ESPEasyRV Electronical Upgrade of a Motorhome
Some pictures of the old electronics, self-soldered, the battery sensor self designed and built on selfmade pcb board, read using AD, an old modified USB GPS mouse attached to serial port, huge amount of spaces used, bunch of cables through the whole motorhome. But it worked through the past 15 years reliably without any changes except the addition of two NTC resistors to get and display inside/outside temperatures (not to be seen on the old pictures I took 16 years ago, sorry), the data are downloadable using a serial cable to the laptop.
In this current project which I name ESPEasy-RV I want to collect all data of my motorhome I could get, i.e. level of water tank, level of LPG tank, battery states, solar panel energy production, levelling of the vehicle itself, track trips, display time and ambient data, aso. The amount of sensors needed took me to the decision to realize it using ESPEasy. This will reduce the weight of the motorhome by a ton of copper cables, increase the amount of data collectable, give much more precise readings. And last but not least, it will increase the WAF of my doing as already happened with my installations in my house/living room.
This project will be steadily growing. At first I want to implement the features of my old Tiny Tiger which are battery state monitoring (voltage/current/power/remainig capacity), trip tracking and inside/outside temperatures.
So, lets start.
Equipment currently used: Huawei mobile 4G Hotspot, three Wemos D1, one for the GPS sensor, one for a MPU6050 gyro and a BMP280, one for a 4.3" Nextion display.
The first steps are done, I will not post the hardware itself at this time, is currently not presentable. But some results already appear on the Nextion display.
pi@raspberrypi:~ $ man woman
No manual entry for woman
pi@raspberrypi:~ $
Re: ESPEasyRV Electronical Upgrade of a Motorhome
Using a MPU6050 I am finally able to level the motorhome form drivers seat by moving the vehicle and / or alter the pressure in the air suspension. Has been in the past sometimes really painful to get the vehicle correctly levelled:
- Murphy1.jpg (97.49 KiB) Viewed 90619 times
pi@raspberrypi:~ $
So, now we are coming to more technical stuff.
Step1: Get the levelling of the Motorhome to have a good night. My purpose: getting an idea of the levelling of the vehicle to assure a good working refridgerator and not rolling out of bed during the night. And this idea I need when I am actually parking the vehicle, sitting on drivers chair. For further modifications the pcbs have to be easily removable, so I decided to choose a strong magnetic fixing.
Hardware needed (sorry, some of the links are outdated but at least may be useful to get an idea):
- GY521 MPU6050 Gyro Sensor
- Wemos D1 mini
- Mini 12v-5v Step Down Power Supply
- A piece of wood as a basis for the Wemos, power supply and sensors, in my case 100x150x8mm
- four holed neodym magnets, ordering them, don't forget to assure that you have fitting screws
- a piece of iron tin, in my casr 120x170x1mm
- hot glue
- a flat, horizontal, hidden area to fasten the sensor plate in the motorhome.
The iron plate is fixed with hot glue onto a flat, almost horizontal surface in the underbed compartment at the farest end of the vehicle. Tipp: before applying the glue, heat up the surface and the iron plate a little bit (ofcourse taking into account the heat resistance of the surface!!), you will get better and more durable results:
The four magnets are screwed to the plate:
And the plate holding the hot glued pcbs will be in place fixed and horizontal:
On the left Wemos D1, top mini step down voltage regulator, right GY521 / MPU6050 sensor - and enough space for more sensors to come.
In the next step I will post my rules calculating a (for me) understandable tilt and explain, how to get them onto the Nextion.
pi@raspberrypi:~ $
At first I am creating two tasks, every needed axis gets one:
Additionally I am creating a dummy device to be able to calculate averages and a dummy device to be able to switch on / off sending the data to Nextion manually. I did this to minimize Wifi traffic during the times the levelling is not needed.
Switching measurement On / Off (resp. sending the data):
Hitting the button "Messung" on the Nextion display (refer picture post #2 in this thread) sends an idx of 100 from Nextion to its attached ESPEasy device and this will fire an event on the device with Gyro attached:
On Di#idx=100 Do
SendTo 49,'event,Messung' //Device #49=Gyro-device
EndOn
On Messung Do
If [Auto#Messung]=1
TimerSet,1,0 //Stop sending process
TaskValueSet 6,1,0 //Store that sending is stopped
SendTo 28,'Di,page0.h1.val=100' //setting slider vertical (tilt front/back) into the middle = Zero-position
SendTo 28,'Di,page0.h1.pic2=4' //setting slider button to blue colored
SendTo 28,'Di,page0.p1.pic=4' //setting middle mark to blue color
SendTo 28,'Di,page0.t1.txt="Tilt_längs:Aus"'
SendTo 28,'Di,page0.h0.val=100' //setting slider horizontal (tilt left/right) in the middle = Zero-position
SendTo 28,'Di,page0.h0.pic2=3' //setting slider button to blue colored
SendTo 28,'Di,page0.p0.pic=3' //setting middle mark to blue color
SendTo 28,'Di,page0.t0.txt="Tilt_quer:Aus"'
SendTo 28,'Di,page0.b0.pic=5' //setting button "Messung" to blue LEDs
Else
TaskValueSet 6,1,1 //Start sending process
TimerSet,1,1 //Store that sending is started
SendTo 28,'Di,page0.b0.pic=6' //setting button "Messung" to green LEDs
SendTo 28,'Di,page0.h1.pic2=9' //setting middle mark to green colored
SendTo 28,'Di,page0.p1.pic=9' //setting slider button to green colored
SendTo 28,'Di,page0.h0.pic2=8' //setting middle mark to green colored
SendTo 28,'Di,page0.p0.pic=8' //setting slider button to green colored
EndIf
EndOn
On Rules#Timer=1 Do
TimerSet 1,1
TaskRun 1 //trigger the correspondig tasks for X / Y-axis
TaskRun 2
EndOn
On task-triggered events I generate a little bit of averaging to minimize influence of whatever, i.e. egine vibrations and write the results directly on the Nextion screen.
