Nodemcu V3 with BS18b20, no temp values !
I have a nodemcu V3 with BS18b20, had it running with arduino code no problem. I thought I would try ESPEasy, but I'm not getting any temp values, they say 0.00. I switched from GPIO2 to GPIO14, but still get same results. Everything is soldered no breadboards etc. Is there a simple step or config I've missed.
Any pointers would be greatly appreciated
INIT : Booting Build nr:120
WIFI : Connecting... 1
WIFI : Connected!
INIT : I2C
INIT : Boot OK
INIT : Normal boot
WD : Uptime 0 ConnectFailures 0 FreeMem 28752
WD : Uptime 1 ConnectFailures 0 FreeMem 28720
WD : Uptime 1 ConnectFailures 0 FreeMem 28688
WD : Uptime 2 ConnectFailures 0 FreeMem 28656
WD : Uptime 2 ConnectFailures 0 FreeMem 28624
<> Task Device Name Port IDX/Variable GPIO Values
Edit 1 Temperature - DS18b20 TestTemp 28-8a-93-1-17-13-1-9a GPIO-14 Temperature:0.00
Edit 2 Temperature - DS18b20 TestTemp1 28-ce-27-77-91-a-2-cd GPIO-14 Temperature:0.00
WIFI : Connected!
INIT : I2C
INIT : Boot OK
INIT : Normal boot
Re: Nodemcu V3 with BS18b20, no temp values !
Did you add a pull-up resistor (4k7 or 10k work fine here) to the GPIO port?, that does seem to help. The internal pull-up is often too weak (80-100k)
The topic starter claims it was running on the NodeMCU.
So the internal pull up may be sufficient, but it is not enabled by default in ESPEasy.
You can enable it in the Hardware tab in the GPIO boot states.
This issue has come up before. My memory is fuzzy on the details, but I recall that the Arduino code works Ok with the internal weak pullup. But the ESPEasy code is less tolerant to DS18B20 bit timing and installing the external 4.7K pull-up resistor seems to help out.
But per @TD-er's recommendation, enable the internal weak pull-up first. It might solve the problem. If not, install the external pull-up.
Many thanks for the ideas.
Sorry, I should have mentioned I have a 4.7k resistor installed, device is powered from 3.3v on NODEMCU
- Tested resistor -ok 4.7k
- Tried enabling GPIO14 to start on high
- Re-flashed
- Removed second temp sensor
- Tried different temp sensor
- Tried another nodemcu board
- Tested connections
- Tried sensor without resistor - could not find device address.
Behavior is consistent ie. no temp value in the devices web screen.
Open to any suggestions or ideas
- Re-flashed
Your boot message shows you're running R120. That's a very old release. I suggest you try the latest Mega release instead.
https://github.com/letscontrolit/ESPEasy/releases
Certainly can try it, I thought R120 was the latest stable release
Loaded latest version of MEGA and it worked first go, now have 5 sensors all working well.
I thought R120 was the latest release as it was in the tutorials etc. Looking deeper I now see it is pretty old as eluded.
Many thanks to everyone who replied.
Now to get it to talk to thingsboard and mqtt.
Users browsing this forum: No registered users and 62 guests
