Linking a SMART meter to home WiFi
- dynamicdave
HI,
I've just had a SMART metering system installed at home (i.e. Elster AS300P with home display unit).
The LCD home display unit must be receiving signals from the SMART meter in order to display the energy usage.
So my question is... has anyone managed to construct a unit to receive these signals and interface them to MQTT and Node-Red ?
Any help, suggestions, advice would be appreciated.
BTW - I live in the UK, so my equipment is subject to UK standards.
Kind regards, David Dempster
Re: Linking a SMART meter to home WiFi
According to the spec:s the unit has an "Optical communications port" which makes me believe that you could intercept the power/water/gas consumption using a pulse counter.
See more here on the wiki: https://www.letscontrolit.com/wiki/index.php/TCR5000
- dynamicdave
Thanks for your swift response.
I assume the comms port is situated on the front of the SMART meter and is just a simple infra-red link ??
On a personal note - many years ago I used to run training courses at Ericsson in Stockholm and Gothenburg.
Have had great times in Sweden.
Cheers from David.
Cheers from David.
Due to the spec sheet the AS300P is a modular device.
Following the datasheet (see https://www.elstersolutions.com/assets/ ... 072013.pdf )
there is a choice of a lot of different modules for data transfer like GSM, ZigBee, LP-RF for WAN/LAN to name some of them.
As long as there is no info which module is implemented in the counter, it's a bit difficult to say how it could be read or if at all.
Anyways there should a infrared sending diode on 880nm wavelength that sends countable pulses if i understand that right.
- dynamicdave
Hi Shardan,
Thanks for your swift response and "good" advice.
Cheers from David.
Cheers from David.
- dynamicdave
Have you managed to get the Pulse Counter device (within ESP Easy) to function?grovkillen wrote: ↑22 Jun 2017, 12:34 According to the spec:s the unit has an "Optical communications port" which makes me believe that you could intercept the power/water/gas consumption using a pulse counter.
I've rigged-up an IR detector this afternoon that seems to detect "light signals" from the SMART meter, however the values that ESP8266 report never change.
Cheers from David
Please post your settings for that device.
This is my setup: https://www.letscontrolit.com/wiki/inde ... ogic_input
- dynamicdave
Here's a screenshot of my setup.
It looks very similar to yours.
Cheers from David
Cheers from David
- pulse_counter.png (22.92 KiB) Viewed 8979 times
Hello dave,
can you provide a link to the type of IR sensor you use, or a schematic of the sensor?
Debounce time 2mSec is really tight! Under 100 mSec is not ideal I would say.dynamicdave wrote: ↑26 Jun 2017, 19:48 Hi,
Cheers from David
- dynamicdave
I'll try a longer debounce time.
Cheers from David
Cheers from David
Users browsing this forum: Bing [Bot] and 29 guests