On X#X Do
let 4,%v3%
let 3,%v2%
let 2,%v1%
let 1,[X#X]
TaskValueSet 3,1,(%v1%+%v2%+%v3%+%v4%)/4000*5.625+0.7 //bringing the raw data in somewhat useful format for my eyes and calibrating zero (^= +0.7)
let 8,([XY#X]*10)+100 //adopting to the middle of the slider in Nextion (°=100)
If [Auto#Messung]=1 //doublecheck, if sending data is not initiated by the task schedule itself
SendTo 28,'Di,page0.h1.val=[int#8]'
SendTo 28,'Di,page0.t1.txt="Tilt_längs:[XY#X]"'
EndIf
EndOn
On Y#Y Do
let 12,%v11%
let 11,%v10%
let 10,%v9%
let 9,[Y#Y]
TaskValueSet 3,2,(%v9%+%v10%+%v11%+%v12%)/4000*5.625-0.4 //bringing the raw data in somewhat useful format for my eyes and calibrating zero (^= -0.4)
let 16,([XY#Y]*-10)+100 //adopting to the middle of the slider in Nextion (°=100)
SendTo 28,'Di,page0.h0.val=[int#16]'
SendTo 28,'Di,page0.t0.txt="Tilt_quer:[XY#Y]"'
EndIf
EndOn
And here we are, assuming that the Nextion display is placed correctly somewhere reachable and visible by the driver we have a running levelling gauge for our motorhome. That (ESP)Easy(RV)
In the next step I will show, how to get the water level of the tank.
[edit]
Eeehm, I forgot: For calibration of the levelling I took an ordinary bubble level, placed the car in absolute levelled position and added the correspondig values to my rules code (in this case: X-direction: +0.7 and Y-direction: -0.4))
[/edit]
pi@raspberrypi:~ $
My motorhome isn't the youngest one and the old system to show the water level inside the freshwater tank has only four leds to show full / medium / low / empty. But if it shows "empty" there is still somewhat of 40 liter of water inside (from a maximum of 100 liter). So I can't name it accurate in any way, its just useless if you want to know if you get the shampoo out of your hair during taking a shower.
What I am presenting now is a good part off topic concerning the forum itself. But to prevent someone others to run into the same mistakes I made, I would like to explain in detail what I did do, perhaps may be useful for others.
My design will be a floater in the tank equipped with a MPU6050 to get the angle of the floater for calculating the water level.
I used (or will use) the following parts:
- a plastic pill bottle, modified to get waterproof, a petling would do a better job I guess, but I didn't want to order 20 pieces to get a reasonable price or to order one for somewhat 8.50€-10€ (as I now know, I should have done that )
- 2x waterproof 4-pole docking plugs to connect cables once inside and once outside of the tank
- 2x M6 Metric Cable Gland Waterproof for 2-4mm cables to get the cable for the sensor through the cap of the floater and through the tank wall
- Some meter of 4 core cable
- some 4 pin connectors
- 0.5mm stainless steel tin and stainless steel 2mm straight welding rod
- 1x Stainles steel lug (mine is a female one)
- O-rings to seal the lug screw
- preferrably a 3D-printer
- ...and, ofcourse, 1x MPU6050 GY521, 1x Wemos D1 mini, 1x ESPEasy
My stupid idea to save money by using a pill bottle for my floater made the highest efforts to get it waterproof. But nevertheless, I show you, which stupidity I did.
My first waterproofing test I did with the unmodified bottle by submerging it for ~5 hours:
Surprisingly the sealing of the cap was originally made of paper (!), which let the water through after a while. So I replaced it ny cutting out a sealing out of an old bycicle tube. Second submerge test was successful.
I produced an arm for my floater made of stainless steel parts:
And did a floating test, which was really promising that it will work:
And at last I added a cable to my pill bottle, made another sumerging test with it, this time in a depth of 0.5m, which should be enough, which it passed.
Next step will be the placing of sensor and cables. Due to the fact that the submerging tests and the modifying of the pill bottle took so much time, for me is not left enough day today to continue now. So stay tuned....
pi@raspberrypi:~ $
Have you considered using an ultrasonic distance sensor?
