ESP32 boards
Re: ESP32 boards
Hi Lisa,
Just thought I'd post a screen shot of uPyEasy on my Lolin32 Lite board, working with three DS18B20 sensors (it seems these have to be on separate pins) and a BME280 showing all three readings (temperature, humidity, and pressure) and running nice and stable.
It starts automatically, thanks to BertB for his suggestion to add a main.py file.
Still using port 9000.
Thanks for all the hard work you have been putting in. Please continue, within the time you have available, and let me know if I can help at all.
AndrewJ
AndrewJ
Re: ESP32 boards
Cool!!!AndrewJ wrote: ↑09 Jan 2018, 17:25 Hi Lisa,
AndrewJ
The DS's should be able to run on one pin, but maybe the plugin can't handle that yet. I haven't tested that out so far.
I'm busy documenting the architecture and database contents, so that you'll understand how uPyEasy operates.
Re: ESP32 boards
I tried this first time around, with just two DS's, but they interfered with each other and both ended up looking at the same ROM address and reporting the same value as each other. It would be good to do that eventually, to match the ESP8266 version (it would simplify wiring, and use less pins too ) but it is probably best to spend time on developing the rest of uPyEasy, unless someone particularly needs that extra functionality.The DS's should be able to run on one pin, but maybe the plugin can't handle that yet. I haven't tested that out so far.
I'll raise an Issue on Github for this so it doesn't get lost.
That sounds good.I'm busy documenting the architecture and database contents, so that you'll understand how uPyEasy operates.
Re: ESP32 boards
Version v54 has been created op put in the releases dir of the uPyEasy github: https://github.com/letscontrolit/uPyEas ... /tag/ALPHA
The following functionality has been added:
Added Save Settings (saving your config)
Added Files (Files Explorer, see all dirs/files in the ESP32 flash area, where you can edit/delete/add them)
This is the LAST alpha, the coming week(s) i'm busy documenting uPyEasy (including Togaf 9.1 based Architecture Guidelines, since i'm certified and working as a Data Architect) and transferring the source code to the Github repository. The first new version will then be BETA-1.
- Config page
- Tools page
Re: ESP32 boards
This is getting better each time I look.
Re: ESP32 boards
Thanks for all your hard work on this!
Re: ESP32 boards
Hi Lisa,LisaM wrote: ↑13 Jan 2018, 13:20 Version v54 has been created op put in the releases dir of the uPyEasy github: https://github.com/letscontrolit/uPyEas ... /tag/ALPHA
The following functionality has been added:Added admin password (password protected uPyEasy!)
- Config page
Added Load Settings (restoring your config)
- Tools page
Many thanks for that. It's working on my LOLIN32 LITE board with no immediate problems.
(I'm still finding that I need to change to port to 9000 to avoid the 128 error, but I've got it off to a fine art now!)
I'll give it a try on my recently-arrived LOLIN32 Pro soon.
Regarding the DOIT devkit v1 - revision 0 chip, I've more or less given up on it. It just seems very unreliable, I think there may be issues with the power supply end but even attempts to use it with an external supply failed.
Looking forward to the BETA-1 when it's ready!
Andrew
Re: ESP32 boards
Hello, thank you for your development
I try the upyeasy for amusing on my Wemos ESP32 lolin oled and that work
If i use a AP wifi open without key, it's ok, on the other hand if i tried an other AP with WPA_PSK, i lost the connexion and i must reset the esp32, an idea
I ested the command upyeasy.setwifi with more combination, but error
I tested a switch with domoticz, doesn't work, it was fast test.
I you want, i can test a oled plugin
>>> upyeasy.setwifi ('IOT','xxxxxxxxxx','','',80)
File "<stdin>", line 1, in <module>
File "upyeasy/__init__.py", line 29, in setwifi
File "upyeasy/utils.py", line 46, in setwifi
File "filedb.py", line 73, in update
OSError: [Errno 2] ENOENT
Re: ESP32 boards
when attempting to flash using :
esptool.py --port COM9 write_flash --baud 460800 --compress 0x1000 upyeasy_v54_20180113_test_esp32_2048.bin
i get:
esptool write_flash: error: argument <address> <filename>: Must be pairs of an address and the binary filename to write there
any tips?
scratch that, removed the "baud" statement and it flashed. leaving this here in case it's helpful to someone else
i get:
any tips?
Re: ESP32 boards
I hate it when stuff does not work reliably.
I think I followed all the steps in the books.
I have Python36 and pip and ampy and pyserial.
