasy guy's
A question, did anybody try to distinguish the difference between a long and short push on a button, connected to a gpio on the ESP?
This could be interesting to build one normal on/off switch at the entrance of your house.
When short push on the button > normal on/off lighting in the entrance.
Long push is to disable all lights in your house when leaving.
Anybody?
Anybody?
Re: long push, short push detection with a button (connected on gpio)
Yes, I got that working by using the rules section.
Let the button start a timer-rule. (where you can specify your long-push time)
On Switch#Switch1=1.00 do
timerSet,1,2 (where 2 is the long push time in seconds)
On Rules#Timer=1 do
if [Switch#Switch1]=1.00
gpio,15,1
gpio,16,1
It can work but it's not really a long press, if you press, release, and then press it again within 2 seconds it will trigger the "long press" and it shoudln't...
I think you shoudl reset the timer if the switch is released in order to make it work properly!
ok, cool, so this is possible. thanks!
Did not have a look yet to the 'rules'.
I think I could add a 'turn off all lights' virtual button in domoticz,
and add a SendToHTTP in the rules? right?
e.g.
keep up the good work thx!
e.g.
SendToHTTP 192.168.0.243,8080,/json.htm?type=command¶mm=switchlight&idx=174&switchcmd=On
You're right. Thanks for the addition.papperone wrote:It can work but it's not really a long press, if you press, release, and then press it again within 2 seconds it will trigger the "long press" and it shoudln't...
Hi, i'm using this rules to control 4 lights with 2 pushbuttons.
on s2#S do
TaskValueSet 9,1,[tv#tv]+1
TaskValueSet 9,2,[salon#salon]+1
timerSet,1,1
timerSet,2,2
on s1#S do
TaskValueSet 9,3,[keuken#keuken]+1
TaskValueSet 9,4,[eetplaats#eetplaats]+1
timerSet,3,1
timerSet,4,2
on sw2#S=1 do
TaskValueSet 9,1,[Dummy#switch1]-1
if [salon#salon] > 0
gpio,14,0
pwm,14,0
gpio,14,1
on sw1#S=1 do
TaskValueSet 9,3,[Dummy#switch3]-1
if [eetplaats#eetplaats] > 0
gpio,2,0
pwm,2,0
gpio,2,1
On Rules#Timer=2 do
TaskValueSet 9,1,0
TaskValueSet 9,2,0
On Rules#Timer=4 do
TaskValueSet 9,3,0
TaskValueSet 9,4,0
On Rules#Timer=1 do
if [Dummy#switch1] = 1
gpio,13,1
gpio,13,0
pwm,13,0
On Rules#Timer=3 do
if [Dummy#switch3] = 1
gpio,0,1
gpio,0,0
pwm,0,0
<> Task Device Name Port IDX/Variable GPIO Values
Edit 1 Temperature - DS18b20 Garage 28-b1-a6-3b-5-0-0-68 65 GPIO-16 Temperature garage:24.63
Edit 2 Switch input keuken GPIO-0 keuken: 0
Edit 3 Switch input eetplaats GPIO-2 eetplaats: 0
Edit 4 Switch input tv GPIO-13 tv: 0
Edit 5 Switch input salon GPIO-14 salon: 0
Edit 6 Switch input s1 GPIO-12 S: 1
Edit 7 Switch input s2 GPIO-15 S: 1
Edit 8
Edit 9 Dummy Device Dummy switch1:0.00
switch2:0.00
switch3:0.00
switch4:0.00
Edit 10 Switch input sw1 GPIO-12 S: 0
Edit 11 Switch input sw2 GPIO-15 S: 0
Edit 12
on s2#S do
timerSet,1,1
timerSet,2,2
on s1#S do
timerSet,3,1
timerSet,4,2
on sw2#S=1 do
gpio,14,0
pwm,14,0
gpio,14,1
on sw1#S=1 do
gpio,2,0
pwm,2,0
gpio,2,1
On Rules#Timer=2 do
TaskValueSet 9,1,0
TaskValueSet 9,2,0
On Rules#Timer=4 do
TaskValueSet 9,3,0
TaskValueSet 9,4,0
On Rules#Timer=1 do
gpio,13,1
gpio,13,0
pwm,13,0
On Rules#Timer=3 do
gpio,0,1
gpio,0,0
pwm,0,0
Edit 8
switch2:0.00
switch3:0.00
switch4:0.00
Edit 12
hello, i'm making a switchboard with 4 channel mains relay module with 4 buttons. I want when one of the buttons long pressed to turn ON/OFF all 4 relays. anyway I can do this?... I'm kind of new to espeasy so far I managed to get this rules to work 4 channel relay to on/off how can I use one this button to control all channel?
rules
Someone, Please Help me
thank you
rules
on button1#button1 do
if [relay1#relay1] =0
GPIO,16,1
GPIO,16,0
on button2#button2 do
if [relay2#relay2] =0
GPIO,14,1
GPIO,14,0
on button3#button3 do
if [relay3#relay3] =0
GPIO,13,1
GPIO,13,0
on button4#button4 do
if [relay4#relay4] =0
GPIO,2,1
GPIO,2,0
thank you
Here is a snippet of working "production" code as example:
Button# is configured as normal switch (important!), TaskValueSet stores to dummy device/value State#Reboot.
I use the same gpio in another switch device (configured as pushbutton) for the "normal" switching.
on Button#Button do
if [Button#Button]=1
TimerSet 3,5
TaskValueSet 2,4,1
PWM 13,0
TimerSet 3,0
TaskValueSet 2,4,0
on Rules#Timer=3 do
if [State#Reboot]=1
Reboot
Hi, can you explain how you set the "normal" switch for the short push? What rule do you use?paxi wrote: ↑09 Apr 2017, 21:18 Here is a snippet of working "production" code as example:Button# is configured as normal switch (important!), TaskValueSet stores to dummy device/value State#Reboot.Code: Select all
on Button#Button do if [Button#Button]=1 TimerSet 3,5 TaskValueSet 2,4,1 PWM 13,0 else TimerSet 3,0 TaskValueSet 2,4,0 endif endon on Rules#Timer=3 do if [State#Reboot]=1 Reboot endif endon
if I create a new switch with the same gpio the short push rule is activated after the long push too.
thanks!
HI
i wondering how to use this long and short press option on my esp 8266 and easyesp
i have two relays and diffent GPIo's
and one buttom
i like to maka as following
on short press i like to change the state of relay 1 - if is OFF i like change to ON and opposit
on long press i like to change the state of relay 2 - if is OFF i like change to ON and opposit
the best willbe option tongle - but this option is missing on esp
finally wilbe two bottoms in differnt places to make the change on relays - but this wilbe next step..
regards
and one buttom
regards
Use my rule in the wiki and you can press the button as long as you want....
Pmn wrote: ↑01 Feb 2017, 20:57 Hi,
On Switch#Switch1=1.00 do timerSet,1,2 (where 2 is the long push time in seconds) endon On Rules#Timer=1 do if [Switch#Switch1]=1.00 gpio,15,1 else gpio,16,1 endif endon
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 25 guests