There are also water-proof versions available.
If you considered it, then I do want to know why it was found to be useless.
Two days ago someone posted here a waterproof ultrasonic sensor, with a minimum working range of 30 mm. That could be my solution in the future, yes. But I am too far with my floater to stop now.
pi@raspberrypi:~ $
pi@raspberrypi:~ $
Yep, those are killing for the WAF.
It isn't a cheap one and I don't know the measuring principle.
But it is available for several ranges in liquid levels, the lowest being 0 - 1m.
It looks like it outputs an analog value, analogue (pun intended) to the water level I assume.
Believe me, a floater is a good and reasonable solution. And if you still have any doubts: why, do you hink, the gasoline tank of your car still is equipped with a floating sensor to give you an idea, when to approach a gasoline station?
pi@raspberrypi:~ $
If you can mount the floater reliable to whatever you use to determine its angle (e.g. potmeter) then it is for sure the preferred solution.
It probably does give a lot more 'filtered' output compared to measuring a single spot.
My only worry was that it may need more modifications compared to a smaller sensor.
That is a hydrostatic measurement or a pressure transmitter.TD-er wrote: ↑08 Jun 2020, 20:19 Jimmy sent me this sensor link for a liquid level sensor: https://a.aliexpress.com/_dWTFi8A
As for thé float, on a long stick, you will need to think about slushing in the tank, water bar is incredible in what it can do.
Something like this https://www.aliexpress.com/item/329342 ... web201603_is better suited, can also be built in a stilling well
Thats exactly what I am still worried about, fast moving water has incredible forces. And thats why I didn't trust a waterproofing only by floating on the surface but submerged the floater. I would trust my design much more if I could give some pressure (somewhat like 1.5-2 bar) on the submerged floater, but I don't have the equipment for doing this. I had a BME280 at hand and have added it to the sledge the sensor is sitting on to be alarmed if the humidity inside rises. And yes, I know that there are better solutions for leakage alarms, but the BME has been laying around.
And I will put a handful small, fast fuses into the wiring....and additionally I will use a condom
During the measurement test yesterday I noticed that the ring for holding the stick is not the best solution. Theres a danger that it could get stuck. So I will have to alter the design anyway and I will put the floater into the middle of the tanks heighth so I could cut the length of the stick, thanks for your suggestions.
No, its not better suited, its the PERFECT SOLUTION. I will contact the seller, he says he could deliver different sizes. Thanks a lot for the link and I am glad to have put my little project over here. And Thanks @TD-er and @grovkillen for their thoughts, too.HomeJCL wrote: ↑09 Jun 2020, 13:25 [...]
Nevertheless, because I have to drill into the tank anyway and I need a solution right next week I will give the floater a try. Its almost ready to do so and to be frankly, I am pretty curious if it would work.
pi@raspberrypi:~ $
Although with jam jar don’t overcook it on the pressure !!!
More sophisticated https://www.christopherwardforum.com/v ... 33&t=10816
Have a soft spot for watches
This "thing" went inside my freshwater tank after being - more or less accurate - calibrated last night by using a bowl and some liters of water:
Now its inside of the tank and I will show you, why I did these efforts (despite the fact that with some more research probably it could have been easier). The next picture shows the reading of the onboard water level info:
Its says, the tank is almost empty and at this moment - if I should trust the LEDs - it would be risky to take a shower. But I filled the tank already with 45 liters of water - almost the half of its volume of 100 liters. The reading of my floater/sensor combination tells me:
The difference to the amount of water I filled into the tank is easy to explain: its the weight of the floater. So the weight eats up some 7-9l of water before the floater begins to float. At least this is acceptable, the gasolin gauge in your car behaves the same way.
Lets leave the handcraft part and return to ESPEasy. The device is configured:
And a dummy device for storing values neede for calculation:
The way the end of the floater rises is a direct linear function to the read acceleration of the sensor. So the height of the floater above the tanks bottom can be calculated directly by the factor length floater/16384 (max reading of the MPU6050 +/- direction). Depending on the floater angle in relation to the surface of the water (optimum would be a ball, my floater is a cylinder) the factor varies a little bit over the height, I took an estimated average of this factor. To minimize the influence of water movement I am averaging the raw readings to the maximum I can using ESPEasy, might be possible to reduce it.