When I start pyton i get the >>> signs
when I enter import serial, again I get >>>
But when I enter esptool.py --port COM6 erase_flash in the shell, I get
File "D:\Program Files\Python\Python36\esptool.py", line 34, in <module>
import serial
ImportError: No module named serial
What stupid thin am I forgetting?
Oh, by the way, some week ago I got it working.
And I really want to play with upyeasy Beta ....
import serial
Re: ESP32 boards
Espressif instructions: https://github.com/espressif/esptoolBertB wrote: ↑28 Jan 2018, 16:17 I hate it when stuff does not work reliably.
import serial
More help on installation of esptool: https://diyprojects.io/esp-easy-flash-f ... y-esp8266/
Re: ESP32 boards
Thanks, but i did that:
D:\Program Files>cd python\python36
D:\Program Files\Python\Python36>esptool.py --port COM6 erase_flash
import serial
D:\Program Files\Python\Python36>pip install esptool
Requirement already satisfied: esptool in d:\program files\python\python36\lib\site-packages
Requirement already satisfied: ecdsa in d:\program files\python\python36\lib\site-packages (from esptool)
Requirement already satisfied: pyserial>=2.5 in d:\program files\python\python36\lib\site-packages (from esptool)
Requirement already satisfied: pyaes in d:\program files\python\python36\lib\site-packages (from esptool)
D:\Program Files\Python\Python36>esptool.py --port COM6 flash_id
import serial
D:\Program Files\Python\Python36>mode
Status for device COM6:
Baud: 115200
Parity: None
Data Bits: 8
Stop Bits: 1
Timeout: OFF
XON/XOFF: OFF
CTS handshaking: OFF
DSR handshaking: OFF
DSR sensitivity: OFF
DTR circuit: OFF
RTS circuit: OFF
Re: ESP32 boards
Path set correctly?:BertB wrote: ↑28 Jan 2018, 16:46 Thanks, but i did that:
D:\Program Files>cd python\python36 D:\Program Files\Python\Python36>esptool.py --port COM6 erase_flash Traceback (most recent call last): File "D:\Program Files\Python\Python36\esptool.py", line 34, in <module> import serial ImportError: No module named serial D:\Program Files\Python\Python36>pip install esptool Requirement already satisfied: esptool in d:\program files\python\python36\lib\site-packages Requirement already satisfied: ecdsa in d:\program files\python\python36\lib\site-packages (from esptool) Requirement already satisfied: pyserial>=2.5 in d:\program files\python\python36\lib\site-packages (from esptool) Requirement already satisfied: pyaes in d:\program files\python\python36\lib\site-packages (from esptool) D:\Program Files\Python\Python36>esptool.py --port COM6 flash_id Traceback (most recent call last): File "D:\Program Files\Python\Python36\esptool.py", line 34, in <module> import serial ImportError: No module named serial D:\Program Files\Python\Python36>mode Status for device COM6: ----------------------- Baud: 115200 Parity: None Data Bits: 8 Stop Bits: 1 Timeout: OFF XON/XOFF: OFF CTS handshaking: OFF DSR handshaking: OFF DSR sensitivity: OFF DTR circuit: OFF RTS circuit: OFF
Python -V
esptool.py -h
pip uninstall esptool
pip install esptool
Re: ESP32 boards
I can start python from everywhere on the pc
after issuing Path, I get a lot of stuff, including:
D:\Program Files\Python\Python36\Scripts;D:\Program Files\Python\Python36
C:\Users\berbe>python -VCode: Select all
Python -V
Python 3.6.2
D:\Tools\uPython>esptool.py -hEsptool version?:Code: Select all
esptool.py -h
import serial
Does not seem to help at all ...Re-installing?:Code: Select all
pip uninstall esptool pip install esptool
But when I first start python and then import serial:
D:\Tools\uPython>python
Python 3.6.2 (v3.6.2:5fd33b5, Jul 8 2017, 04:57:36) [MSC v.1900 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import serial
Re: ESP32 boards
Solved it ... I got one esptool.py to many ...
Re: ESP32 boards
yeah ... growing up hurts ...
But, I had a esptool in the directory of Python36.
And one in Lib/site-packages.
When I run esptool from site-packages, there is no nagging about serial.
So, I removed esptool from the home directory of Python.
Now I have the following:
'esptool.py' is not recognized as an internal or external command,
operable program or batch file.
So, that was the wrong de-fuse wire
In site-packages is also the serial directory.
So, where do I put all this stuff?
