hello
is there an android apk available which you would recommend for getting data from espeasy flashed device.
just a native app to get the sensor data
Android APK
Re: Android APK
ESPEasy Mega has a built-in web page that will provide basic status data to your devices. Visit this local IP:
http://<YOUR_ESPEZ_IP>/dashboard.esp
Or you can write your own custom web page to report the information in the format that you want. The custom page can include buttons to control your devices. More info: https://www.letscontrolit.com/wiki/inde ... _Dashboard
If you intend to access ESPEasy from outside your local IP then be aware that this will require router port forwarding and security risks. So not recommended.
Re: Android APK
Hello Thomas,
many thanks. The dashboard is exactly what i need
Greetings
Greetings