On X#X Do
let 15, %v14%
let 14,%v13%
let 13,%v12%
let 12,%v11%
let 11,%v10%
let 10,%v9%
let 9,%v8%
let 8,%v7%
let 7,%v6%
let 6,%v5%
let 5,%v4%
let 4,%v3%
let 3,%v2%
let 2,%v1%
let 1,[X#X]
let 16,(%v1%+%v2%+%v3%+%v4%+%v5%+%v6%+%v7%+%v8%+%v9%+%v10%+%v11%+%v12%+%v13%+%v14%+%v15%)/15 //averaging
TaskValueSet,4,1,%v16%
let 16,292-[test#dummy]*-0.021 // 292 = lenght of the floater minus height of mounting point, 0.021 = tan-constant calculated from max to actual accreleration
taskvalueset,4,2,%v16%
let 16,[int#16]*450*680/1000000 // depending on the size of the tank calculation of volume
TaskValueSet,4,3,%v16%
SendTo 28,'Di,page3.t2.txt="Stand:[int#16]l"' //and send the whole stuff to the Nextion device
SendTo 28,'Di,page3.j0.val=[int#16]'
SendTo 28,'Di,page3.t3.txt="[Temp#C]°C"'
SendTo 28,'Di,page3.t4.txt="[Temp#H]%"'
SendTo 28,'Di,page3.t5.txt="[Temp#P]hPa"'
EndOn
...and again, thats all. I got a perfect information of my oboard water. Only thing is: up to now, the vehicle itself wasn't moved. Wether my design is standing the rough environment of a moving home the future wil tell me. Thanks to ESPEasy, its mighty sensor connection posibilities in combination with rules.
In this case, handcrafts took around two days, attaching and configuring the sensors, adding the rules was done almost in minutes.
In the next step I will present a trip/ travel tracker.
pi@raspberrypi:~ $
1. the readings of the water level has - between ~8l and 95l - an accuracy of 1 liter, in a tank of 32 cm of height
2. the levelling system I described before is that sensible, that it told me after filling 50 liters of water into the tank (this is placed in the left side of the vehicle), that the vehicle should be levelled once again - and the RV itself has a gross weight of almost 3.000 kg.
pi@raspberrypi:~ $
Not sure what range of those you should use, as I can imagine a moving tank of water may give quite a strong impact force every now and then.
Not that you should change it now, but just theoretically, could it be done?
If you place those sensors at each corner, maybe the water tank can then also be used to measure how level the vehicle is.
pi@raspberrypi:~ $
You can use a flowmeter and count what you use.
Another possibility is descripe here: https://www.camperforum.nl/viewtopic.php?t=8457836
Its in Dutch, so you need Google Translate.
Yes, ofcourse. But how do I get the current amount of water when filling the tank only partly? I have been at many places where I get the water not directly but have to carry it in a jerry can. And believe me, pouring rain and 250m to walk forces you to minimize the momentary efforts.
A hydraulic pressure sensor is useable, yes. But it seems as if am fine with my floater. I am pretty sure that I have to change this or that, that's why I have built this guy detechable. But the principle is pretty accurate as I know now. The lack of the last 8 liters isn't important, the display will show "<10l" (you won't be able to take a shower with less than 10l of water), the maximum level isn't important either, it will show ">95l". And don't forget: total amount of spent money less than 5€. Beat it.
pi@raspberrypi:~ $
Everything stayed in its place, readings of waterlevel during driving are useable to make a decision if our next place we are heading for has to have the possibility of tanking water or not. The level was displayed in a range of +/- 5l. So I can tell, the design is worth the efforts I had.
pi@raspberrypi:~ $
pi@raspberrypi:~ $
Was mainly asking to know if the reported distance was similar to the trip counter of the car
And have a look, using the experimental cache controller, your html-based GPS2csv converter and converting the data to gpx file, importng this to an online OMS-GPX viewer the result looks like this one (I removed the underlaying map):
In the next step I will explain in detail what I have done how.
pi@raspberrypi:~ $
I've been using it myself for over a year in several units now.
I will also test it on LittleFS to see how that performs as you then may be able to record a lot more samples on 16M nodes
The offset from the trip meter in the dashboard of your car may also be off due to differences in tires etc.
I always wondered if the speed meter and the trip meter were in sync, as I have an offset of roughly 8% with the GPS speed. (reported speed is too high)
I guess it makes no sense to have them out of sync, but that the manufacturers would not dare to show a speed which is possibly lower than the actual speed as that may lead to law suits.
For example my offset in reported speed differs between summer and winter tires. But maybe that can also be related to the fact the garage makes sure the tires they put on are at the right pressure and after half a year driving the just removed ones may not be anymore.
You need:
- a GPS device, mine is a Neo6M, others are supported, too. I tok the Neo6M because I ave positive experiences in other automotive projects. Supported devices are documented in the ESPEasy readthedocs
- a Wemos D1
- another Wemos D1 and the Nextio display
- In my case ESP_Easy_mega_20200608_custom_ESP8266_4M2M.bin to get the cache controller and some more space to store data
On the road I get the current GPS readings including some calculated values:
The fields names are self explaining.
Using the last custom build
Defining some devices:
is the prerequisit for what I am doing now.
