%v1% value not save
sacy80
%v1% value not save
#1 Post by sacy80 » 31 Dec 2020, 17:27
I have encouter issue, base on doc, using let,1,value will store as non-volatile.. and dummy var , but when power remove and power on or reboot.. everything are clear to zero.
code:
On System#Boot do
if [dim01#Counter] = 0
#TaskValueSet,4,1,%v1%
#pwm,14,[dummy#d1],0,22000
TaskValueSet,3,1,%v2%
on dim01#Counter do
TaskValueSet,4,1,[dim01#Counter]*1023/93 //scaling (i have my scaling in device setting for encoder as 1 to 10 to make roughly 10 steps dimmer)
TaskValueSet,4,2,[dim01#Counter]*100/93
if [dim01#Counter] >=1
let,1,[dummy#d1]
#TaskValueSet,4,3,[dummy#d1]
let,2,[dim01#Counter]
version:
Build:⋄ 20111 - Mega
System Libraries:⋄ ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support
Git Build:⋄
Plugin Count:⋄ 46 [Normal]
Build Origin: Travis
Build Time:⋄ Nov 30 2020 00:38:42
Binary Filename:⋄ ESP_Easy_mega_20201130_normal_ESP8266_4M1M
Build Platform:⋄ Linux-4.19.104-microsoft-standard-x86_64-with-glibc2.29
Git HEAD:⋄ mega-20201130_f4f960c
Re: %v1% value not save
#2 Post by Ath » 31 Dec 2020, 18:54
On power-cycle, only settings are restored, not measured or calculated values.
The only values that will be saved are the Dummy Device values, and only during a warm boot (reset), not a cold boot (power off and on again).
ESP's (usually) don't have an on-board battery of some form, and storing to Flash would quickly wear out the flash memory, so that's why it is not able to restore on a power-cycle.
#3 Post by TD-er » 01 Jan 2021, 12:30
Yep, all task values will be stored in so called "RTC memory".
This memory is kept as long as the unit is powered, so on a warm reboot or after a crash, the last values will be restored at boot.
Users browsing this forum: No registered users and 46 guests