Re: ESP32 boards
In powershell:BertB wrote: ↑28 Jan 2018, 18:53 yeah ... growing up hurts ...
esptool.py.exe
ls Env:
Re: ESP32 boards
Hi Lisa,
great work.
I installed the beta yesterday on an ESP-32 Dev board
It works, only the performance of the webinterface is not as good as in your videos.
Many of us would like to participate in the event in a timely manner.
Is it possible to provide Nightly Build?
Can you tell us how to compile the source code from Github?
How do you access the file system of the ESP? For example, to exchange .py files.
Many greetings Peter
great work.
- upEASY.jpg (80.27 KiB) Viewed 83630 times
Re: ESP32 boards
Hi Peter,micropet wrote: ↑31 Jan 2018, 15:32 Hi Lisa,
great work.
I'm busy writing the build doc's but will take one or two weeks to complete. Nightly build is on the todo list also.
Here is a guide how to upload files: https://techtutorialsx.com/2017/06/04/e ... le-system/
Re: ESP32 boards
Thank you Lisa,
I am looking forward to it.
I know Ampy, that's really primitive. I thought you had a more comfortable method.
Something like mounting the file system as a drive.
Greetings Peter
Greetings Peter
Re: ESP32 boards
The ESP32 design doesn't allow it, the STM32's all have an usb driver that mimics the flash drive as an usb drive.
You can use ampy (or rshell/mpfshell) and the file commander in uPyEasy tool menu and that's it.
Anything more would take a lot of my time and i'm waisting it on other more important stuff...
Re: ESP32 boards
ok I understand.
But the STM32 has no WIFI and therefore no mqtt integration.
This probably makes the ESP32 most suitable.
- budman1758
Re: ESP32 boards
Re: ESP32 boards
Thank you - already ordered.
WIFI has the advantage for me that I can just put my sensors where I have a 5V power supply.
- budman1758
Re: ESP32 boards
I use those ethernet boards with a Raspberry PI Zero and POE for my homemade security cameras. I send 12 volts to it and use a DC stepdown at the camera. That way the wireless isn't overloaded. Plus, you need power for it anyway so POE makes sense.
Re: ESP32 boards
And now you know where the fast uPyEasy demo came from... Wifi is always slow, 100MB or 1GB ethernet is preferable always! I have my house wired with 40 ethernet connections, together with a 1GB switch it's faster then any wifi ever will be. My gate is 30M from my house, wifi was always unreliable there. Since i have it connected to ethernet, it never failed again.
Re: ESP32 boards
I have about 50 devices here, all connected via WIFI.
None of it is completely reliable. Some run a few weeks, some a few months. Suddenly a device stops sending because it is no longer on the network.
I will test the solution over LAN.
Is the STM32F405RGT6 and the W5500 ethernet card recommended?
The STM32F405RGT6 has little memory.
Or are there better solutions?
Greetings Peter
Greetings Peter
Re: ESP32 boards
Have these 'stalled' devices been up like 49.7 days?
If so. please test with one of the last builds for ESPeasy.
I've added some patches to prevent such crashes.
Re: ESP32 boards
Yes, they are always on.
It is the latest version from the Git. I always flash about 5 devices with the current version.
They have stayed in the network so far. I would have to watch it longer.
One Device with BME280 VEML6040 MH-Z19 TVoc CSS811 SDS021 loses the CSS811, BME280 and the VEML6040 after a few hours. After a reset, the sensors stay away.
Only switching off and then switching on the supply voltage brings it back to life.
There are 2x 10k terminators on the I2C bus. The device ran before with an ESP-32 always without problems. I have no idea why the I2C bus suddenly stops working.
Re: ESP32 boards
Lisa,
here you can compare the performance of my installation. ESP-210 is the Arduino version, ESP-01 is the Python version. The Python version sometimes hangs for a few seconds.
Greetings Peter
Greetings Peter
- Performance ESPEasy.zip
- (1.59 MiB) Downloaded 696 times
Re: ESP32 boards
Peter,
Am i correct to notice that the uPyEasy performance is good, besides the hardware tab?
Cheers,
Lisa
Re: ESP32 boards
Yes, the orange/raspberry pi which have it all, loads of memory and ethernet and wifi, however they have a tradeoff in terms of latency. Besides that, i haven't found so far an I2C python library for the pi's which can be used with micropython.
Re: ESP32 boards
Yes Lisa, most of the time the performance is good.
But there is also a break in between, then it takes a little longer.
Re: ESP32 boards
But real python is running on the Pi.
Also with I2C.
I had built some devices with sensors and PWM for my LEDs a long time ago.