Since the last release the GPS plugin sends an event depending on the travelled distance including the calculated distance since last event. I take this value to add it to the total distance travelled, write it into the dummy device and send the values to the cache controller which writes it into the flash:
On GPS#travelled Do
if %eventvalue%<500 //just make sure there's no misreading of the GPS sensor
let 1,[Strecke#Strecke]+%eventvalue% //adding the distance
TaskValueSet 2,1,%v1% //setting dummy values
TaskValueSet 2,2,[GPS#lat]
TaskValueSet 2,3,[GPS#long]
TaskValueSet 2,4,[GPS#alt]
TaskRun 2 //run the task to write the data into the flash using the cache controller
let 1,[GPS#spd]*3.6 /calculating speed in km/h
SendTo 28,'Di,page2.t7.txt="[int#1]km/h"'
SendTo 28,'Di,page2.t1.txt="Long:[GPS#long]°"'
SendTo 28,'Di,page2.t2.txt="Lat:[GPS#lat]°"'
let 1,[GPS#alt]
SendTo 28,'Di,page2.t3.txt="Höhe:[int#1]m"'
SendTo 28,'Di,page2.t4.txt="Speed:[GPS#spd]m/s"'
let 1,[Strecke#Strecke]/1000
SendTo 28,'Di,page2.t5.txt="Trip:%v1%km"' //displaying the total distance since last trip reset
EndIf
EndOn
On TripReset Do
SendTo 28,'Di,page2.t5.txt="Trip:0.0km"'
SendTo 28,'Di,page2.t7.txt="0km/h"'
TaskValueSet 2,1,0
TaskValueSet 3,1,%uptime%
TaskValueSet 3,2,0
SendTo 28,'Di,page2.t6.txt="Zeit:%c_m2dhm%([Strecke1#Tripzeit])"'
TaskRun 2
EndOn
On Clock#Time=All,**:** Do
SendTo 28,'Di,page1.t10.txt="%systm_hm%"' //sending the GPS-depending time to the zime fields of the various Nextion pages
SendTo 28,'Di,page2.t10.txt="%systm_hm%"'
SendTo 28,'Di,page3.t1.txt="%systm_hm%"'
let 1,%uptime%-[Strecke1#Startzeit] // calculating the trip time
TaskValueSet 3,2,%v1% //setting the dummy value
SendTo 28,'Di,page2.t6.txt="Zeit:%c_m2dhm%([Strecke1#Tripzeit])"' //and sending it to Nextion display
EndOn
On System#Boot Do
//Warmstart überleben Tripzeit
let 1,0-[Strecke1#Tripzeit]
TaskValueSet 3,1,%v1%
TaskValueSet 3,2,0
EndOn
On NextionInit Do
let 1,[GPS#spd]*3.6
let 1,[GPS#alt]
EndOn
@TD-er was so kind topost:
Using the cache controller and the html-code I get a semicolon seperated .csv file which - with a little bit of work - I can convert them to a .gpx format using GPSBabel.TD-er wrote: ↑30 May 2020, 09:48 [...]
On the file system I have placed this .htm file (use .htm as extension, not .html)
Via the browser you can then open this .htm file and export all recorded samples to a .csv file
A stored task takes 24 bytes, so storing 2 dummy tasks like this takes 48 bytes per interval.
On a build with 4M flash divided in 1M filesystem, you can store roughly 750k of files.
<html> <script src="https://cdn.jsdelivr.net/npm/lodash@4.17.11/lodash.min.js"></script> <script> const TASKS_MAX = 12; const VARS_PER_TASK = 4; function sleep(ms) { return new Promise(resolve => setTimeout(resolve, ms)); } class DataParser { constructor(data) { this.view = new DataView(data); this.offset = 0; this.bitbyte = 0; this.bitbytepos = 7; } pad(nr) { while (this.offset % nr) { this.offset++; } } bit(signed = false, write = false, val) { if (this.bitbytepos === 7) { if (!write) { this.bitbyte = this.byte(); this.bitbytepos = 0; } else { this.byte(signed, write, this.bitbyte); } } if (!write) { return (this.bitbyte >> this.bitbytepos++) & 1; } else { this.bitbyte = val ? (this.bitbyte | (1 << this.bitbytepos++)) : (this.bitbyte & ~(1 << this.bitbytepos++)); } } byte(signed = false, write = false, val) { this.pad(1); const fn = `${write ? 'set' : 'get'}${signed ? 'Int8' : 'Uint8'}`; const res = this.view[fn](this.offset, val); this.offset += 1; return res; } int16(signed = false, write = false, val) { this.pad(2); let fn = signed ? 'Int16' : 'Uint16'; const res = write ? this.view[`set${fn}`](this.offset, val, true) : this.view[`get${fn}`](this.offset, true); this.offset += 2; return res; } int32(signed = false, write = false, val) { this.pad(4); let fn = signed ? 'Int32' : 'Uint32'; const res = write ? this.view[`set${fn}`](this.offset, val, true) : this.view[`get${fn}`](this.offset, true); this.offset += 4; return res; } float(signed = false, write = false, val) { this.pad(4); const res = write ? this.view.setFloat32(this.offset, val, true) : this.view.getFloat32(this.offset, true); this.offset += 4; return res; } bytes(nr, signed = false, write = false, vals) { const res = []; for (var x = 0; x < nr; x++) { res.push(this.byte(signed, write, vals ? vals[x] : null)); } return res; } ints(nr, signed = false, write = false, vals) { const res = []; for (var x = 0; x < nr; x++) { res.push(this.int16(signed, write, vals ? vals[x] : null)); } return res; } longs(nr, signed = false, write = false, vals) { const res = []; for (var x = 0; x < nr; x++) { res.push(this.int32(signed, write, vals ? vals[x] : null)); } return res; } floats(nr, signed = false, write = false, vals) { const res = []; for (var x = 0; x < nr; x++) { res.push(this.float(write, vals ? vals[x] : null)); } return res; } string(nr, signed = false, write = false, val) { if (write) { for (var i = 0; i < nr; ++i) { var code = val.charCodeAt(i) || '\0'; this.byte(false, true, code); } } else { const res = this.bytes(nr); return String.fromCharCode.apply(null, res).replace(/\x00/g, ''); } } } const parseConfig = (data, config, start) => { const p = new DataParser(data); if (start) p.offset = start; const result = {}; config.map(value => { const prop = value.length ? value.length : value.signed; _.set(result, value.prop, p[value.type](prop, value.signed)); }); return result; } /* const fileFormat = [ [...Array(1000)].map((x, i) => ({ prop: `samples[${i}].values`, type:'floats', length: VARS_PER_TASK })), [...Array(1000)].map((x, i) => ({ prop: `samples[${i}].timestamp`, type: 'longs', signed: false })), [...Array(1000)].map((x, i) => ({ prop: `samples[${i}].controllerIndex`, type: 'byte' })), [...Array(1000)].map((x, i) => ({ prop: `samples[${i}].taskIndex`, type: 'byte' })), [...Array(1000)].map((x, i) => ({ prop: `samples[${i}].sensorType`, type: 'byte' })), [...Array(1000)].map((x, i) => ({ prop: `samples[${i}].valueCount`, type: 'byte' })), ]; */ const fileFormat = [ { prop: 'values', type:'floats', length: VARS_PER_TASK }, { prop: 'timestamp', type: 'int32', signed: false }, { prop: 'controllerIndex', type: 'byte' }, { prop: 'taskIndex', type: 'byte' }, { prop: 'sensorType', type: 'byte' }, { prop: 'valueCount', type: 'byte' }, ]; /* loadConfig = () => { return fetch('http://192.168.1.182/cache_json').then(response => response.arrayBuffer()).then(async response => { document.body.innerText = parseConfig(response, fileFormat); }); } */ loadConfig = async () => { const floatvalues = {}; const info = await fetch('/cache_json').then(response => response.json()); let csv = info.columns.join(';') + '\n'; for (var j = 0; j < (VARS_PER_TASK * TASKS_MAX); j++) { // TODO make "unused" value configurable floatvalues[j] = 0; } // TODO must also read partial files (< 24k) var maxFileNr = info.files.length; for (var filenr = 0; filenr < maxFileNr; filenr++) { var elem = document.getElementById("bar"); var width = Math.round(100.0 * (filenr / (maxFileNr - 1 ))); elem.style.width = width + '%'; elem.innerHTML = width * 1 + '%'; const binary = await fetch(info.files[filenr]).then(response => response.arrayBuffer()).then(async response => { const samples = {}; var arrayLength = response.byteLength / 24; //1000;//samples.length; [...Array(arrayLength)].map((x, i) => { samples[i] = parseConfig(response, fileFormat, 24 * i); }); // TODO Fetch number of samples. for (var i = 0; i < arrayLength; i++) { var floatIndex = VARS_PER_TASK * samples[i].taskIndex; samples[i].values.forEach(item => { floatvalues[floatIndex] = item; floatIndex++; }); // TODO quick fix to remove damaged samples due to writing to closed files. if (samples[i].timestamp > 1500000000) { const utc_date = new Date(samples[i].timestamp * 1000); csv += samples[i].timestamp + ';' + utc_date.toISOString() + ';' + samples[i].taskIndex; for (var j = 0; j < (VARS_PER_TASK * TASKS_MAX); j++) { csv += ';' + floatvalues[j]; } csv += '\n'; } } await sleep(100); // Wait to prevent the ESPeasy node from rebooting. }); } // document.body.innerText = csv; // document.body.innerHTML = `<a href='data:text/plain;charset=utf-8,${encodeURIComponent(csv)}' download='test.csv'>click me</a>`; const a = document.createElement('a'); const aText = document.createTextNode('Download'); a.href = window.URL.createObjectURL(new Blob([csv]), {type: 'text/csv'}); a.download = 'test.csv'; a.appendChild(aText); a.classList.add("button"); document.getElementById("downloadLink").appendChild(a); // document.body.appendChild(a); } </script> <style> #progress { width: 100%; background-color: #ddd; } #bar { width: 0%; height: 30px; background-color: #4CAF50; text-align: center; line-height: 30px; color: white; } h1, h2 { font-size: 16pt; margin: 8px 0; } h1, h2 { color: #07D; } * { box-sizing: border-box; font-family: sans-serif; font-size: 12pt; margin: 0; padding: 0; } .button { background-color: #07D; border: none; border-radius: 4px; color: #FFF; margin: 4px; padding: 4px 16px; } </style> <body> <h2>ESPeasy cache to CSV</h2> <BR> <button class="button" type="button" onclick="loadConfig()">Fetch cache files</button> <div id="progress"> <div id="bar">0%</div> </div> <BR> <p id="downloadLink"></p> </body> </html>
At first I have to cleanup the data extracted from the devices flash using the html-code of @TD-er, I am doing this using Excel. You have to assure, that the excel-produced "," inside the exported .csv have are converted to ".". I am doing this currently simply using wordpad. Works. Up to now I was concentrated purely on the geodata Latitude and Longitude, much more is possible. Out of the .csv file I build a tab-delimited file with a header setting, structure looks like this:
No Latitude Longitude
0 xx.xxxxxxx y.yyyyyyyyy
pi@raspberrypi:~ $
I did remove the underlaying map, but if you do it by yourself, you will have a wonderful mapview of your travel.
