Hello all
At the moment I have an Arduino as o ProMiniExtender on a Wemos Board by I2C
At the PME Board I'm measuring Currents by SCT013 current sensors.
But 4 pieces are not enough.
Is it possible to connect 2 or 3 PMEs at one Wemos?
I have the PME I2C adress 0x7f and two ports, 90 and 100 for two sensors at the moment.
Thank you!
2 ProMiniExtender on 1 ESP possible?
Re: 2 ProMiniExtender on 1 ESP possible?
I was wondering the same thing. Is it possible to daisy-chain multiple PME's to one ESP module?
The I²C bus allows daisy-chaining provided each PME has a unique I²C address, however I see no way to set an I²C address for each PME. I think the current soft assumes a single PME with a default I²C address?
I think you can set the adress of the Pro Mini Extender in the ProMiniExtender Sketch for the Arduino, (check wire.begin)waaslandwolf wrote: ↑06 Mar 2018, 10:08 I was wondering the same thing. Is it possible to daisy-chain multiple PME's to one ESP module?
The plugin must be modified in such a way, that the adress is selectable, maybe that can be carried over from other plug-ins
Thanks for the quick reply. That would confirm that currently multiple, daisy-chained, PME's are not provisioned for in the current firmware.
I might attempt to modify the code to allow for this. Changing the PME sketch would be quite straightforward, only the I²C address should be changed. Modifying the ESPeasy code would be a bit more involved. The following would need to be modified:
- a way to select from multiple PME's. Perhaps the easiest way would be to keep the current hardware device selection (selecting the ProMini Expander), and within the configuration of this device add an address field which would allow addressing of an individual PME in a daisy-chained multiple PME scenario.
- an extension of the current PME port numbering scheme.
- The easiest would be to keep the current numbering scheme, so effectively each concurrent PME has the same port numbers. This would mean that any triggers adressing a certain PME would need to include a mechanism to select an individual PME (using the I²C address would be easiest).
- Alternatively one could imagine numbering all PME's ports' in a consecutive fasion using a sort of mapping so that the port addressing mechanism higher up doesn't need to be modified.
Does that make sense?
It probably makes sense to use same logic as with pcf and mcp i2c port expanders -->use a i2c adress to pin number table. Adress 1 --> D1 to d13, adress 2 d14 to d26) That would allow to keep old command set.waaslandwolf wrote: ↑06 Mar 2018, 11:33 Thanks for the quick reply. That would confirm that currently multiple, daisy-chained, PME's are not provisioned for in the current firmware.
But otherwise makes sense
Users browsing this forum: No registered users and 72 guests
