Keypad MQTT on ESP
Keypad MQTT on ESP
Hey Guys,
I got stucked.
I plugged a keypad as picture attached.
PCF8574 with GPIO 0 and GPIO 2
and setup my MQTT
all i want is that every keyinput should be reported to my MQTT Broker
connection to my broker is working
but the states are not reported to the MQTT Broker i only see the state -1 which i setted as startup script
I got stucked.
and setup my MQTT
Re: Keypad MQTT on ESP
The images are not visible.
Why not use a keypad plugin for this?
good question i never knew there are some plugins.
ill try when the wiki is available again.
i dont know how to use plugins yet
You can also use the Read The Docs: https://espeasy.readthedocs.io/en/lates ... lugin.html
ok found it but dont know how to add them in my existing espeasy firmware
Just use the build in which they are include (normal/test/dev)
i get exactly the same.....
no effect on pressing any button
- budman1758
If the plugin is working you will get an event in the log. You then need rules to act on the event. Unless you changed the label in the device page you will get
the event "ScanCode" with a 2 digit value. You need to write some rules to do anything from that event. See the code notes at the top of this page.
https://github.com/letscontrolit/ESPEas ... KeyPad.ino
Users browsing this forum: Bing [Bot] and 79 guests
