ESP EASY sending data
moayad1995
#1 Post by moayad1995 » 20 Jun 2018, 13:02
Dear all
im new to easy esp so i need your help
i bought an openthermgateway v2 https://www.nodo-shop.nl/en/opentherm-g ... teway.html and connected it to my boiler and thermostat every thing works fine now i bought NODEMCU https://www.lightinthebox.com/en/p/node ... mAQAvD_BwE
and flashed it with easy esp mega and configured it with serial server and connected it OTMonitor , every things works fine so now i wanna send data from my pic to the nodemcu (it suppose to be serial ) and from the nodemcu wanan using easy esp mega want to send it to a server, im not sure if i can do that and if yes how to do it
thanks in advaced
redskinhu
Re: ESP EASY sending data
#2 Post by redskinhu » 20 Jun 2018, 21:45
I think we have a same problem. And nobody knows the answer. :-(
How can we get the data from the serial port?
viewtopic.php?f=6&t=5478
Bye
T
#3 Post by TD-er » 20 Jun 2018, 21:57
At this moment, there is no plugin (as far as I know) for ESPeasy to interface with this OpenTherm board.
But I guess there may be some demand for it.
My heating system does not use OpenTherm, so even if I would have such a board, I could not test it.
And there is something about limited time...
xury
#4 Post by xury » 26 Jun 2018, 23:21
I think is could be a bug in ser2net plugin because !Serial# does not have a value name so %eventvalue% does not work.
