SOLVED AC detector - how to make it work?
pw444
#1 Post by pw444 » 20 Dec 2020, 15:37
Hya,
i have a ESP8266-12 and will use the D8 with a 4N25 as input for an AC detector.
Configuration:
         0-----/\/\/\/\-------- +   1
mains          100K           --^-
                                      D1        4N25    5------ D8 ESP8266
         0----/\/\/\/\/------  +    2               4  ---- GND
                  100K
 D1 1N4007
As plugin P001 switch, i shall use it with PULLUP and when mains detected, GND on pin D8 will internally get HIGH.
My problem. VACC Not working.
My rules are:
On System#Boot do
 GPIO,2,1  // status led - inversed - 1 OFF, 0 ON
 GPIO,12,0 // pb 2-4 PB24
 GPIO,14,0 // pb 5-8 PB58
 GPIO,15,0 // ACC sense
 GPIO,13,0 // pb off PBOFF
on MQTT#Connected do
 event,publishstatus
// loop
// B58 - statusoff P3 D5
On B58 do
  pulse,14,1,500
  pulse,2,0,500
  // stopped - publish
// B24 - status24 P2 D6
On B24 do
  pulse,12,1,500
  pulse,2,0,500
  // started - publish
// BOFF - statusoff P1 D7
On BOFF do
  pulse,13,1,500
  pulse,2,0,500
// VACC - status
on VACC#status do
   if [VACC#status]=1
      let 1,1
      let 1,0
B24, B58, BOFF does what it's defined - pulses the gpios.
By VACC, i get nothing.
Any hint of what may i be doing wrong?
D8 config.png (56.91 KiB) Viewed 17632 times
Re: AC detector - how to make it work?
#2 Post by Ath » 20 Dec 2020, 20:05
I'm a bit puzzled: What are you trying to measure here? Voltage, frequency, on/off state, all three?
pw444
#3 Post by pw444 » 20 Dec 2020, 20:13
Only state - mains on or off - only that.
To isolate the circuit from maisn (AC), i used the optcoupler 4N25.
RobertM
#4 Post by RobertM » 20 Dec 2020, 21:12
Use a 4.7uF capacitor between D8 and GND (in your diagram above)
Now you still have AC voltage at the input.
If the measurement is performed close to zero Volt then the result is 0;)
The capacitor will equalize the oscillation (50-60HZ).
Your mains switches will be detected normally :)
pw444
#5 Post by pw444 » 20 Dec 2020, 21:50
RobertM wrote: 20 Dec 2020, 21:12 Use a 4.7uF capacitor between D8 and GND (in your diagram above)
Thx! ceramic or eletroltic?
RobertM
#6 Post by RobertM » 20 Dec 2020, 22:40
eletroltic
pw444
#7 Post by pw444 » 20 Dec 2020, 23:41
thx, will test and post result.
#8 Post by TD-er » 21 Dec 2020, 14:23
How strong is the pull-up?
That resistor is the one to charge the capacitor and the transistor on the optocoupler is the discharger.
I assume the discharge current is a lot higher compared to the charging current, so it will probably not charge the capacitor.
I think you should use the transsitor in the optocoupler to charge the capacitor and have a weak resistor over the capacitor to discharge it when the transistor remains open.
But then you probably need a stronger (lower resistance) pull-up resistor to charge the capacitor.
Or to make it a lot simpler, have a capacitor over the LED. But then you have to deal with mains voltages.
pw444
#9 Post by pw444 » 21 Dec 2020, 14:35
Hya,
worked, with the following scheme:
replaced D8 by D2 and internal pullup.
By initial tests, it's working.
AC sensor with 4N25.png (69.66 KiB) Viewed 17552 times
pw444
#10 Post by pw444 » 21 Dec 2020, 14:50
TD-er wrote: 21 Dec 2020, 14:23 Or to make it a lot simpler, have a capacitor over the LED. But then you have to deal with mains voltages.
i also thought about it, but dealing with the mains didn't seam a good idea, so i did as the new schema.
Worked on a 5 minut test as i will only be able to test more sometime later this week.
#11 Post by TD-er » 21 Dec 2020, 14:56
Ah that's indeed a way more simple schematic.
Should work just fine.
pw444
#12 Post by pw444 » 21 Dec 2020, 22:56
Ok, guys, something is not right at all.
The pin D2 / GPIO 4 is the input for ACC sensor.
What does happen: VACC status does not change when ACC is detected. So, by devices, i enable Internal PullUp, and.. it works! status of VACC changes form 0 to 1 and 1 to 0 when ACC is detected.
Then after a reboot, PullUp enabled, the VACC status does not change. So, by devices, i disable Internal PullUp and, it works.
Long story short: i have to change the pullup behavior every time after boot to make it work.
The rules are:
On System#Boot do
 let,1,0
 let,2,0
 event,publishstatus
// loop
On B58 do
  pulse,14,1,500
  pulse,2,0,500
On B24 do
  pulse,12,1,500
  pulse,2,0,500
On BOFF do
  pulse,13,1,500
  pulse,2,0,500
on VACC#status do
  if %eventvalue%=1
    if %v1%=1
       Publish,%sysname%/Notify/status,1  // working
  else               // status = 0
    if %v1%=1        // status = 0 var1 =1
       let,1,0
       Publish,%sysname%/Notify/status,0   // finished
    if %v1%=2        // status = 0 var1 =2
       let,1,0
       Publish,%sysname%/Notify/status,2   // cancelled
Any hint?
#13 Post by TD-er » 21 Dec 2020, 23:06
Have you set the boot states in the web uit for the pin?
pw444
#14 Post by pw444 » 21 Dec 2020, 23:07
TD-er wrote: 21 Dec 2020, 23:06 Have you set the boot states in the web uit for the pin?
can you please explain?
#15 Post by TD-er » 21 Dec 2020, 23:09
See the "Hardware" tab in the web UI.
There you can set the internal pull-up state which will be set at boot, before starting the plugins/controllers.
pw444
#16 Post by pw444 » 21 Dec 2020, 23:16
TD-er wrote: 21 Dec 2020, 23:09 See the "Hardware" tab in the web UI.
could not find pullup on the hardware tab. pullup i could only find on devices tab, inside the task definition.
#17 Post by TD-er » 21 Dec 2020, 23:22
It is right under the "GPIO boot states" header.
pw444
solved Re: AC detector - how to make it work?
#18 Post by pw444 » 21 Dec 2020, 23:25
Ok, it's all working now!!!
now i will refine the behavior.
Users browsing this forum: No registered users and 72 guests