They also did not run so reliably. Often there were problems with the microSD.
The Card was suddenly unreadable.
With my PI3s I booted over a USB stick, that was little better.
Overall, I was not satisfied.
I think the most important thing in lighting control or in sensor devices is reliability. They should never fail.
Also with I2C.
Re: ESP32 boards
The STM32's are build for industrial purposes, expensive but very reliable. That's why they have a very low latency, a ton of sensor inputs en low memory. They run in factories and buildings for decades without hickup. The ESP's are build for consumers, cheap and a lot of memory.micropet wrote: ↑02 Feb 2018, 13:01 But real python is running on the Pi.
Also with I2C.
Re: ESP32 boards
So STM boards ...
I just got a PYBv1.1 with STM32F405RG and flashed it with normal MicroPython .
My machine immediately detected an additional drive with boot.py and main.py.
Wow, great.
Can I simply copy the .py files from your github to this drive?
Unfortunately, I have no experience with microPython.
Greetings Peter
Wow, great.
Greetings Peter
Re: ESP32 boards
Lisa,
if I flash the file upyeasy_v020_test_20180128_stm32-pybv3_1024.dfu on the PYBv1.1 the COM port is gone.
I'm flashing on Windows with dfu-util - old 0 -D upyeasy_v020_test_20180128_stm32-pybv3_1024.dfu
If I flash the original MicroPython, the COM port is back.
That's not right or?
Re: ESP32 boards
You can't copy the uPyEasy python files over to the STM flash drive, because it ain't big enough. The uPyEasy files are 'frozen', meaning they are part of the firmware. You need to flash the STM again using these instructions: viewtopic.php?f=22&t=3905micropet wrote: ↑02 Feb 2018, 17:20 So STM boards ...
Wow, great.
Greetings Peter
Re: ESP32 boards
Did you turn the STM on/off? Did the com port disappear completely or did it change numbers?micropet wrote: ↑02 Feb 2018, 18:50 Lisa,
Please continue the STM thread in the STM32 topic.
Re: ESP32 boards
The board has been restarted several times.
The Comport remains completely gone.
But an "unknown device" emerges
An error occurred while requesting the USB device descriptor.
If I flash the original Python, Comport is back.
Sorry listen now in STM thread in the STM32 topic
Re: ESP32 boards
Hi Lisa,
I'm sorry to report that I'm having a problem with Beta version v.0.2.1. on ESP32 boards
I downloaded the binary from the releases page, and installed it per the instructions in post 1 (I tried with and without an erase first). it's getting into a reboot loop when it starts. The log shows
repeated endlessly. This is happening on two different ESP32 boards, one is a Lolin32 Lite, the other a Lolin32 Pro.
I tried it a few times with the same result, then went back to v54 and it works fine.
Am I missing something?
Andrew.
rst:0x10 (RTCWDT_RTC_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3f400020,len:429240
ets Jun 8 2016 00:22:57
Andrew.
Re: ESP32 boards
I have the same problem.
Look here:
http://www.letscontrolit.com/forum/view ... 869#p24927
Best regards
Look here:
Best regards
Re: ESP32 boards
Hello @CHK_BLN,
Thanks for that, it's comforting to know I'm not alone!
Were you able to find any solution?
Best wishes
Andrew
Best wishes
Andrew
Re: ESP32 boards
I have the same problem with this release.
too dumb to check it
hi,
I am trying to get upyeasy on a esp32. after installing python, first hurdler taken, I had to install pyserial and finally got it done, but it took me some time to get there.
next hurdle: I want to start Firmware install on esp32 by:
esptool.py --port COM4 write_flash --baud 460800 --compress 0x1000 upyeasy_v021_20180218_test_esp32_2048.bin
but I get back:
usage: esptool write_flash [-h] [--flash_freq {keep,40m,26m,20m,80m}]
[--flash_mode {keep,qio,qout,dio,dout}]
[--flash_size FLASH_SIZE]
[--spi-connection SPI_CONNECTION] [--no-progress]
[--verify] [--compress | --no-compress]
<address> <filename> [<address> <filename> ...]
can someone help me to do it right...
lisam: you are doing a really really great Job, many thanks! but can you pleeeease create a routine like for espeasy which is really idiotic-proof... ie. for me
many thanks
karl
but I get back:
many thanks
karl
Re: ESP32 boards
I've got it running by using this string, which I found after searching through the thread:
E:\>esptool.py -p COM4 --baud 115200 write_flash --compress 0x1000 upyeasy_v021_20180218_test_esp32_2048.bin
