The idea behind this project was to design a safe, compact, all-in-one Universal WIFI MAINS (EU/US) compatible 8x High Power Relays board that can be easily used for industrial or home automation projects and experiments, fully compatible with Arduino, ARM, ESP8266, ESP32, PIC, RaspberryPI, etc.
As you can see from the Video Tutorials from below, the MPRSx8 Home Automation Development Board is also fully compatible with ESPEasy and DOMOTICZ!!
- Upload firmware using the USBPrg adapter
- Firmware Upload using a generic USB adapter
- ESPEasy Firmware configuration
- MPRSx8 Domoticz Tutorial
For MPRSx8 Dev Board general presentation and hardware description please take a look at Part 1 of the MPRSx8 series
Happy breadboarding,
TJ.
MPRSx8 - WIFI Dev board for Home Automation
www.esp8266-projects.com - ESP8266 Projects and many more!
MPDMv4 Universal AC Dimmer is available also on TINDIE Store: https://www.tindie.com/stores/nEXT_EVO1/
Re: MPRSx8 - WIFI Dev board for Home Automation
I'm new to Esp Easy is it possible to control 4 channel relay board with esp8266 esp(12F) control it with MQTT and add 4 physical buttons to control this relays.?
I see no reason why it would not be possible to drive 4 relays and read 4 buttons, of course depending on your Relays Driver design, etc.ashfaaaa wrote:I'm new to Esp Easy is it possible to control 4 channel relay board with esp8266 esp(12F) control it with MQTT and add 4 physical buttons to control this relays.?
Regarding the MQTT, I've tried it a while ago and they were some issues with MQTT protocol, as far as I remember.
I have little to none experience with ESPEasy MQTT implementation so maybe somebody with more experience will be kind enough to answer to that.
Users browsing this forum: Google [Bot] and 60 guests
