Modded "Wifi" Sound Alarm Siren project
Re: Modded "Wifi" Sound Alarm Siren project
found it but the basic one (plastic case) is 12€ while yours (leather case) is 14€ white and 16€ black...
I think i'll give a try with the cheapest (as it's only cover the difference), thanks!
Don't worry, they are all the same.
It looks like leather with cotton seams... but it's all plastic! It looks like the fakest thing you have ever seen in reality!
But it works, and it's solid... at least as a battery 5v backup.
It can keep an ESP8266 with blinking leds, 100% wifi (no sleep) and a relay ON (for 50% of time, I used it for a quick thermostat test) for 2/3 days.
I am using this TP4056 as an UPS for my RPI Zero W:
Of course with a step up converter and an ICR18650.
I did not experienced any interruption, when i plugged it off from the wall. I am using it with RPI Zero W which hosts my Domoticz server, and working flawlessly from 2017.11.15. I'm also monitoring the battery status through an ADS1015.
I have some pictures on my blog: / sorry page language is my mother tongue /
http://bitekmindenhol.blog.hu/2017/11/1 ... g_dc5v_diy
Many thanks for posting the link to your blog. Most interesting and informative! I'll try that way to supply my Raspberry Pi 3 which runs Home Assistant - I think it's a very similar use-case to yours. (Don't apologise for the language, I was able to get the meaning well enough using Google Translate.)enesbcs wrote: ↑30 Mar 2018, 12:42I did not experienced any interruption, when i plugged it off from the wall. I am using it with RPI Zero W which hosts my Domoticz server, and working flawlessly from 2017.11.15. I'm also monitoring the battery status through an ADS1015.
Andrew
You are welcome. I have no Pi3 to try it, but in my tests - under load - the voltage drops down to 4,75V which may have too little for the Pi3. Unless you find a stronger step up converter to the 5V side.AndrewJ wrote: ↑30 Mar 2018, 13:06 Many thanks for posting the link to your blog. Most interesting and informative! I'll try that way to supply my Raspberry Pi 3 which runs Home Assistant - I think it's a very similar use-case to yours. (Don't apologise for the language, I was able to get the meaning well enough using Google Translate.)
Andrew
Thanks, that's good advice, I'll look into stronger step-up converters.enesbcs wrote: ↑30 Mar 2018, 14:34You are welcome. I have no Pi3 to try it, but in my tests - under load - the voltage drops down to 4,75V which may have too little for the Pi3. Unless you find a stronger step up converter to the 5V side.AndrewJ wrote: ↑30 Mar 2018, 13:06 Many thanks for posting the link to your blog. Most interesting and informative! I'll try that way to supply my Raspberry Pi 3 which runs Home Assistant - I think it's a very similar use-case to yours. (Don't apologise for the language, I was able to get the meaning well enough using Google Translate.)
Andrew
Thanks for the Projekt!
This is something I am looking for a long time but myself, I'm just too bad to think it out.
I have a question @gatsu_1981.
I think I have exactly the same siren as you (one of the two). The siren had a jack plug.
I then tried as a test to connect the siren to a 12v power supply. The power supply has worked, I've measured. According to my theory, the siren should have sounded or not?
My siren does not matter if I connect them to 12v. Can you possibly say something about it, because I see you're just switching the power on and off with a relay?
Similarly, I can not see where the siren gets the 12v ago in your project?
Hi.
This siren should work from 5 to 24v AFAIK, I'm using it @5v as you can see (they share the same input voltage from the NodeMCU).
If it does not sound to 12v, it's broken (or maybe you swapped cables polarity).
Hey,gatsu_1981 wrote: ↑15 Jun 2018, 17:21 Hi.
thanks for your reply. I think I have to order some other Sirens because nothing happens on 12v.
Thank you
Hello @enesbcs,
could you please briefly explain how exactly you control the siren on PWM. which commands do you use? I have everything exactly as you assembled and the siren also works, but I do not know exactly how to control you reliably because it makes sometimes only a short tone and sometimes can not be switched off.
Thank you!
Thank you!
Only the switch is capable of PWM, the siren is not. So i simply use gpio command and the pulse command.
on System#Boot do
event,stop_siren
on pulse_siren do
pulse,12,1,1000
on stop_siren do
GPIO,12,0
sorry that I answer so late. I have in the meantime more with the whole set apart. However, today I have come to a point where I do not know.
I have 5v directly connected to the 5v pin from the wemos d1 mini and ground directly to ground. I do not use the USB port due to space issues. The whole works well, but the wemos extream hot between the USB port and the 5v pin. There, diodes and the voltage regulator seem to be sitting there. Usually it is no problem to connect the wemos d1 mini to 5v pin. Maybe something has broken in the meantime and the voltage regulator or the diode has a negative impact. Is there a way to save the Wemos D1 Mini?
Users browsing this forum: No registered users and 60 guests