The map with the track on it clarifies, why the traced distance using GSP plugin will never be able to get the 100% accurate reading. Corners are looking like this:
Thats because the distance is calculated between the current and the last geo position. This calculation will be a straight line, so the corners are partially cut. But the total difference for me personally is absolute neglectible. E.g. on a trip of around 30km the odomoter reading of the car differed less than 100m to the reading of the trip counter. The readings of my system will be more accurate in the future, because with the latest release I get the calculated distance pretty accurate. So I will reduce the "Distance Update Interval" to somewhat like 25 or 30m. We will see.
Summed up: the whole system is built up with a handful lines of code in the rules. Thats all, Thanks to ESPEasy, its mighty sensor connection and the underlaying code of the developers.
[edit]
Spent money: less than 11€. Beat it.
[/edit]
pi@raspberrypi:~ $
If someone uses the free services and tools I linked in my posts, don't forget to donate the developers of these tools. Its worth it and I am pretty sure that they have had a lot of work and costs to develop and present the tools and functions.
pi@raspberrypi:~ $
On TripReset Do
TaskValueSet 2,1,0
TaskValueSet 3,2,0
TaskRun 2
EndOn
pi@raspberrypi:~ $
This way you could get an accuracy based on updates roughly 3 times a second.
But I think this may also introduce an error which will be reporting a longer distance then actually traveled as you may then measure a saw-tooth pattern with HDOP as some sort of amplitude.
For slow speed movements this may attribute to quite some error.
Today I have to be on the road anyway and I redu ed the update interval to (I think) 40 m. I will report.
pi@raspberrypi:~ $
Today I will have a look at my old system which is still in place and will calculate the distance using google maps for comparism. And I am pretty sure, that your routines give better results, at least compared with my old system. Additionally I will use my app for tracking bycicle trips. So today in the evening we will get some more stuff to discuss.
pi@raspberrypi:~ $
Google maps calculation: 15.8km, odometer reading: 15.4km, trip recorder: 15.79km. Trip profile: 10% in village, 90% highway / overland. Difference odometer reading <-> trip recorder/google -2.5%
My app Eco biker completly useless, recorded 3.4km overall. Surprise: the GPS-mouse of my old system has exhaled today the holy breath of electronics and quitted working after 15 years - what a mess concerning the old system but how lucky am I that I did setup the new system ontime. Gotcha!
The distance update interval I had set to 50m. The track on a map looks like this:
You can see, the track is much closer to the (edged,too) map drawing.
Failure discussion:
- The distance reading of the ESPEasy trip recorder works pretty well.
- This time the odometer was wrong. Explanation could be: The high amount of highway influences the odometer reading because the tyre diameter rises with higher speed and thus counts less distance.
I added time and altitude information to the modified file for GPSBabel and - what a surprise, uploading it to the GPX-Viewer I get a whole profile of the trip:
Isn't it nice?
Structure of the data for GPSBabel:
Time Latitude Longitude Altitude
2020-06-15T13:02:41.000Z xx.xxxxxxx y.yyyyyyyy 91.09999847
2020-06-15T13:04:00.000Z xx.xxxxxxx y.yyyyyyy 93.1999969
Next step will be to move the battery monitoring from the old system (this part is still working) to my small project. To do this, I have to rebuild the wiring of the batteries, because I am planning to measure the batteries using an INA219. The old system measures the current betwenn batteries and ground, the INA219 needs a modification because this sensor is measuring the high side nof the batterie. Rewiring of the batteries will take a moment, the wires are a little bit stiffer than the wires used for the electronics......So stay tuned.
pi@raspberrypi:~ $
Would be completely useless here in the Netherlands though
From here to Groningen (10 km away), I would measure an altitude difference of 10 meters. (including viaducts)
pi@raspberrypi:~ $
On the other hand, from my desk I can see a nice building 10 km away.
