Relay
Ro_64
Relay
#1 Post by Ro_64 » 26 Mar 2019, 18:56
I have this setting but it does not work with the water level sensor. here's the example:
On relay#rele do
if [hum#hum]>=750 and [bo#bo]=0
GPIO,5,1
GPIO,5,0
http://imgur.com/gallery/MFIrt5s
Re: Relay
#2 Post by grovkillen » 26 Mar 2019, 19:02
You have the event which is infact the GPIO 5. So what is the input, not the relay by itself I suspect.
Ro_64
Re: Relay
#3 Post by Ro_64 » 26 Mar 2019, 19:34
kimot
Re: Relay
#4 Post by kimot » 26 Mar 2019, 19:58
Nice, but still -what is relay#rele ?
I can see only rele#rele in your last picture.
And on new firmwares, checking relay status by defining input on the same pin is problematic.
I am using it, but on older versions _dev13 and v2.0
And you are using event:
When toggle relay (change its status - but how?? ) measure humidity and according its value switch on or off the same relay
Ro_64
Re: Relay
#5 Post by Ro_64 » 26 Mar 2019, 20:19
ç
Ro_64
Re: Relay
#6 Post by Ro_64 » 26 Mar 2019, 22:30
kimot wrote:
26 Mar 2019, 19:58
82/5000
Hello, I installed the version Release v2.0.0-dev13 just like yours.
now how can i do the select input.
Re: Relay
#7 Post by ThomasB » 26 Mar 2019, 22:46
can you help me about this. appreciate
As Kimot stated, reading the relay pin with a Switch device is problematic. It used to be tolerated (and there are many examples of doing it in the wiki), but I do not believe it is supported anymore. To avoid surprises the solution is to use dummy variables to report the state of a relay to a rule.
I seem to recall that any release before Dec 2018 will support reading the relay control pin as an input if the I/O pin is defined in a Switch device.
But even if you use a release that supports reading a relay pin with the Switch device, I think there may be a logic issue in the rules. The rules will attempt to change the state of the relay whenever the relay's state has changed. But the rules also change the state of the relay. So perhaps this creates an endless loop.
kimot
Re: Relay
#8 Post by kimot » 28 Mar 2019, 09:54
Do you realize that the event relay#rele is only executed when the relay status changes? How do you do that? In some other part of the program? If not, this event will never happen and cannot work.
schnurzel59
Re: Relay
#9 Post by schnurzel59 » 01 Apr 2019, 23:41
Hi Ro_64
It would be easier to help if you had an idea of what you want to do. What is bo # bo? A switch? When is the condition = "0" given?
hum # hum is the water level. OK.What does your relay do? A little more detail would be helpful.
Your switch rele is labeled wrong. On the one picture it has the name "rele#rele" on the other picture it is "relay#rele". What should it be?
It would be better to set the pictures right here without the weird gallery pictures. Then you would see that immediately.
Switch and relay together is also very unfavorable. For status storage take a dummy device. An event "rele#rele" only occurs if
an interval > 0 is entered in the switch device. A few more detailed information from you and it will be easier to help.
Greetings Martin
