Pulse Counter
Deennoo
Pulse Counter
#1 Post by Deennoo » 07 Sep 2015, 13:36
after building a DHT22 sensor and try the relay with succes, I try to get a Pulse counter (for my gas meter)
I created a Dummy counter on domoticz
i selected the pulse counter on ESPEASY, like this :
On GPIO2 and GND i plug a reed sensor. But with no result, can you help ?
Deennoo
Re: Pulse Counter
#2 Post by Deennoo » 07 Sep 2015, 14:14
Deennoo wrote:Hi
i selected the pulse counter on easyesp, like this :
Edit : ok i just learn that GPIO 1 Can't be use on SP1 version...got a wiring problem to...that work
rtenklooster
Re: Pulse Counter
#3 Post by rtenklooster » 07 Sep 2015, 23:06
I guess your problem is solved :) Fine!
Richard - Groningen (NL) - Image
Deennoo
Re: Pulse Counter
#4 Post by Deennoo » 08 Sep 2015, 11:18
Ok it works, and with a IR pulse sensor too.
Each pulse is Twice add :
1 for contact ON
1 for contact OFF
Deennoo
Re: Pulse Counter
#5 Post by Deennoo » 05 Oct 2015, 21:24
I'm back with this.
Still working on r20
Got a bounce problem using a Reed switch on my gas meter.
Reed switch is hoock to gpio 2 and gnd. Capacitor is on this line too
The same reed with a 433 chinese pir sensor don't do this.
Is there a way to fix this ? Juste by adding rules that 2 plus can't be closer than x millisecond
Martinus
Re: Pulse Counter
#6 Post by Martinus » 06 Oct 2015, 11:18
A digital 'debounce' feature is planned for the next ESP Easy release. I can't guarantee that this will solve all pulse counting issues like these, but it will be worth a try...
Deennoo
Re: Pulse Counter
#7 Post by Deennoo » 06 Oct 2015, 11:27
I just upload r29, samething
Great news thank you very much !
Will be the first to test !
Deennoo
Re: Pulse Counter
#8 Post by Deennoo » 07 Oct 2015, 13:09
Maybe will be not the first but test this this morning.
Looks to works, thanks to add the debounce delay !! on a gas counter gaz case 1000ms (1 seconde is enough).
Thank you Martinus,
Next step Add a pulse counter to my Water Meter with this hall round sensor (the only one i can put and who work on my counter) :
[attachment=0]192926.jpg[/attachment]