- at first reunion of three test devices to one in production - no further documentation neccessary, question of wiring and cut/paste of rules / configs
- determination of the elevation of the satellite dish
- getting the actual pressure of the air suspension including alarm when travelling with too low pressure (forgotten action after being parked
- probably automatic levelling - depends on the availability of a whereever fitting compressor
- onboard battery monitoring
- solar power monitoring
- sewage tank monitoring
- LPG tank monitoring
- freeze alarm for fresh and sewage water including automatic dump of fresh water tank and tubings and automatic heating of sewage tank
- mobility of the Nextion device inside / outside the vehicle using QI and battery/powerbank
There will appear more options to make the travelling more comfortable, the list might stay growing, so the list isn't complete yet - and I think never will be
pi@raspberrypi:~ $
These all don't have to be on the same ESP node to interact with each other
The devices are able to interact with eachother only by using the unique device id. Currently I have four devices running in my RV: One for the Nextion display, one for inner temperature and levelling, one for the tank level and one for the GPS data. I don't have to take care about IP adresses, I am sending the informations between the devices just by using the devices ids. This makes life pretty easy if you have to switch between different networks. In my case the mobile network onboard the RV and my network at home. If they are in the same network, they'll find each other. Thats a feature I havn't seen anywhere, except ESPEasy.
Believe me, my complete design is based on this feature. I am very grateful to be able to use this like I already do. I will be able to concentrate the momentary data collection into one device for the sensors and one device for the GUI - the Nextion display, yes. But overall there have to be some more nodes - at least to minimize cable routings inside of the vehicle (12V->5V I get almost everywhere, but data connection using cables??) and to the limited features of the sensors itselves concerning e.g. I²C adressing, use of GPIO ports aso. Even the ESP32 won't help.
I may be known as someone who wants to limit power consumption as low as possible - just have a look at different posts of mine here in the forum. But in this case: my old installation draws about 400mA 24/7 without backlighting the display, the four devices I am using now (except the Nextion display) summarized 160mA. So there's a lot of air to play with...
pi@raspberrypi:~ $
Well there are new features coming for the peer-2-peer communication. Even without the need for WiFi, but all the rest it will be the same functionality and more
Intermediate result
Navigation using google maps on an Android 9.0 smartphone
Calculated distance to target: 239 km
Trip reading of vehicles odometer: 234.2 km - aha
Total reading of ESPEasy-RV tripcounter: 238.87 km - perfect
Speed readings of ESPEasy-RV : The whole trip the app Google Maps and the tripcounter of ESPEasy-RV where in perfect synchronization, now and then 1km/h difference, but the other device always reported some seconds later the same value - perfect
@TD-er: you have done an absolute perfect work in an unbeatable time - Thank you, I'll buy you a beer
Levelling the vehicle using ESPEasy-RV levelling meter: Took around 60 secs. to get the RV in perfect level by moving forward/backward and at least lowering the pressure of the air suspension on one side a little bit - perfect
ESPEasy-RV water tank levelmeter: During the whole trip in movement reported values +/- 5l of the real amount of water, from the moment of parking and switching off the engine took 60 secs. to deliver the correct reading - perfect
And: all the informations concentrated on just one display, just a fingertip away, no walking through the RV to get the desired informations.
@Wiki: you have done an unbelievable job, just have a beer now!
Spent money upto now:
Nextion 4.3" display
: 44€
- 4x Wemos D1 (will be less at the end of project): 10€
- 2xMPU6050 breakout board 2€
- 2XBME280 5€
- 1xBMP280 3€
- 1xNeo 6M GPS Sensor 8€
- 3D printer filament <1€
- 4-wire cables 5€
- 2x 3-port 12V/5V USB converter 6€
- 1x mini 12V/5V coverter 1€
Sum.: 85€
Free on market available device with similar functionality: None
Time invested on hardware production:
2 days for the floater, could have been less using more suitable devices
1h for magnetic fixing plate of levelling sensor
Time invested on typing rules and testing/calibrating 2h
Comfortable zone using this tiny little project in praxis: Unpayable
Influence of firmware ESPEasy: unpayable, without I personally wouldn't have been able to bring a project at this speed at this point.
Remember: In the past, 16 years ago, I designed and put into praxis an almost similar project in a timeline of 1 1/2 years!
.....to be continued, stay tuned...
pi@raspberrypi:~ $
Most of our documentation does require some basic knowledge of what ESPEasy can do and how to do it.
It is more like a reference.
So what we do need is to describe a use case to which people can relate and is not too far fetched or artificial just made up to describe some feature.
I think this project could serve as a good use case to describe step-by-step a problem and how it can be solved using ESPEasy.
And the nice thing is, you can extend the problem set with new things to solve and still maintain a story line throughout the introduction chapters.
So keep us posted with your project
In other places I asked the admins to close the thread for answering for others than me and open a parallel thread where things could be discussed. I missed it this time, because in the beginning there were no comments. Probably we could heal this?
I could have opened an own blog, a thread in a rv forum or whatever. The key component of this tiny small project is ESPEasy and so I felt it belongs to here.
Thank you for the flowers....
pi@raspberrypi:~ $
You mean a topic closed for replies, just for documenting it?
nice, isn't it?
pi@raspberrypi:~ $
Yep, if seen as helpful
pi@raspberrypi:~ $
Afterwards we/you can summarize it on the wiki and/or we format it into the ReadTheDocs.
Users browsing this forum: No registered users and 27 guests
