help rule
novembre62
help rule
#1 Post by novembre62 » 02 Jan 2021, 14:45
hi, i would like a rule on pulse counter
..when the Count value is> of a set threshold and remains for a set time ... sends a Telegram notification.
it would be possible ?
Thanks for your help
Re: help rule
#2 Post by Ath » 02 Jan 2021, 15:19
Something like this?
on Pulsecounter#Total do // Could also trigger on Count instead of Total
  if %eventvalue%>100 // Change 100 to desired value
    TimerSet,2,30  // Send Telegram message after 30 seconds, change duration as desired
    TimerSet,2,0 // Stop timer
on Rules#Timer=2 do
  SendToHTTP,url_for_telegram_api,443,'/address/and/other/stuff/with/telegram/message/total=[Pulsecounter#Total]'
NB: I have not investigated how the Telegram API needs to be used, if the GET verb isn't sophisticated enough, you might meed to use the Generic HTTP Advanced controller.
novembre62
Re: help rule
#3 Post by novembre62 » 03 Jan 2021, 09:54
use
https://api.telegram.org/botxxxxxxxx/se ... t_id=xxxxx
& text = xxxxx
for telegram notifications, but on espeasy it doesn't work
Re: help rule
#4 Post by Ath » 03 Jan 2021, 10:14
Do you have any log results from both ESPEasy and Telegram?
The link you provided complaints that field "description" is missing, so you probably need to adjust that.
chemmex
Re: help rule
#5 Post by chemmex » 03 Jan 2021, 12:46
First of all, there's https in the url, so no chance to send it that way
Re: help rule
#6 Post by TD-er » 03 Jan 2021, 14:20
Yep the same for the sendtohttp call, which is using port 443 (HTTPS)
novembre62
Re: help rule
#7 Post by novembre62 » 03 Jan 2021, 16:43
Ath wrote: 03 Jan 2021, 10:14 Do you have any log results from both ESPEasy and Telegram?
the link from the browser works fine ..
thanks for the help, I will try other solutions
Users browsing this forum: No registered users and 65 guests
