LCD: right-aligned values ???
Hi there again,
on a 07S I use a BM280, a lightsensor BH1750FUI and a 4x20 LCD. Temp. and Humity are well formed and takes 5 digits (when the temperature reaches 100 ° C, nobody will be there to read it ). Pressure are most also takes 7 Digits, somtetimes 6.
But the Lightsensor gives values from 0.00 up to more then 40000.00 LUX. Ok... In nature more then 9000 I don't await but then it jump's arround between 5.00 and 9000.00 ...
At the LCD there is no option to align values on the right side... So if there a way by formulas inside the Options of the Sensor itselfe to say i.e. "If one character before the comma fill with 3 spaces, if 2 before fill with 2 spaces....) ???
DLzG
Micha
Micha
Re: LCD: right-aligned values ???
I use percent instead of the actual value since 4768 lux doesn't do it for me. I like 1...100% better. But that's me I guess.
That being said. You can do left of right align, can't remember the syntax just now but you need to use rules.
I haven't been able to add it to the docs but here's the PR describing it:
https://github.com/letscontrolit/ESPEasy/pull/1289
... ok, I have read it but I just understand... nothing
DLzG
Micha
Micha
Lets say your task is called "sun" and its value is named "lux" you could do this (in rules)
[sun#lux#R#P2]
To justify the value to the right and add two spaces on the left of the value.
Just as one example.
[sun#lux#R#P2]
Enjoy!
.. nope ... I'm too dumb for that
Where I have to insert it? In the Formula-field at the sensor or in the line-field at the display?
- capture_002_05072019_205641.jpg (47.62 KiB) Viewed 16789 times
- capture_001_05072019_205549.jpg (43.39 KiB) Viewed 16789 times
DLzG
Micha
Micha
If it's not working to add that to those [....] Inside the settings of the LCD task you need to use the LCD command inside rules.
... ok, I'm sorry but I'm realy too dumb to handle that...
I have searching arround the forum and other but don't find an exsample for that how I can see howto ...
Not so important... It's ok what I have now. The little bad thing is accepted ...
DLzG
Micha
Micha
Sleep on it and give it another try another day. Never give up.
Users browsing this forum: Google [Bot] and 59 guests
